I have this Growatt script which was working fine until last sunday.
It now gives a unexpected http error.
Does anybody recognize this ??
This is the script:
#!/usr/bin/php
<?PHP
* Pass2PHP
* php version 7.0
* @category Home_Automation
* @package Pass2PHP lightscript for Growatt Inverter
* @author Sándor Incze
* @license GNU GPLv3
* @link https://github.com/sincze/Domoticz
// $ sudo apt-get update && sudo apt-get upgrade
// $ sudo apt-get install php7.0 php7.0-curl php7.0-gd php7.0-imap php7.0-json php7.0-mcrypt php7.0- php7.0-cli
// $ cd /home/pi/domoticz/scripts
// $ mkdir pass2php
// $ cd pass2php
// $ Add the downloaded RAW file here
// In Domoticz:
// Create Virtual Sensor -> Electric (instant+Counter)
// Check device idx (Setup-> Devices) for created Virtual Sensor
// Check Setup -> Settings -> Local Networks if '127.0.0.*' is present.
// In growatt-inverter.php
// Modify **** to your username line 49
// Modify **** to your password line 50
// Modify DOMOTICZDEVICE **** to your IDX line 56
// In terminal execute 'php /home/pi/domoticz/scripts/pass2php/growatt-inverter.php'
// No errors should be seen, check domoticz created virtual sensor device & log for errors.
// If device is updated continue.
// $ sudo nano /etc/crontab
// add line: */5 * * * * root php /home/pi/domoticz/scripts/pass2php/growatt-inverter.php >/dev/null 2>&1
error_reporting(E_ALL);
ini_set("display_errors","on");
date_default_timezone_set('Europe/Amsterdam');
define('time',$_SERVER['REQUEST_TIME']);
define('domoticz','http://192.168.178.52:8080/');
#define('domoticz','http://127.0.0.1:8080/');
retrieve_growatt_data('test');
function retrieve_growatt_data($command)
define('USERNAME', '*****'); // The username or email address of the account.
define('PASSWORD', '******');// The Password of the account
$pw = md5(PASSWORD); // No Need to double md5
//replace leading 0 by c for Growatt
for ($i = 0; $i < strlen($pw); $i=$i+2){
if ($pw[$i]=='0')
$pw=substr_replace($pw,'c',$i,1);
define('USER_AGENT', 'Dalvik/2.1.0 (Linux; U; Android 9; ONEPLUS A6003 Build/PKQ1.180716.001)'); // Set a user agent.
define('COOKIE_FILE','/home/pi/domoticz/scripts/pass2php/growatt.cookie'); // Where our cookie information will be stored (need to be writable!)
define('HEADER',array('Content-Type: application/x-www-form-urlencoded;charset=UTF-8'));
define('LOGIN_FORM_URL', 'http://server-api.growatt.com/newLoginAPI.do'); // URL of the login form.
define('LOGIN_ACTION_URL', 'http://server-api.growatt.com/newLoginAPI.do'); // Login action URL. Sometimes, this is the same URL as the login form.
define('DOMOTICZDEVICE', '65'); // 'idx_here' For Watt / Daily Return
$continue=true;
$postValues = array(
'userName' => USERNAME,
'password' => $pw
$curl = curl_init();
curl_setopt($curl, CURLOPT_URL, LOGIN_ACTION_URL); // Set the URL that we want to send our POST request to. In this case, it's the action URL of the login form.
curl_setopt($curl, CURLOPT_POST, true); // Tell cURL that we want to carry out a POST request.
curl_setopt($curl, CURLOPT_POSTFIELDS, http_build_query($postValues)); // Set our post fields / date (from the array above).
curl_setopt($curl, CURLOPT_SSL_VERIFYHOST, false); // We don't want any HTTPS errors.
curl_setopt($curl, CURLOPT_SSL_VERIFYPEER, false); // We don't want any HTTPS errors.
curl_setopt($curl, CURLOPT_COOKIEJAR, COOKIE_FILE); // Where our cookie details are saved.
// This is typically required for authentication, as the session ID is usually saved in the cookie file.
curl_setopt($curl, CURLOPT_HTTPHEADER, HEADER);
curl_setopt($curl, CURLOPT_COOKIEFILE, COOKIE_FILE);
curl_setopt($curl, CURLOPT_USERAGENT, USER_AGENT); // Sets the user agent. Some websites will attempt to block bot user agents. //Hence the reason I gave it a Chrome user agent.
curl_setopt($curl, CURLOPT_RETURNTRANSFER, true); // Tells cURL to return the output once the request has been executed.
curl_setopt($curl, CURLOPT_REFERER, LOGIN_FORM_URL); // Allows us to set the referer header. In this particular case,
// we are fooling the server into thinking that we were referred by the login form.
curl_setopt ($curl, CURLOPT_SSLVERSION, 1);
curl_setopt($curl, CURLOPT_FOLLOWLOCATION, true); // Do we want to follow any redirects?
$result=curl_exec($curl); // Execute the login request.
if(curl_errno($curl)){
switch ($http_code = curl_getinfo($curl, CURLINFO_HTTP_CODE)) {
case 200: $continue=true;# OK
lg('Growatt inverter: Login: Expected HTTP code: ', $http_code);
break;
case 302: $continue=true;# OK
break;
default: $continue=false;
lg('Growatt inverter: Login: Unexpected HTTP code: ', $http_code);
curl_close($curl);
if (file_exists(COOKIE_FILE)) lg ('Cookie File: '.COOKIE_FILE.' exists!'); else lg ('Cookie File: '.COOKIE_FILE.' does NOT exist!');
if (is_writable(COOKIE_FILE)) lg ('Cookie File: '.COOKIE_FILE.' is writable!'); else lg ('Cookie File: '.COOKIE_FILE.' NOT writable!');
if ($continue) {
$url='http://server-api.growatt.com/newPlantA ... EnertyData';
curl_setopt($curl, CURLOPT_URL, $url);
curl_setopt($curl, CURLOPT_POSTFIELDS, "language=1" );
curl_setopt($curl, CURLOPT_SSL_VERIFYPEER, 1);
curl_setopt($curl, CURLOPT_SSL_VERIFYHOST, 2);
$result = curl_exec($curl);
lg('Growatt inverter: Data: Expected HTTP code: ', $http_code);
break;
break;
lg('Growatt inverter: Data: Unexpected HTTP code: ', $http_code);
curl_close($curl);
$data = json_decode($result, JSON_PRETTY_PRINT);
if(!empty($data['todayStr']) && !empty($data['totalValue'])) {
$nowpower = (float)$data['powerValue'];
$todaypower = (float)$data['todayValue']; // kWH
$allpower = (float)$data['totalValue']; // [totalStr] => 1505.4kWh [totalValue] => 1505.4
$allpower = $allpower*1000; // Convert to Wh
$str=( $nowpower.';'.$allpower ); // times 1000 to convert the 0.1kWh to 100 WattHour and to convert 2.1kWh to 2100 WattHour
lg('Growatt Inverter: '. $nowpower.' for domoticz: '.$str);
ud(DOMOTICZDEVICE,0,$str,'GrowattInverter: Generation updated');
function lg($msg) // Can be used to write loglines to separate file or to internal domoticz log. Check settings.php for value.
curl(domoticz.'json.htm?type=command¶m=addlogmessage&message='.urlencode('--->> '.$msg));
function ud($idx,$nvalue,$svalue,$check=false)
curl(domoticz.'json.htm?type=command¶m=udevice&idx='.$idx.'&nvalue='.$nvalue.'&svalue='.$svalue);
lg(' (udevice) | '.$idx.' => '.$nvalue.','.$svalue);
function curl($url){
$headers=array('Content-Type: application/json');
$ch=curl_init();
curl_setopt($ch,CURLOPT_URL,$url);
curl_setopt($ch,CURLOPT_RETURNTRANSFER,1);
curl_setopt($ch,CURLOPT_CONNECTTIMEOUT, 5);
curl_setopt($ch,CURLOPT_TIMEOUT, 3);
curl_setopt($ch,CURLOPT_USERAGENT,'Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.13) Gecko/20080311 Firefox/2.0.0.13');
curl_setopt($ch,CURLOPT_HTTPHEADER,$headers);
$data=curl_exec($ch);
curl_close($ch);
return $data;
This is the Line in sudo crontab
*/5 * * * * root php /home/pi/domoticz/scripts/pass2php/growatt-inverter_2.php >/dev/null 2>&1
Growatt inverter scripts does not work any more
rick8245
Re: Growatt inverter scripts does not work any more
I found out that I could not reach the internet and network.
The error is gone and the script does not give any errors.
In domoticz I do not see anything in the log file.
In UTILITY it does not update either
Any ideas ??
thanks in advance
Rick
Any ideas ??
thanks in advance
Rick
- Domoticz version: 2025.1
What messages do you see in a terminal window when you follow the instructions in the script to test the script
And you definitely need internet access to growatt.com. New wifi router? Something changed in your network?
rick8245
Hi Waltervl,
Thanks for your response
Manually it works fine now .
I like to use it in a cron so i did : sudo cron -e
Then I put this line into a cron : */5 * * * * root php /home/pi/domoticz/scripts/pass2php/growatt-inverter.php
If i run : grep CRON /var/log/syslog
I do see : Sep 8 07:30:01 raspberrypi CRON[30865]: (pi) CMD (root php /home/pi/domoticz/scripts/pass2php/growatt-inverter.php)
But nothing happens while it should run every 5 minutes ...as far as i know.
Thanks in advance
Rick8245
Thanks in advance
Rick8245
rick8245
I just checked and now it works fine. Maybe it needed some time to run OK
OK good, thanks for the feedback!
rick8245
No problem, thanks for your help Waltervl
