[solved] Python Framework DomoticzEx - onRemove Topic is solved
pipiche
Post by pipiche »
When removing a device from Domoticz and with a plugin using DomoticzEx, I'm getting this error !
Sep 06 18:55:33 rasp domoticz[9565]: 2021-09-06 18:55:33.759 Error: DomoticzEx: (DomoticzEx) 'onDeviceRemoved' failed 'TypeError':'onDeviceRemoved() takes 1 positional argument but 2 were given'.
Sep 06 18:55:33 rasp domoticz[9565]: 2021-09-06 18:55:33.760 Error: DomoticzEx: (DomoticzEx) No traceback available
    def onDeviceRemoved( self, DeviceID, Unit ):
        Domoticz.Log("onDeviceRemoved... Ex")
def onDeviceRemoved(DeviceID,Unit):
    global _plugin
    _plugin.onDeviceRemoved(DeviceID, Unit)
Last edited by pipiche on Thursday 09 September 2021 21:16, edited 1 time in total.
Dnpwwo
Re: Python Framework DomoticzEx - onRemove
Post by Dnpwwo »
Hmmm ... not sure.
This worked for me:
    def onDeviceRemoved(self, DeviceID, Unit):
        Domoticz.Log("Device onDeviceRemoved for Plugin")
    global _plugin
    _plugin.onDeviceRemoved(DeviceID,Unit)
I also added this at the 'Device' level and it worked as well (correctly overrode the base plugin one):
    def onDeviceRemoved(self, Unit):
        Domoticz.Log("Device onDeviceRemoved")
Are you sure the DomoticzEx module was loaded and not Domoticz?
pipiche
Post by pipiche »
Ok will cross check
pipiche
Post by pipiche »
@Dnpwwo sorry for wasting your time. It works as documented ... My fault.
