Page 1 of 2
Electricity Current/Ampere 3 Phase IPX800V3 + X400CT
Posted: Friday 27 August 2021 22:19
by laco
- current-clamps-for-x400-ct.jpg (7.72 KiB) Viewed 2519 times
- x400ct-addon-for-ipx800.jpg (8.1 KiB) Viewed 2519 times
- web-relay-board-control-ipx800-v3.jpg (14.02 KiB) Viewed 2519 times
I would need to convert this LUA script to DzVents.
Can anyone help me?
-- Odber 3 fázy
--time=os.date("*t")
IDX=44 --virtual CM113, Electrisave
IDX_D=40 --darling
json = (loadfile "/volume1/docker/domoticz/config/scripts/lua/JSON.lua")() -- For Synology Linux
local config=assert(io.popen('/usr/bin/curl "http://login:[email protected]/api/xdevices.json?cmd=30"'))
local blocjson = config:read('*all')
config:close()
-- print (blocjson)
local jsonValeur = json:decode(blocjson)
-- if time.min%2==0 then --[2min test]--
faza1=(tonumber(jsonValeur.AN6)/310) --faza1 on IPX800V3
faza2=(tonumber(jsonValeur.AN7)/310) --faza2 on IPX800V3
faza3=(tonumber(jsonValeur.AN8)/310) --faza3 on IPX800V3
darling=(tonumber(jsonValeur.AN5)/310) --darling
print ('faza1 : ' .. faza1) --prints a value.
print ('faza2 : ' .. faza2) --prints a value.
print ('faza3 : ' .. faza3) --prints a value.
print ('darling : ' .. darling) --prints a value.
commandArray[1]={['UpdateDevice'] = IDX .."|0|"..faza1..";"..faza2..";"..faza3..";"}
commandArray[2]={['UpdateDevice'] = IDX_D .."|0|"..darling..";"}
--end
Re: Electricity Current/Ampere 3 Phase
Posted: Sunday 29 August 2021 13:10
Could be based on something like this
https://domoticz.com/forum/viewtopic.ph ... 44#p237144
You can reuse your own json parsing logic.
Posted: Monday 30 August 2021 9:04
by laco
Use this command to read data from my IPX800 V3, X400-CT:
http://192.168.1.120/api/xdevices.json?cmd=30
{"product":"IPX800_V3","AN1":766,"AN2":62,"AN3":190,"AN4":65,"AN5":0,"AN6":823,"AN7":1269,"AN8":1548,"AN9":0,"AN10":0,"AN11":0,"AN12":0,"AN13":0,"AN14":0,"AN15":0,"AN16":0}
I have an analog phase sampling sensor in Amperes there.
AN6 = PHASE1
AN7 = PHASE2
AN8 = PHASE3
I need to write data to the virtual sensor IDX:44 CM113, Electrisave
Thanks for help
Posted: Monday 30 August 2021 9:11
dzVents is based on Lua so some things be the same.
Take the script I referred to and copy the json parsing logic into it.
You need .updateCurrent(current1, current2, current3) to update your 3Phase Current device (idx 44)
What kind of device is the darling? Check the update code for that in
https://www.domoticz.com/wiki/DzVents:_ ... _scripting
Posted: Thursday 02 September 2021 15:28
by laco
I can't do it.
Posted: Thursday 02 September 2021 15:47
What do you have now on code and what is the error?
Posted: Thursday 02 September 2021 17:41
by laco
The LUA script above gives me an error:
2021-09-02 17:35:00.770 Error: EventSystem: in Script #11 Odber 3 fázy: [string "-- Odber 3 fázy ..."]:8: attempt to call a nil value
I have Domoticz running in DOCKER
https://hub.docker.com/r/domoticz/domoticz
Posted: Thursday 02 September 2021 23:46
It could be something like this.
Not tested!!!
local scriptVar = '3PhaseCurrent'
return
on =
timer =
'every 5 minutes',
httpResponses =
scriptVar
logging =
level = domoticz.LOG_DEBUG, -- set to LOG_ERROR when tested and OK
marker = scriptVar,
execute = function(dz, item)
if item.isTimer then
dz.openURL({
url = 'http://192.168.1.120/api/xdevices.json?cmd=30',
callback = scriptVar,
return
if (item.isHTTPResponse) then
if item.ok then
--- do the parsing logic here
local jsonValeur = item.json
domoticz.log('3 Phase values = ' .. faza1 .. ' , ' .. faza2 .. ' , ' .. faza3, domoticz.LOG_INFO)
-- update devices here
domoticz.devices(44).updateCurrent(faza1, faza2, faza3) -- update IDX:44 CM113, Electrisave
-- domoticz.devices(40).update????(darling) -- update command depends on device type. See dzVents Wiki
dz.log('There was a problem handling the request', dz.LOG_ERROR)
dz.log(item, dz.LOG_ERROR)
Posted: Sunday 05 September 2021 18:27
by laco
Prints an error:
2021-09-05 18:26:00.688 Error: dzVents: Error: (3.1.8) 3PhaseCurrent: An error occurred when calling event handler Odber 3 fazy
2021-09-05 18:26:00.689 Error: dzVents: Error: (3.1.8) 3PhaseCurrent: ...rdata/scripts/dzVents/generated_scripts/Odber 3 fazy.lua:41: attempt to index a nil value (global 'domoticz')
Posted: Tuesday 07 September 2021 9:44
by laco
I enter in a web browser:
Print this text:
{"product":"IPX800_V3","AN1":805,"AN2":65,"AN3":202,"AN4":65,"AN5":0,"AN6":0,"AN7":14,"AN8":254,"AN9":0,"AN10":0,"AN11":0,"AN12":0,"AN13":0,"AN14":0,"AN15":0,"AN16":0}
Posted: Tuesday 07 September 2021 10:46
As said the script was not tested. There were some inconsistencies in the dz/domoticz calls. I tried to fix them in the code below.
return
on =
timer =
'every 5 minutes',
httpResponses =
scriptVar
logging =
marker = scriptVar,
domoticz.openURL({
return
if item.ok then
domoticz.log('There was a problem handling the request', dz.LOG_ERROR)
domoticz.log(item, dz.LOG_ERROR)
Posted: Wednesday 08 September 2021 8:26
by laco
It's working properly now.
Well thank you.
Is it possible to set it to write more often than 1 minute?
Posted: Wednesday 08 September 2021 9:06
by rrozema
You still have some dz. in that code that needs to be replaced by domoticz.
return
on =
timer =
'every 5 minutes',
httpResponses =
scriptVar
logging =
marker = scriptVar,
domoticz.openURL({
return
if item.ok then
domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
domoticz.log(item, domoticz.LOG_ERROR)
And no, dzvents timers can't be set faster than once per minute. I think you may be able to do it though using
command option .afterSec()), but i haven't tested it so I really don't know if below code actually works. But if it does work, it will query your device and update your device values in domoticz every 15 seconds. I also added .checkFirst() to the update statement, to prevent the values to be updated every 15 seconds even if no new value was read. Again, this is untested: see for yourself if it works. And please do let us know the results
return
on =
timer =
'every 1 minute',
httpResponses =
scriptVar
logging =
marker = scriptVar,
domoticz.openURL({
domoticz.openURL({
}).afterSec(15)
domoticz.openURL({
}).afterSec(30)
domoticz.openURL({
}).afterSec(45)
return
elseif (item.isHTTPResponse) then
if item.ok then
domoticz.devices(44).updateCurrent(faza1, faza2, faza3).checkFirst() -- update IDX:44 CM113, Electrisave
However, dzvents may still not be the best solution for this, because this is actually an implementation of a hardware device. I think it should be possible to implement this using the
http/https poller hardware. Using that method it
is possible to trigger the refresh more often than once per minute, for example every 10 seconds is quite normal. An example of how this is done for another device can be found here (site is in Dutch, sorry) :
https://www.connectix.nl/watermeter-uit ... -domoticz/
Posted: Thursday 09 September 2021 17:29
by laco
It works properly, writes every 15 seconds.
But it still displays an error in the log.
2021-09-09 17:23:00.835 Status: dzVents: Debug: - HTTPResponse: 3PhaseCurrent
2021-09-09 17:23:00.860 Status: dzVents: Info: Handling httpResponse-events for: "3PhaseCurrent"
2021-09-09 17:23:00.861 Status: dzVents: Info: 3PhaseCurrent: ------ Start internal script: Odber_phase_15s: HTTPResponse: "3PhaseCurrent"
2021-09-09 17:23:00.862 Status: dzVents: Info: 3PhaseCurrent: 3 Phase values = 0.0 , 0.045161290322581 , 0.75806451612903
2021-09-09 17:23:00.871 Status: dzVents: Debug: 3PhaseCurrent: Processing device-adapter for Fázy: 3-phase Ampere device adapter
2021-09-09 17:23:00.872 Status: dzVents: Info: 3PhaseCurrent: ------ Finished Odber_phase_15s
2021-09-09 17:23:00.872 Status: dzVents: !Info: 3PhaseCurrent: Debug: Writing module summary to /opt/domoticz/userdata/scripts/dzVents/module.log
2021-09-09 17:23:00.872 Error: dzVents: Error: (3.1.8) 3PhaseCurrent: An error occurred when calling event handler Odber_phase_15s
2021-09-09 17:23:00.872 Error: dzVents: Error: (3.1.8) 3PhaseCurrent: ...ta/scripts/dzVents/generated_scripts/Odber_phase_15s.lua:54: attempt to call a nil value (field 'checkFirst')
Posted: Thursday 09 September 2021 20:49
by rrozema
That's the 2nd addition I did: checking if the value has actually changed. Please remove the .checkFirst() from that code and see if works better then.
It should have worked, but apparently something's wrong, so better leave it off for now.
Re: Electricity Current/Ampere 3 Phase IPX800V3 + X400CT
Posted: Friday 10 September 2021 9:01
by laco
Thank you very much.
Now it works perfectly.
I set every 5 seconds to write the value.
Here is my function code:
return
on =
timer =
'every 1 minutes',
httpResponses =
scriptVar
logging =
marker = scriptVar,
domoticz.openURL({
url = 'http://login:[email protected]/api/xdevices.json?cmd=30',
domoticz.openURL({
}).afterSec(5)
domoticz.openURL({
}).afterSec(10)
domoticz.openURL({
}).afterSec(15)
domoticz.openURL({
}).afterSec(20)
domoticz.openURL({
}).afterSec(25)
domoticz.openURL({
}).afterSec(30)
domoticz.openURL({
}).afterSec(35)
domoticz.openURL({
}).afterSec(40)
domoticz.openURL({
}).afterSec(45)
domoticz.openURL({
}).afterSec(50)
domoticz.openURL({
}).afterSec(55)
return
if item.ok then
phase1=(tonumber(jsonValeur.AN6)/310) --phase1 on IPX800V3
phase2=(tonumber(jsonValeur.AN7)/310) --phase2 on IPX800V3
phase3=(tonumber(jsonValeur.AN8)/310) --phase3 on IPX800V3
domoticz.log('3 Phase values = ' .. phase1 .. ' , ' .. phase2 .. ' , ' .. phase3, domoticz.LOG_INFO)
domoticz.devices(44).updateCurrent(phase1, phase2, phase3) -- update IDX:44 CM113, Electrisave
domoticz.devices(40).updateCurrent(darling) -- update command depends on device type. See dzVents Wiki
- last-24-hours.jpeg (48.89 KiB) Viewed 2516 times
Posted: Friday 10 September 2021 11:41
by rrozema
As I said, retrieving the values using dzVents is not the best idea. It works, but it may overload your system. Symptoms of an overloaded system can be: slow response of the domoticz UI site, long delays between clicking a button in Domoticz and the actual response of the device and vice versa, long delays between activating an actuator (f.e. a light switch) and the corresponding device in Domoticz showing the result, high cpu usage, high RAM usage, overheating, etc. And if you really go to far, you could even crash/freeze Domoticz. So I would suggest not to update as often as every 5 seconds. Plus, besides the potential performance issues, adding new values every 5 seconds makes your database grow very fast too.
You're better off implementing your interface using one of the "hardware" methods Domoticz provides. This can for example be the HTTP/HTTPS poller combined with a lua script, or a python hardware implementation. Those can achieve similar results, but they are meant to be run every so-many seconds, so they're probably better optimized for it. I can't give you much pointers how to exactly use those "hardware" methods, as I've myself not done this before either. I just want you to be aware that the way you're doing it now can potentially cause you other/future problems in your system.
Posted: Friday 10 September 2021 12:33
I agree, especially for URL requests they can be high demanding on your system. dzVents luckily now supports asynchronous requests but setting it to 5 seconds is a little bit fast. Why do you need this? Looking at your graph there is no spike of 5 seconds. so 30 sec or 1 minute should be enough in monitoring your 3Phase usage. In the end, in the weekly/monthly/yearly overviews all the values of 1 day are recalculated and summarized to 1 daily value (containing min,max and average). So these 5 sec intervalls are only stored for max 7 days (depends on your Log settings in menu Setup-Settings)
Posted: Friday 10 September 2021 13:08
by laco
My domoticz runs in DOCKER on SYNOLOGY NAS.
I'm testing it so far, but the CPU load and RAM consumption are very low.
The response is fast, there is no sign of slowing down.
It is important for me to know the immediate consumption in Wats.
- 2021-09-10 (1).png (32.32 KiB) Viewed 2500 times
- 2021-09-10.png (6.71 KiB) Viewed 2500 times
Posted: Sunday 07 November 2021 12:50
by laco
I have one more question.
Can I modify the script to write only positive data?
For example, if 0 is darling so that it does not write it to the database.
Is it possible to create a separate script for DARLING?
