Door open notification script for multiple doors
sciroccojc
Post by sciroccojc »
Hello, I am trying to get a script going that will notify me when any one of my doors have been open for more than a few minutes. I found this script here viewtopic.php?t=29250. The script works well for only a single door. I have tried many different ways to get the script to work for multiple doors but I can't seem to get it working. Any help would be appreciated. I am not getting any errors in the log, I just never get the notification.
-- *** user settings below this line **
local doorSensorName1 = 'ATS1'  -- change to the name of your doorSensor'
local doorSensorName2 = 'ATS2'  -- change to the name of your doorSensor'
local scriptVar = 'simpleDelayedNotification'
local secondsUntilNotification = 5
-- *** No changes required below this line **
return
            devices = { doorSensorName1, doorSensorName2 },
            httpResponses = { scriptVar },
        local doorSensor1 = domoticz.devices(doorSensorName1)
        local doorSensor2 = domoticz.devices(doorSensorName2)
        local function retriggerScript(delay)
            local url = domoticz.settings['Domoticz url'] ..
                        '/json.htm?type=command&param=addlogmessage&message=' ..
                        scriptVar .. '%20retriggered'
            domoticz.openURL  ({ url = url, callback = scriptVar }).afterSec(delay)   -- to come back after delay seconds
        if item.isDevice and item.active then
                retriggerScript(secondsUntilNotification) -- come back after x seconds
        else -- triggered by HTTPResponse
            if (item == doorSensor1 and doorSensor1.active) then
                local secondsOpened = doorSensor1.lastUpdate.secondsAgo
                if secondsOpened >= secondsUntilNotification then
                    domoticz.notify(doorSensorName1,'Still open after ' .. secondsOpened .. ' seconds.' )
            elseif (item == doorSensor2 and doorSensor2.active) then
                local secondsOpened = doorSensor2.lastUpdate.secondsAgo
                    domoticz.notify(doorSensorName2,'Still open after ' .. secondsOpened .. ' seconds.' )
I also tried this way...
return
        if item == doorSensor1 then
                if doorSensor1.active then
        elseif item == doorSensor2 then
                if doorSensor2.active then
StephaneM60
Re: Door open notification script for multiple doors
Post by StephaneM60 »
For me this script cannot work because when you get the http callback in the script you check if the item is one of the door sensor, but the item is the httpcallback.
so I would try this approach instead (I have not tested the code, so let met know the error message if any)
local doorSensorName1 = 'Nuki - Porte de devant Sensor'  -- change to the name of your doorSensor'
local doorSensorName2 = 'Nuki - Porte Cuisine Sensor'  -- change to the name of your doorSensor'
return
            customEvents = { 'doorStillOpen' },
     logging = {
		level = domoticz.LOG_ERROR,
		marker = 'DOOR NOTIFICATION',
                -- door is open : check in a few seconds if it is still open
                domoticz.emitEvent('doorStillOpen', item.id).afterSec(secondsUntilNotification)
            -- Get the device from the event data
            local deviceId = tonumber(item.data)
            -- Number of seconds after last event on the sensor
            local secondsOpened = domoticz.devices(deviceId).lastUpdate.secondsAgo
            -- If the door is still open and has been for some time : notify
            if domoticz.devices(deviceId).active and secondsOpened >= secondsUntilNotification then
                domoticz.notify(domoticz.devices(deviceId).name,'Still open after ' .. secondsOpened .. ' seconds.' )
Last edited by StephaneM60 on Thursday 12 August 2021 10:59, edited 1 time in total.
DutchHans
Post by DutchHans »
Hi, I have the script you need running for years, happy to share.
dofile ( '/home/pi/domoticz/scripts/lua/speakmodule.lua')
local function runEvery10min()
   local sensor_1 = 'sensor door 1'
   local sensor_2 = 'sensor door 2'
   local sensor_3 = 'deur 3 sensor'
   Doortext = ''
local Sensorvar = 0
if ((otherdevices[sensor_1] == 'Open')) then Sensorvar = Sensorvar + 1 end
if ((otherdevices[sensor_2] == 'Open') ) then Sensorvar = Sensorvar + 2 end
if ((otherdevices[sensor_3] ~= 'Normal') ) then Sensorvar = Sensorvar + 4 end
if Sensorvar == 0 then Message = "All doors are closed"
elseif Sensorvar == 1 then Message  = "Door 1 is open"
elseif Sensorvar == 2 then Message = "Door 2 is open"
elseif Sensorvar == 3 then Message = "Door 1 and 2 are open"
elseif Sensorvar == 4 then Message = "Door 3 is open"
elseif Sensorvar == 5 then Message = "Door 1 and 3 are open"
elseif Sensorvar == 6 then Message = "Door 2 and 3 are open"
elseif Sensorvar == 7 then Message = "Door 1, 2 and 3 are open"
  if (Sensorvar > 0 ) then
  -- your code here
   speak(Message)
local m = os.date('%M')
if (m % 10== 0) then
   runEvery10min()
niki_lauda
Post by niki_lauda »
DutchHans wrote: Wednesday 11 August 2021 15:38 Hi, I have the script you need running for years, happy to share.
   Doortext = ''
local Sensorvar = 0
  -- your code here
   speak(Message)
   runEvery10min()
Nice. Where can I find information on the speakmodule.lua?
sciroccojc
Hmmnm, I can't seam to get this one working.
sciroccojc
StephaneM60 wrote: Wednesday 11 August 2021 14:54 Hi,
return
            customEvent = { 'doorStillOpen' },
                domoticz.emitEvent('doorStillOpen', item.idx).afterSec(secondsUntilNotification)
I ran this code but I'm getting an error.
2021-08-11 20:07:21.764 Error: dzVents: Error: (3.1.7) ...cripts/dzVents/generated_scripts/Doors Open - Test 3.lua:25: attempt to index a nil value (field 'lastUpdate')
besix
Post by besix »
I am using this script successfully.
You can set a different time for each door (threshold)
viewtopic.php?f=72&t=23768&p=230569#p230569
StephaneM60
sciroccojc wrote: Thursday 12 August 2021 2:07
Ok, don't know why but the .idx wasn't returning the device ID. I fixed the script (I also had a typo for the event at the top, it was missing the "s" for customEvents)
Now I tested the script and it works fine (edited my first message so you can copy the code from it)
sciroccojc
Thank you!!! It works.
sciroccojc
StephaneM60 wrote: Thursday 12 August 2021 11:03
So, in checking further, the script is working and I am receiving the alert, but for some reason I am still getting this error in the log.
2021-08-12 13:59:21.845 Error: dzVents: Error: (3.1.7) DOOR NOTIFICATION: ...cripts/dzVents/generated_scripts/Doors Open - Test 4.lua:30: attempt to index a nil value (field 'lastUpdate')
StephaneM60
sciroccojc wrote: Thursday 12 August 2021 20:00 So, in checking further, the script is working and I am receiving the alert, but for some reason I am still getting this error in the log.
If you do have this error, then the notification is not sent (as the error stop the script)
The error will occur when the event "doorStillOpen" occurs with a device ID that doesn't exist, so when it's time to check the device last update it fails because the device wasn't found (and lastUpdate is a nil value)
Let me know if you still see the error tomorrow
rrozema
Post by rrozema »
StephaneM60 wrote: Thursday 12 August 2021 21:11
Most likely the error occurs when the door closes and the customevent will have processed successfully. The logic is a little bit off because you're not properly checking the conditions. Try this to see if it fixes the error message?
return
        if item.isDevice then
            if item.active then
        elseif item.isCustomEvent then
            local device = domoticz.devices(deviceId)
            if nil == device then
                domoticz.log( 'Device ' .. tostring(deviceId) .. ' not found.', domoticz.LOG_ERROR)
                local secondsOpened = device.lastUpdate.secondsAgo
                if device.active and secondsOpened >= secondsUntilNotification then
                    domoticz.notify(device.name,'Still open after ' .. secondsOpened .. ' seconds.' )
Fredom
Domoticz version: 2025.1
Post by Fredom »
sciroccojc wrote: Tuesday 10 August 2021 0:39 Hello, I am trying to get a script going that will notify me when any one of my doors have been open for more than a few minutes. I found this script here viewtopic.php?t=29250. The script works well for only a single door. I have tried many different ways to get the script to work for multiple doors but I can't seem to get it working. Any help would be appreciated. I am not getting any errors in the log, I just never get the notification.
return
return
Maybe this script is working for you. I have been using this for a long time and it works perfectly
--(dzVents)--
--Door open  and 'Thuis' is On then no telegram
--Door open  and 'Thuis' is Off then send telegram with name of the door and door is open
--Thuis is Dummy switch that is on when smartphone is at home
--Door is an Kerui D026
--Telegram is activated
local doors =
    'Voordeur',
    'Garagedeur',
    'Schuifpui',
    'Schuifdeur',
    --'Schuurdeur'
    --'Overkappingdeur'
    --'Testdeur',  --for testing (only a switch)
local allDevices = doors            -- copy the doors table to table allDevices
table.insert(allDevices, 'Thuis')   -- this will add this deviceName to the table allDevices
return
    on =
        devices = allDevices,
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'deur',
    execute = function(dz)
        local allDoorsClosed = true
        local  Thuis = dz.devices('Thuis') --atHome
        local atHome = Thuis.active
        dz.log('state of Thuis is ' .. dz.devices('Thuis').state .. '; atHome is ' .. tostring(atHome), dz.LOG_DEBUG)
        if atHome then
            return
            for _, doorName in ipairs(doors) do
                local door = dz.devices(doorName)
                dz.log('state of ' .. doorName .. ' is ' .. door.state .. ' (' .. ( ( door.active and 'active' ) or 'not active' ) .. ')', dz.LOG_DEBUG)
                if door.state == 'Open' or door.state == 'Alarm' then -- a door is open
                    allDoorsClosed = false
                    dz.notify('Devices', 'Device ' .. doorName .. ' is geopend ')
                    break -- no need to look at the other doors if one is open.
Yours sincerely,
Fred
Rasberry Pi 3B+ - Debian Trixie - Domoticz 2025.2
RFLink - RFXCom - Zigbee (CC2531)
P1 Smart Meter - KaKu
