Door open notification script for multiple doors
Posted: Tuesday 10 August 2021 0:39
by sciroccojc
Hello, I am trying to get a script going that will notify me when any one of my doors have been open for more than a few minutes. I found this script here
viewtopic.php?t=29250. The script works well for only a single door. I have tried many different ways to get the script to work for multiple doors but I can't seem to get it working. Any help would be appreciated. I am not getting any errors in the log, I just never get the notification.
-- *** user settings below this line **
local doorSensorName1 = 'ATS1' -- change to the name of your doorSensor'
local doorSensorName2 = 'ATS2' -- change to the name of your doorSensor'
local scriptVar = 'simpleDelayedNotification'
local secondsUntilNotification = 5
-- *** No changes required below this line **
return
devices = { doorSensorName1, doorSensorName2 },
httpResponses = { scriptVar },
local doorSensor1 = domoticz.devices(doorSensorName1)
local doorSensor2 = domoticz.devices(doorSensorName2)
local function retriggerScript(delay)
local url = domoticz.settings['Domoticz url'] ..
'/json.htm?type=command¶m=addlogmessage&message=' ..
scriptVar .. '%20retriggered'
domoticz.openURL ({ url = url, callback = scriptVar }).afterSec(delay) -- to come back after delay seconds
if item.isDevice and item.active then
retriggerScript(secondsUntilNotification) -- come back after x seconds
else -- triggered by HTTPResponse
if (item == doorSensor1 and doorSensor1.active) then
local secondsOpened = doorSensor1.lastUpdate.secondsAgo
if secondsOpened >= secondsUntilNotification then
domoticz.notify(doorSensorName1,'Still open after ' .. secondsOpened .. ' seconds.' )
elseif (item == doorSensor2 and doorSensor2.active) then
local secondsOpened = doorSensor2.lastUpdate.secondsAgo
domoticz.notify(doorSensorName2,'Still open after ' .. secondsOpened .. ' seconds.' )
I also tried this way...
return
if item == doorSensor1 then
if doorSensor1.active then
elseif item == doorSensor2 then
if doorSensor2.active then
Re: Door open notification script for multiple doors
Posted: Wednesday 11 August 2021 14:54
by StephaneM60
For me this script cannot work because when you get the http callback in the script you check if the item is one of the door sensor, but the item is the httpcallback.
so I would try this approach instead (I have not tested the code, so let met know the error message if any)
local doorSensorName1 = 'Nuki - Porte de devant Sensor' -- change to the name of your doorSensor'
local doorSensorName2 = 'Nuki - Porte Cuisine Sensor' -- change to the name of your doorSensor'
return
customEvents = { 'doorStillOpen' },
logging = {
level = domoticz.LOG_ERROR,
marker = 'DOOR NOTIFICATION',
-- door is open : check in a few seconds if it is still open
domoticz.emitEvent('doorStillOpen', item.id).afterSec(secondsUntilNotification)
-- Get the device from the event data
local deviceId = tonumber(item.data)
-- Number of seconds after last event on the sensor
local secondsOpened = domoticz.devices(deviceId).lastUpdate.secondsAgo
-- If the door is still open and has been for some time : notify
if domoticz.devices(deviceId).active and secondsOpened >= secondsUntilNotification then
domoticz.notify(domoticz.devices(deviceId).name,'Still open after ' .. secondsOpened .. ' seconds.' )
Posted: Wednesday 11 August 2021 15:38
by DutchHans
Hi, I have the script you need running for years, happy to share.
dofile ( '/home/pi/domoticz/scripts/lua/speakmodule.lua')
local function runEvery10min()
local sensor_1 = 'sensor door 1'
local sensor_2 = 'sensor door 2'
local sensor_3 = 'deur 3 sensor'
Doortext = ''
local Sensorvar = 0
if ((otherdevices[sensor_1] == 'Open')) then Sensorvar = Sensorvar + 1 end
if ((otherdevices[sensor_2] == 'Open') ) then Sensorvar = Sensorvar + 2 end
if ((otherdevices[sensor_3] ~= 'Normal') ) then Sensorvar = Sensorvar + 4 end
if Sensorvar == 0 then Message = "All doors are closed"
elseif Sensorvar == 1 then Message = "Door 1 is open"
elseif Sensorvar == 2 then Message = "Door 2 is open"
elseif Sensorvar == 3 then Message = "Door 1 and 2 are open"
elseif Sensorvar == 4 then Message = "Door 3 is open"
elseif Sensorvar == 5 then Message = "Door 1 and 3 are open"
elseif Sensorvar == 6 then Message = "Door 2 and 3 are open"
elseif Sensorvar == 7 then Message = "Door 1, 2 and 3 are open"
if (Sensorvar > 0 ) then
-- your code here
speak(Message)
local m = os.date('%M')
if (m % 10== 0) then
runEvery10min()
Posted: Wednesday 11 August 2021 21:42
by niki_lauda
DutchHans wrote: Wednesday 11 August 2021 15:38
Doortext = ''
local Sensorvar = 0
-- your code here
speak(Message)
runEvery10min()
Nice. Where can I find information on the speakmodule.lua?
Posted: Thursday 12 August 2021 2:05
by sciroccojc
Hmmnm, I can't seam to get this one working.
Posted: Thursday 12 August 2021 2:07
by sciroccojc
StephaneM60 wrote: Wednesday 11 August 2021 14:54
return
customEvent = { 'doorStillOpen' },
domoticz.emitEvent('doorStillOpen', item.idx).afterSec(secondsUntilNotification)
I ran this code but I'm getting an error.
2021-08-11 20:07:21.764 Error: dzVents: Error: (3.1.7) ...cripts/dzVents/generated_scripts/Doors Open - Test 3.lua:25: attempt to index a nil value (field 'lastUpdate')
Posted: Thursday 12 August 2021 6:54
by besix
I am using this script successfully.
You can set a different time for each door (threshold)
viewtopic.php?f=72&t=23768&p=230569#p230569
Posted: Thursday 12 August 2021 11:03
by StephaneM60
sciroccojc wrote: Thursday 12 August 2021 2:07
Ok, don't know why but the .idx wasn't returning the device ID. I fixed the script (I also had a typo for the event at the top, it was missing the "s" for customEvent
s)
Now I tested the script and it works fine (edited
my first message so you can copy the code from it)
Posted: Thursday 12 August 2021 19:10
by sciroccojc
Thank you!!! It works.
Posted: Thursday 12 August 2021 20:00
by sciroccojc
StephaneM60 wrote: Thursday 12 August 2021 11:03
s)
So, in checking further, the script is working and I am receiving the alert, but for some reason I am still getting this error in the log.
2021-08-12 13:59:21.845 Error: dzVents: Error: (3.1.7) DOOR NOTIFICATION: ...cripts/dzVents/generated_scripts/Doors Open - Test 4.lua:30: attempt to index a nil value (field 'lastUpdate')
Posted: Thursday 12 August 2021 21:11
by StephaneM60
sciroccojc wrote: Thursday 12 August 2021 20:00
If you do have this error, then the notification is not sent (as the error stop the script)
The error will occur when the event "doorStillOpen" occurs with a device ID that doesn't exist, so when it's time to check the device last update it fails because the device wasn't found (and lastUpdate is a nil value)
Let me know if you still see the error tomorrow
Posted: Monday 18 October 2021 22:28
by rrozema
StephaneM60 wrote: Thursday 12 August 2021 21:11
Most likely the error occurs when the door closes and the customevent will have processed successfully. The logic is a little bit off because you're not properly checking the conditions. Try this to see if it fixes the error message?
return
if item.isDevice then
if item.active then
elseif item.isCustomEvent then
local device = domoticz.devices(deviceId)
if nil == device then
domoticz.log( 'Device ' .. tostring(deviceId) .. ' not found.', domoticz.LOG_ERROR)
local secondsOpened = device.lastUpdate.secondsAgo
if device.active and secondsOpened >= secondsUntilNotification then
domoticz.notify(device.name,'Still open after ' .. secondsOpened .. ' seconds.' )
Posted: Thursday 25 November 2021 21:12
by Fredom
sciroccojc wrote: Tuesday 10 August 2021 0:39
return
return
Maybe this script is working for you. I have been using this for a long time and it works perfectly
--(dzVents)--
--Door open and 'Thuis' is On then no telegram
--Door open and 'Thuis' is Off then send telegram with name of the door and door is open
--Thuis is Dummy switch that is on when smartphone is at home
--Door is an Kerui D026
--Telegram is activated
local doors =
'Voordeur',
'Garagedeur',
'Schuifpui',
'Schuifdeur',
--'Schuurdeur'
--'Overkappingdeur'
--'Testdeur', --for testing (only a switch)
local allDevices = doors -- copy the doors table to table allDevices
table.insert(allDevices, 'Thuis') -- this will add this deviceName to the table allDevices
return
on =
devices = allDevices,
logging =
level = domoticz.LOG_DEBUG,
marker = 'deur',
execute = function(dz)
local allDoorsClosed = true
local Thuis = dz.devices('Thuis') --atHome
local atHome = Thuis.active
dz.log('state of Thuis is ' .. dz.devices('Thuis').state .. '; atHome is ' .. tostring(atHome), dz.LOG_DEBUG)
if atHome then
return
for _, doorName in ipairs(doors) do
local door = dz.devices(doorName)
dz.log('state of ' .. doorName .. ' is ' .. door.state .. ' (' .. ( ( door.active and 'active' ) or 'not active' ) .. ')', dz.LOG_DEBUG)
if door.state == 'Open' or door.state == 'Alarm' then -- a door is open
allDoorsClosed = false
dz.notify('Devices', 'Device ' .. doorName .. ' is geopend ')
break -- no need to look at the other doors if one is open.
