Page 1 of 2
Installation-error ZiGate on Domoticz on Windows
Posted: Wednesday 25 August 2021 8:48
by djdehaan
Log message: "I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work"
Short version of what I did so far:
I run Domoticz 2021.1 on Windows 10 with Python 3.8.2 and few Python plugins running smooth.
I bought the ZiGate+ V2 dongle, installed it on the machine and did the hardware test ZGWUI successful (dongle appears on COM5).
I downloaded the python plugin, configured it (COM5) and the plugin is starting.
2021-08-25 08:45:08.109 Status: ZiGate: (ZiGate) Started.
2021-08-25 08:45:08.109 Status: ZiGate: (ZiGate) Entering work loop.
2021-08-25 08:45:08.109 Status: Incoming connection from: 192.168.100.100
2021-08-25 08:45:08.300 Status: ZiGate: (ZiGate) Initialized version 5.1, author 'zaraki673 pipiche38'
2021-08-25 08:45:08.300 Status: ZiGate: (ZiGate) filename set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Conf/PluginConf-43.json
2021-08-25 08:45:08.300 Status: ZiGate: (ZiGate) pluginHome set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\
2021-08-25 08:45:08.300 Status: ZiGate: (ZiGate) homedirectory set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\
2021-08-25 08:45:08.300 Status: ZiGate: (ZiGate) pluginData set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Data/
2021-08-25 08:45:08.300 Status: ZiGate: (ZiGate) pluginConfig set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Conf/
2021-08-25 08:45:08.300 Status: ZiGate: (ZiGate) pluginOTAFirmware set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\OTAFirmware/
2021-08-25 08:45:08.300 Status: ZiGate: (ZiGate) pluginReports set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Reports/
2021-08-25 08:45:08.300 Status: ZiGate: (ZiGate) pluginWWW set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\www/
2021-08-25 08:45:08.300 Status: ZiGate: (ZiGate) pluginLogs set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Logs/
2021-08-25 08:45:08.300 Status: ZiGate: (ZiGate) Zigate plugin stable5-5.1.006 started
2021-08-25 08:45:08.336 Status: ZiGate: (ZiGate) DeviceConf loaded
2021-08-25 08:45:08.399 Status: ZiGate: (ZiGate) load ListOfDevice
2021-08-25 08:45:08.415 Status: ZiGate: (ZiGate) 0 Entries loaded from C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Data/DeviceList-43.txt
2021-08-25 08:45:08.415 Status: ZiGate: (ZiGate) Transport mode: V2-USB
But after a minute it start showing errors in the Domotics logging:
2021-08-25 08:46:20.116 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 08:46:20.116 Error: ZiGate: (ZiGate) [ 72] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 08:46:21.098 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 08:46:21.098 Error: ZiGate: (ZiGate) [ 73] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 08:46:22.099 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 08:46:22.099 Error: ZiGate: (ZiGate) [ 74] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
Also, I am not able to launch the management screen on <IP>:9440
Has anyone tips what the problem is or where to search??
-COM port seems right, as ZGWUI shows a good response retrieving the version info
Many thanks,
Dirk Jan de Haan
Netherlands
Re: Installation-error ZiGate on Domoticz on Windows
Posted: Wednesday 25 August 2021 8:51
by pipiche
Did you enable the flag Initialise Zigate from the hardware menu ?
Posted: Wednesday 25 August 2021 9:02
Did you close the ZGWUI before starting the Domoticz application as normally 1 program can have access to a USB device (except mouse etc).
Posted: Wednesday 25 August 2021 9:55
by djdehaan
Hi Pipiche: I did enable the flag, see the attachment - that is what you mean?
Hi Waltervl: I did close the connection in ZGWUI
Thanks for your idea's!
Posted: Wednesday 25 August 2021 9:58
by pipiche
Posted: Wednesday 25 August 2021 10:36
by djdehaan
Hi Pipiche, yes, did that too, did it again and no difference.
I switched "Initialize ZiGate" to true, then Update. In the log I see the same as in my original post: the plugin loads with success, but after a minute the errors start. I do have the 2 devices, "Zigate Status 43" and "Zigate Notification 43".
Posted: Wednesday 25 August 2021 10:39
by pipiche
This looks as a communication issue or something like that. But the log you provided are not helpfull as there is only the Status.
There is dedicated Win10 setup page (unfortunatly only in French)
https://github.com/pipiche38/Domoticz-Z ... windows-10
That could be helpfull
What do you have if you look, after the logs of "Zigate Notification 43" device ?
Posted: Wednesday 25 August 2021 10:52
by djdehaan
There is nothing in the Notification device, see attachment.
I did use that french page (with Google Translate to understand it), it was very usefull to get all the steps right. There were maybe 2 issues:
Could it be something with rights in Windows? I tried to locate the ZiGate Python App on the hard drive (after installation), but cannot find it (I do not mean the plugin but the App).
That installed fine; could there be an access rights problem?
Also, in Windows there seems not to be this library, could that cause a problem?
I also tried 3.8 and many other codes.
Posted: Wednesday 25 August 2021 11:09
by pipiche
can you try configuring Zigate instead of Zigate+ ?
Posted: Wednesday 25 August 2021 11:16
by djdehaan
I just did that, result is the same: after 1 minute errors.
Posted: Wednesday 25 August 2021 11:56
by pipiche
What do you mean by App ?
would it be something with rights in Windows? I tried to locate the ZiGate Python App on the hard drive (after installation), but cannot find it (I do not mean the plugin but the App).
Posted: Wednesday 25 August 2021 12:07
by pipiche
Can you try to edit the file
C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Conf\PluginConf-43.json
( I suppose 43 from what I have seen in your logs, it could be something else. This is the HardwareiD of the plugin in Domoticz)
Then add the following lines:
"debugzigateCmd" : 1,
"debugPlugin": 1,
Then you restart the plugin, and please copy-paste all logs that you can see in the Domoticz Logs windows relevant to the Plugin (not only Status and Errors, but Logs as weel )
Posted: Wednesday 25 August 2021 12:23
by djdehaan
Edited the PluginConf-43.json file as suggested, enabled the hardware in Domiticz, applied filter "ZiGate" on logging:
2021-08-25 12:11:11.160 ZiGate hardware started.
2021-08-25 12:11:11.675 ZiGate: (ZiGate) ZiGate plugin started!
2021-08-25 12:11:11.675 ZiGate: (ZiGate) load PluginConf
2021-08-25 12:11:11.675 ZiGate: (ZiGate) C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Conf/PluginConf-43.json timestamp is 1629886237.270247
2021-08-25 12:11:11.675 ZiGate: (ZiGate) Dz PluginConf is older than Json Dz: 0 Json: 1629886237.270247
2021-08-25 12:11:11.675 ZiGate: (ZiGate) PluginConf Loaded from Dz: 0 from Json: 11
2021-08-25 12:11:11.675 ZiGate: (ZiGate) Starting LoggingManagement thread
2021-08-25 12:11:11.675 ZiGate: (ZiGate) start_logging_thread
2021-08-25 12:11:11.675 ZiGate: (ZiGate) logging_thread - listening
2021-08-25 12:11:11.675 ZiGate: (ZiGate) - DeviceStatus table
2021-08-25 12:11:11.675 ZiGate: (ZiGate) Database: C:\Program Files (x86)\Domoticz\domoticz.db
2021-08-25 12:11:11.675 ZiGate: (ZiGate) Debug: 2
2021-08-25 12:11:11.675 ZiGate: (ZiGate) DomoticzBuildTime: 2021-04-17 17:29:11
2021-08-25 12:11:11.675 ZiGate: (ZiGate) DomoticzHash: 8547c5b7e
2021-08-25 12:11:11.691 ZiGate: (ZiGate) DomoticzVersion: 2021.1
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Home Folder: C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Is GC enabled: True
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Opening DomoticzDB in raw
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[Address] 0.0.0.0
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[Author] zaraki673 pipiche38
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[Database] C:\Program Files (x86)\Domoticz\domoticz.db
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[DomoticzBuildTime] 2021-04-17 17:29:11
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[DomoticzHash] 8547c5b7e
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[DomoticzVersion] 2021.1
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[FirmwareUpdate] None
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[FirmwareVersion] None
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[HardwareID] 43
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[HomeFolder] C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[Key] Zigate
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[Language] en
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[Mode1] V1
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[Mode2] USB
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[Mode3] True
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[Mode4] 9440
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[Mode5]
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[Mode6] 2
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[Name] ZiGate
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[Password]
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[PluginBranch] stable5
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[PluginUpdate] None
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[PluginVersion] 5.1.006
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[Port] 9999
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[SerialPort] COM5
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[StartupFolder] C:\Program Files (x86)\Domoticz\
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[TimeStamp] 0
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[UserDataFolder] C:\Program Files (x86)\Domoticz\
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[Username]
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[Version] 5.1
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[WebRoot]
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[available-firmMajor] None
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[available-firmMinor] None
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Parameters[available] None
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Python Version - 3.8.2 (tags/v3.8.2:7b3ab59, Feb 25 2020, 22:45:29) [MSC v.1916 32 bit (Intel)]
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Startup Folder: C:\Program Files (x86)\Domoticz\
2021-08-25 12:11:11.691 ZiGate: (ZiGate) User Data Folder: C:\Program Files (x86)\Domoticz\
2021-08-25 12:11:11.691 ZiGate: (ZiGate) Web Root Folder:
2021-08-25 12:11:11.691 ZiGate: (ZiGate) - Hardware table
2021-08-25 12:11:11.691 ZiGate: (ZiGate) - Preferences table
2021-08-25 12:11:11.691 ZiGate: (ZiGate) LogLevel: 7
2021-08-25 12:11:11.721 ZiGate: (ZiGate) Plugin Database: DeviceList-43.txt
2021-08-25 12:11:11.904 ZiGate: (ZiGate) Connection open: None
2021-08-25 12:11:11.904 ZiGate: (ZiGate) Establish Zigate connection
2021-08-25 12:11:11.904 ZiGate: (ZiGate) IEEE2NWK :
2021-08-25 12:11:11.904 ZiGate: (ZiGate) IEEE2NWK after checkListOfDevice2Devices : {}
2021-08-25 12:11:11.904 ZiGate: (ZiGate) ListOfDevices :
2021-08-25 12:11:11.904 ZiGate: (ZiGate) ListOfDevices after checkListOfDevice2Devices: {}
2021-08-25 12:11:11.160 Status: ZiGate: (ZiGate) Started.
2021-08-25 12:11:11.160 Status: ZiGate: (ZiGate) Entering work loop.
2021-08-25 12:11:11.675 Status: ZiGate: (ZiGate) Initialized version 5.1, author 'zaraki673 pipiche38'
2021-08-25 12:11:11.675 Status: ZiGate: (ZiGate) filename set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Conf/PluginConf-43.json
2021-08-25 12:11:11.675 Status: ZiGate: (ZiGate) pluginHome set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\
2021-08-25 12:11:11.675 Status: ZiGate: (ZiGate) homedirectory set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\
2021-08-25 12:11:11.675 Status: ZiGate: (ZiGate) pluginData set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Data/
2021-08-25 12:11:11.675 Status: ZiGate: (ZiGate) pluginConfig set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Conf/
2021-08-25 12:11:11.675 Status: ZiGate: (ZiGate) pluginOTAFirmware set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\OTAFirmware/
2021-08-25 12:11:11.675 Status: ZiGate: (ZiGate) pluginReports set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Reports/
2021-08-25 12:11:11.675 Status: ZiGate: (ZiGate) pluginWWW set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\www/
2021-08-25 12:11:11.675 Status: ZiGate: (ZiGate) pluginLogs set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Logs/
2021-08-25 12:11:11.675 Status: ZiGate: (ZiGate) debugzigateCmd set to 1
2021-08-25 12:11:11.675 Status: ZiGate: (ZiGate) debugPlugin set to 1
2021-08-25 12:11:11.691 Status: ZiGate: (ZiGate) Zigate plugin stable5-5.1.006 started
2021-08-25 12:11:11.723 Status: ZiGate: (ZiGate) DeviceConf loaded
2021-08-25 12:11:11.888 Status: ZiGate: (ZiGate) load ListOfDevice
2021-08-25 12:11:11.904 Status: ZiGate: (ZiGate) 0 Entries loaded from C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Data/DeviceList-43.txt
2021-08-25 12:11:11.904 Status: ZiGate: (ZiGate) Transport mode: USB
2021-08-25 12:11:16.084 ZiGate: (ZiGate) send_zigatecmd_raw - [0] 0010 None Queue Length: 1
2021-08-25 12:11:16.084 ZiGate: (ZiGate) [5] PDMready: False requesting Get version
2021-08-25 12:11:21.121 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 12:11:21.121 ZiGate: (ZiGate) [10] PDMready: False requesting Get version
2021-08-25 12:11:21.121 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 12:11:26.094 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 12:11:26.094 ZiGate: (ZiGate) [15] PDMready: False requesting Get version
2021-08-25 12:11:26.094 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 12:11:31.064 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 12:11:31.064 ZiGate: (ZiGate) [20] PDMready: False requesting Get version
2021-08-25 12:11:31.064 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 12:11:36.094 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 12:11:36.094 ZiGate: (ZiGate) [25] PDMready: False requesting Get version
2021-08-25 12:11:36.094 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 12:11:41.099 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 12:11:41.099 ZiGate: (ZiGate) [30] PDMready: False requesting Get version
2021-08-25 12:11:41.099 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 12:11:46.069 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 12:11:46.069 ZiGate: (ZiGate) [35] PDMready: False requesting Get version
2021-08-25 12:11:46.069 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 12:11:51.068 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 12:11:51.068 ZiGate: (ZiGate) [40] PDMready: False requesting Get version
2021-08-25 12:11:51.068 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 12:11:56.089 ZiGate: (ZiGate) [45] PDMready: False requesting Get version
2021-08-25 12:11:56.089 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 12:12:01.084 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 12:12:01.084 ZiGate: (ZiGate) [50] PDMready: False requesting Get version
2021-08-25 12:12:01.084 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 12:12:06.109 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 12:12:06.109 ZiGate: (ZiGate) [55] PDMready: False requesting Get version
2021-08-25 12:12:06.109 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 12:12:11.086 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 12:12:11.086 ZiGate: (ZiGate) [60] PDMready: False requesting Get version
2021-08-25 12:12:11.086 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 12:12:12.125 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:12.125 Error: ZiGate: (ZiGate) [ 61] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:13.116 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:13.116 Error: ZiGate: (ZiGate) [ 62] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:14.110 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:14.110 Error: ZiGate: (ZiGate) [ 63] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:15.099 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:15.099 Error: ZiGate: (ZiGate) [ 64] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:16.096 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 12:12:16.096 ZiGate: (ZiGate) [65] PDMready: False requesting Get version
2021-08-25 12:12:16.096 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 12:12:16.096 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:16.096 Error: ZiGate: (ZiGate) [ 65] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:17.066 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:17.066 Error: ZiGate: (ZiGate) [ 66] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:18.124 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:18.124 Error: ZiGate: (ZiGate) [ 67] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:19.064 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:19.064 Error: ZiGate: (ZiGate) [ 68] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:20.066 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:20.066 Error: ZiGate: (ZiGate) [ 69] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:21.117 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 12:12:21.117 ZiGate: (ZiGate) [70] PDMready: False requesting Get version
2021-08-25 12:12:21.119 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 12:12:21.117 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:21.119 Error: ZiGate: (ZiGate) [ 70] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:22.096 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:22.096 Error: ZiGate: (ZiGate) [ 71] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:23.095 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:23.095 Error: ZiGate: (ZiGate) [ 72] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:24.095 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:24.095 Error: ZiGate: (ZiGate) [ 73] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:25.081 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:25.081 Error: ZiGate: (ZiGate) [ 74] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:26.076 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 12:12:26.076 ZiGate: (ZiGate) [75] PDMready: False requesting Get version
2021-08-25 12:12:26.076 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 12:12:26.076 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:26.076 Error: ZiGate: (ZiGate) [ 75] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:27.083 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:27.085 Error: ZiGate: (ZiGate) [ 76] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:28.084 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:28.084 Error: ZiGate: (ZiGate) [ 77] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:29.070 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:29.070 Error: ZiGate: (ZiGate) [ 78] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:30.064 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:30.068 Error: ZiGate: (ZiGate) [ 79] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:31.062 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 12:12:31.062 ZiGate: (ZiGate) [80] PDMready: False requesting Get version
2021-08-25 12:12:31.062 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 12:12:31.062 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:31.062 Error: ZiGate: (ZiGate) [ 80] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:32.124 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:32.124 Error: ZiGate: (ZiGate) [ 81] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:33.065 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:33.065 Error: ZiGate: (ZiGate) [ 82] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:34.065 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:34.065 Error: ZiGate: (ZiGate) [ 83] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:46.075 ZiGate: (ZiGate) [95] PDMready: False requesting Get version
2021-08-25 12:12:46.075 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 12:12:46.075 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:46.075 Error: ZiGate: (ZiGate) [ 95] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:47.069 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:47.069 Error: ZiGate: (ZiGate) [ 96] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:48.114 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:48.114 Error: ZiGate: (ZiGate) [ 97] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:49.102 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:49.102 Error: ZiGate: (ZiGate) [ 98] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:50.113 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:50.115 Error: ZiGate: (ZiGate) [ 99] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:51.100 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 12:12:51.100 ZiGate: (ZiGate) [100] PDMready: False requesting Get version
2021-08-25 12:12:51.107 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 12:12:51.100 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:51.104 Error: ZiGate: (ZiGate) [100] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:52.095 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:52.095 Error: ZiGate: (ZiGate) [101] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:53.095 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:53.095 Error: ZiGate: (ZiGate) [102] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:54.090 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:54.090 Error: ZiGate: (ZiGate) [103] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:55.082 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:55.082 Error: ZiGate: (ZiGate) [104] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:56.082 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 12:12:56.082 ZiGate: (ZiGate) [105] PDMready: False requesting Get version
2021-08-25 12:12:56.082 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 12:12:56.082 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:56.082 Error: ZiGate: (ZiGate) [105] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:57.066 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:57.068 Error: ZiGate: (ZiGate) [106] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:58.119 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:58.119 Error: ZiGate: (ZiGate) [107] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:12:59.062 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:12:59.062 Error: ZiGate: (ZiGate) [108] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:13:00.097 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 12:13:00.097 Error: ZiGate: (ZiGate) [109] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 12:13:01.108 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 12:13:01.108 ZiGate: (ZiGate) [110] PDMready: False requesting Get version
2021-08-25 12:13:01.108 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
Posted: Wednesday 25 August 2021 12:30
by djdehaan
pipiche wrote: Wednesday 25 August 2021 11:56
With the app I mean where you install
. Python does download and install something, but I dont know where on my drive, so I cant check access rights.
Posted: Wednesday 25 August 2021 13:30
by pipiche
From the Log, that confirm no communication, but I cannot say more than that.
there is still some strange messages here
There is most-likely something wrong happening when opening the port (either from OS perspective or an issue in the plugin).
Is Domoticz running with Admin rights ?
Can you add the following debug parameter in the file
"debugTransportRx": 1,
Posted: Wednesday 25 August 2021 13:48
by djdehaan
I added that config line and enabled the hardware, below the logging.
I expect it to run with admin rights, how can I see that? Domoticz runs at startup as a service.
2021-08-25 13:43:33.219 ZiGate hardware started.
2021-08-25 13:43:33.406 ZiGate: (ZiGate) ZiGate plugin started!
2021-08-25 13:43:33.406 ZiGate: (ZiGate) load PluginConf
2021-08-25 13:43:33.406 ZiGate: (ZiGate) C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Conf/PluginConf-43.json timestamp is 1629891690.5055785
2021-08-25 13:43:33.406 ZiGate: (ZiGate) Dz PluginConf is older than Json Dz: 0 Json: 1629891690.5055785
2021-08-25 13:43:33.406 ZiGate: (ZiGate) PluginConf Loaded from Dz: 0 from Json: 12
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Starting LoggingManagement thread
2021-08-25 13:43:33.422 ZiGate: (ZiGate) start_logging_thread
2021-08-25 13:43:33.422 ZiGate: (ZiGate) logging_thread - listening
2021-08-25 13:43:33.422 ZiGate: (ZiGate) - DeviceStatus table
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Database: C:\Program Files (x86)\Domoticz\domoticz.db
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Debug: 2
2021-08-25 13:43:33.422 ZiGate: (ZiGate) DomoticzBuildTime: 2021-04-17 17:29:11
2021-08-25 13:43:33.422 ZiGate: (ZiGate) DomoticzHash: 8547c5b7e
2021-08-25 13:43:33.422 ZiGate: (ZiGate) DomoticzVersion: 2021.1
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Home Folder: C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Is GC enabled: True
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Opening DomoticzDB in raw
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[Address] 0.0.0.0
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[Author] zaraki673 pipiche38
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[Database] C:\Program Files (x86)\Domoticz\domoticz.db
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[DomoticzBuildTime] 2021-04-17 17:29:11
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[DomoticzHash] 8547c5b7e
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[DomoticzVersion] 2021.1
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[FirmwareUpdate] None
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[FirmwareVersion] None
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[HardwareID] 43
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[HomeFolder] C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[Key] Zigate
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[Language] en
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[Mode1] V2
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[Mode2] USB
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[Mode3] True
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[Mode4] 9440
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[Mode5]
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[Mode6] 2
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[Name] ZiGate
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[Password]
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[PluginBranch] stable5
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[PluginUpdate] None
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[PluginVersion] 5.1.006
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[Port] 9999
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[SerialPort] COM5
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[StartupFolder] C:\Program Files (x86)\Domoticz\
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[TimeStamp] 0
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[UserDataFolder] C:\Program Files (x86)\Domoticz\
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[Username]
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[Version] 5.1
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[WebRoot]
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[available-firmMajor] None
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[available-firmMinor] None
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Parameters[available] None
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Python Version - 3.8.2 (tags/v3.8.2:7b3ab59, Feb 25 2020, 22:45:29) [MSC v.1916 32 bit (Intel)]
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Startup Folder: C:\Program Files (x86)\Domoticz\
2021-08-25 13:43:33.422 ZiGate: (ZiGate) User Data Folder: C:\Program Files (x86)\Domoticz\
2021-08-25 13:43:33.422 ZiGate: (ZiGate) Web Root Folder:
2021-08-25 13:43:33.422 ZiGate: (ZiGate) - Hardware table
2021-08-25 13:43:33.422 ZiGate: (ZiGate) - Preferences table
2021-08-25 13:43:33.422 ZiGate: (ZiGate) LogLevel: 7
2021-08-25 13:43:33.451 ZiGate: (ZiGate) Plugin Database: DeviceList-43.txt
2021-08-25 13:43:33.532 ZiGate: (ZiGate) Connection open: None
2021-08-25 13:43:33.532 ZiGate: (ZiGate) Establish Zigate connection
2021-08-25 13:43:33.532 ZiGate: (ZiGate) IEEE2NWK :
2021-08-25 13:43:33.532 ZiGate: (ZiGate) IEEE2NWK after checkListOfDevice2Devices : {}
2021-08-25 13:43:33.532 ZiGate: (ZiGate) ListOfDevices :
2021-08-25 13:43:33.532 ZiGate: (ZiGate) ListOfDevices after checkListOfDevice2Devices: {}
2021-08-25 13:43:33.219 Status: ZiGate: (ZiGate) Started.
2021-08-25 13:43:33.219 Status: ZiGate: (ZiGate) Entering work loop.
2021-08-25 13:43:33.406 Status: ZiGate: (ZiGate) Initialized version 5.1, author 'zaraki673 pipiche38'
2021-08-25 13:43:33.422 Status: ZiGate: (ZiGate) filename set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Conf/PluginConf-43.json
2021-08-25 13:43:33.422 Status: ZiGate: (ZiGate) pluginHome set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\
2021-08-25 13:43:33.422 Status: ZiGate: (ZiGate) homedirectory set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\
2021-08-25 13:43:33.422 Status: ZiGate: (ZiGate) pluginData set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Data/
2021-08-25 13:43:33.422 Status: ZiGate: (ZiGate) pluginConfig set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Conf/
2021-08-25 13:43:33.422 Status: ZiGate: (ZiGate) pluginOTAFirmware set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\OTAFirmware/
2021-08-25 13:43:33.422 Status: ZiGate: (ZiGate) pluginReports set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Reports/
2021-08-25 13:43:33.422 Status: ZiGate: (ZiGate) pluginWWW set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\www/
2021-08-25 13:43:33.422 Status: ZiGate: (ZiGate) pluginLogs set to C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Logs/
2021-08-25 13:43:33.422 Status: ZiGate: (ZiGate) debugzigateCmd set to 1
2021-08-25 13:43:33.422 Status: ZiGate: (ZiGate) debugTransportRx set to 1
2021-08-25 13:43:33.422 Status: ZiGate: (ZiGate) debugPlugin set to 1
2021-08-25 13:43:33.422 Status: ZiGate: (ZiGate) Zigate plugin stable5-5.1.006 started
2021-08-25 13:43:33.452 Status: ZiGate: (ZiGate) DeviceConf loaded
2021-08-25 13:43:33.516 Status: ZiGate: (ZiGate) load ListOfDevice
2021-08-25 13:43:33.532 Status: ZiGate: (ZiGate) 0 Entries loaded from C:\Program Files (x86)\Domoticz\plugins\domoticz-Zigate\Data/DeviceList-43.txt
2021-08-25 13:43:33.532 Status: ZiGate: (ZiGate) Transport mode: V2-USB
2021-08-25 13:43:38.090 ZiGate: (ZiGate) send_zigatecmd_raw - [0] 0010 None Queue Length: 1
2021-08-25 13:43:38.090 ZiGate: (ZiGate) [5] PDMready: False requesting Get version
2021-08-25 13:43:43.111 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 13:43:43.111 ZiGate: (ZiGate) [10] PDMready: False requesting Get version
2021-08-25 13:43:43.111 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 13:43:48.115 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 13:43:48.115 ZiGate: (ZiGate) [15] PDMready: False requesting Get version
2021-08-25 13:43:48.115 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 13:43:53.079 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 13:43:53.079 ZiGate: (ZiGate) [20] PDMready: False requesting Get version
2021-08-25 13:43:53.079 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 13:43:58.080 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 13:43:58.080 ZiGate: (ZiGate) [25] PDMready: False requesting Get version
2021-08-25 13:43:58.080 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 13:44:03.080 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 13:44:03.080 ZiGate: (ZiGate) [30] PDMready: False requesting Get version
2021-08-25 13:44:03.080 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 13:44:08.113 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 13:44:08.113 ZiGate: (ZiGate) [35] PDMready: False requesting Get version
2021-08-25 13:44:08.113 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 13:44:13.098 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 13:44:13.098 ZiGate: (ZiGate) [40] PDMready: False requesting Get version
2021-08-25 13:44:13.098 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 13:44:18.080 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 13:44:18.080 ZiGate: (ZiGate) [45] PDMready: False requesting Get version
2021-08-25 13:44:18.080 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 13:44:23.114 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 13:44:23.114 ZiGate: (ZiGate) [50] PDMready: False requesting Get version
2021-08-25 13:44:23.114 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 13:44:41.097 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 13:44:41.097 Error: ZiGate: (ZiGate) [ 68] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 13:44:42.088 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 13:44:42.088 Error: ZiGate: (ZiGate) [ 69] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 13:44:43.079 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 13:44:43.079 ZiGate: (ZiGate) [70] PDMready: False requesting Get version
2021-08-25 13:44:43.086 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 13:44:43.079 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 13:44:43.079 Error: ZiGate: (ZiGate) [ 70] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 13:44:50.071 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 13:44:50.071 Error: ZiGate: (ZiGate) [ 77] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 13:44:51.081 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 13:44:51.081 Error: ZiGate: (ZiGate) [ 78] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 13:44:52.081 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 13:44:52.081 Error: ZiGate: (ZiGate) [ 79] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 13:44:53.073 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 13:44:53.073 ZiGate: (ZiGate) [80] PDMready: False requesting Get version
2021-08-25 13:44:53.073 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 13:44:53.073 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 13:44:53.073 Error: ZiGate: (ZiGate) [ 80] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 13:44:54.087 Error: ZiGate: (ZiGate) [ 81] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 13:44:54.091 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 13:44:55.075 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 13:44:55.075 Error: ZiGate: (ZiGate) [ 82] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 13:44:56.065 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 13:44:56.069 Error: ZiGate: (ZiGate) [ 83] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 13:44:57.071 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 13:44:57.071 Error: ZiGate: (ZiGate) [ 84] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 13:44:58.071 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 13:44:58.071 ZiGate: (ZiGate) [85] PDMready: False requesting Get version
2021-08-25 13:44:58.071 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 13:44:58.071 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 13:44:58.071 Error: ZiGate: (ZiGate) [ 85] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 13:44:59.129 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 13:44:59.129 Error: ZiGate: (ZiGate) [ 86] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 13:45:00.115 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 13:45:00.119 Error: ZiGate: (ZiGate) [ 87] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 13:45:01.094 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 13:45:01.094 Error: ZiGate: (ZiGate) [ 88] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 13:45:02.070 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 13:45:02.070 Error: ZiGate: (ZiGate) [ 89] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-08-25 13:45:03.066 ZiGate: (ZiGate) send_zigatecmd_raw - [None] 0010 None Queue Length: 1
2021-08-25 13:45:03.066 ZiGate: (ZiGate) [90] PDMready: False requesting Get version
2021-08-25 13:45:03.066 ZiGate: (ZiGate) sendData - Warning 0010/ already in queue this command is dropped
2021-08-25 13:45:03.066 Error: ZiGate: (ZiGate) [ ] Stop the plugin and check ZiGate.
2021-08-25 13:45:03.066 Error: ZiGate: (ZiGate) [ 90] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
Posted: Wednesday 25 August 2021 14:59
by pipiche
I'm trying to setup a test bed based on Win10, but I'm not able to find the right Domoticz version with Python enabled. Can you kindly tell me where you get the Domoticz binaries ?
Posted: Wednesday 25 August 2021 15:10
pipiche wrote: Wednesday 25 August 2021 14:59
Those should be here:
https://www.domoticz.com/downloads/
For Python you will have to install it additional:
https://www.domoticz.com/wiki/Using_Python_plugins
Allways install the 32 bit Python version as Domoticz is 32 bit.
Posted: Wednesday 25 August 2021 15:11
by pipiche
So do I but do not get the plugins folder which usually the case when domoticz has not been compiled with Python framework
Posted: Wednesday 25 August 2021 15:13
Did you install Python 32bit
