Zigbee2mqtt/CC2652R problem
Sarcas
Domoticz version: 2022.1ß
Post by Sarcas »
I bought a ZZH! stick and flashed it according to the instructions from the Electrolama website. I used the TI flash utility and the latest firmware CC2652R_coordinator_20210708.hex. The utility reported a successful flash. The next step is connecting it to my rPi, checking which port it uses and " edit your Zigbee2mqtt configuration.yam". But the stick seems dead after putting it in the rPi4. I rebooted it, updatet it, but
ls -l /dev/serial/by-id
just gives
total 0
lrwxrwxrwx 1 root root 13 Aug  8 16:03 usb-0658_0200-if00 -> ../../ttyACM0
lrwxrwxrwx 1 root root 13 Aug  8 16:03 usb-1a86_USB_Serial-if00-port0 -> ../../ttyUSB1
lrwxrwxrwx 1 root root 13 Aug  8 16:03 usb-RFXCOM_RFXtrx433_A129KUAH-if00-port0 -> ../../ttyUSB0
I flashed it again to be sure i did everything correctly, but no changes. I have no idea how to proceed.
Anyone?
Thanks,
S.
Domoticz on rPi4 - RFXCOM RFXtrx433 USB - ZW090 Z-Stick Gen5 EU - IKEA Tradfri - Philips HUE - YouLess meter - SolarEdge
heggink
Domoticz version: 12451
Re: Zigbee2mqtt/CC2652R problem
Post by heggink »
I also have the zzh stick which runs fine. Not at home atm but will try to help later.
P1 meter & solar panel
EddyG
Post by EddyG »
Unplug and plugin again and see what the last line are from
dmesg
You can see if the stick is recognized and what the port is.
heggink
Post by heggink »
Correct. dmesg is your first check.
You can also check what devices are connected with lsusb (or lsusb -v for verbose)
HansOtten
Domoticz version: 2021-1
Post by HansOtten »
If The TI utility works, then the stick is allright.
But check it again in Windows Device manager and confirm it is a 340 with usb id's 1a86 7523
Then power down your Pi (plug and play is not always a success in Linux!) , insert the stick check, power up
and check with:
lsusb
you should see at least something like
Bus 001 Device 003: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
The 340 serial USB adapter is supported in current Raspberry Pi OS. What version are you running? If older you might have to install the 340 driver.
Or use another USB port and try again, there are 4. Power down and up to be sure.
Raspberry Pi 4, SSD, RFlink, P1 Smart Meter. Many Zigbee devices CR2562 USB stick. Bresser via Weather Underground
Switched to Home Assistant!
Sarcas
Post by Sarcas »
EddyG wrote: Sunday 08 August 2021 18:08 Unplug and plugin again and see what the last line are from
dmesg
Unplugging and plugging-in kills the rPi4:
pi@raspberrypi4:~ $ dmesg
-bash: /usr/bin/dmesg: Input/output error
pi@raspberrypi4:~ $ sudo reboot
-bash: sudo: command not found
pi@raspberrypi4:~ $
i have to cut the power to get it to reboot.
then I get
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.52-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1441 SMP Tue Aug 3 18:11:56 BST 2021
[    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
[    0.000000] random: fast init done
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
[    0.000000]   Normal   empty
[    0.000000]   HighMem  [mem 0x0000000030000000-0x00000001ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000003befffff]
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
[    0.000000] On node 0 totalpages: 2064128
[    0.000000]   DMA zone: 1728 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 196608 pages, LIFO batch:63
[    0.000000]   HighMem zone: 1867520 pages, LIFO batch:63
[    0.000000] percpu: Embedded 20 pages/cpu s50764 r8192 d22964 u81920
[    0.000000] pcpu-alloc: s50764 r8192 d22964 u81920 alloc=20*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2062400
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:0F:26:DC vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=1d7c7a13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] Kernel parameter elevator= does not have any effect anymore.
               Please use sysfs to set IO scheduler for individual devices.
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x0000000012400000-0x0000000016400000] (64MB)
[    0.000000] Memory: 7769728K/8256512K available (10240K kernel code, 1364K rwdata, 3188K rodata, 2048K init, 891K bss, 159104K reserved, 327680K cma-reserved, 7470080K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 34303 entries in 67 pages
[    0.000000] ftrace: allocated 67 pages with 3 groups
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=1
[    0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[    0.000035] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    0.000099] bcm2835: system timer (irq = 25)
[    0.000748] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000770] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000792] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000810] Switching to timer-based delay loop, resolution 18ns
[    0.001068] Console: colour dummy device 80x30
[    0.001838] printk: console [tty1] enabled
[    0.001904] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[    0.001959] pid_max: default: 32768 minimum: 301
[    0.002137] LSM: Security Framework initializing
[    0.002338] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.002383] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.003857] cgroup: Disabling memory control group subsystem
[    0.004105] CPU: Testing write buffer coherency: ok
[    0.004582] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005825] Setting up static identity map for 0x200000 - 0x20003c
[    0.006042] rcu: Hierarchical SRCU implementation.
[    0.006994] smp: Bringing up secondary CPUs ...
[    0.008211] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.009579] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.010967] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.011126] smp: Brought up 1 node, 4 CPUs
[    0.011173] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[    0.011203] CPU: All CPU(s) started in HYP mode.
[    0.011230] CPU: Virtualization extensions available.
[    0.012101] devtmpfs: initialized
[    0.026252] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[    0.026507] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.026560] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.034613] pinctrl core: initialized pinctrl subsystem
[    0.035711] NET: Registered protocol family 16
[    0.039603] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.040392] audit: initializing netlink subsys (disabled)
[    0.040668] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[    0.041290] thermal_sys: Registered thermal governor 'step_wise'
[    0.041987] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.042042] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.042448] Serial: AMBA PL011 UART driver
[    0.074528] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[    0.090887] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-08-03T18:14:56, variant start
[    0.100899] raspberrypi-firmware soc:firmware: Firmware hash is 40787ee5905644f639a2a0f6e00ae12e517a2211
[    0.141751] Kprobes globally optimized
[    0.146943] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[    0.151065] vgaarb: loaded
[    0.151544] SCSI subsystem initialized
[    0.151772] usbcore: registered new interface driver usbfs
[    0.151875] usbcore: registered new interface driver hub
[    0.151964] usbcore: registered new device driver usb
[    0.152313] usb_phy_generic phy: supply vcc not found, using dummy regulator
[    0.154229] clocksource: Switched to clocksource arch_sys_counter
[    1.112763] VFS: Disk quotas dquot_6.6.0
[    1.112880] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.113057] FS-Cache: Loaded
[    1.113282] CacheFiles: Loaded
[    1.123400] NET: Registered protocol family 2
[    1.123660] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    1.125195] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.125354] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    1.125440] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.125534] TCP: Hash tables configured (established 8192 bind 8192)
[    1.125712] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.125768] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.126049] NET: Registered protocol family 1
[    1.126788] RPC: Registered named UNIX socket transport module.
[    1.126821] RPC: Registered udp transport module.
[    1.126850] RPC: Registered tcp transport module.
[    1.126877] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.126914] PCI: CLS 0 bytes, default 64
[    1.129823] Initialise system trusted keyrings
[    1.130075] workingset: timestamp_bits=14 max_order=21 bucket_order=7
[    1.138450] zbud: loaded
[    1.140602] FS-Cache: Netfs 'nfs' registered for caching
[    1.141361] NFS: Registering the id_resolver key type
[    1.141415] Key type id_resolver registered
[    1.141443] Key type id_legacy registered
[    1.141605] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.141638] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.142697] Key type asymmetric registered
[    1.142729] Asymmetric key parser 'x509' registered
[    1.142936] bounce: pool size: 64 pages
[    1.142997] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    1.143239] io scheduler mq-deadline registered
[    1.143270] io scheduler kyber registered
[    1.147719] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[    1.147774] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[    1.147876] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[    1.147986] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
[    1.216332] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[    1.216731] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[    1.216768] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.216804] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[    1.216916] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[    1.217175] pci 0000:00:00.0: PME# supported from D0 D3hot
[    1.220664] PCI: bus0: Fast back to back transfers disabled
[    1.220704] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    1.221015] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[    1.221103] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    1.221380] pci 0000:01:00.0: PME# supported from D0 D3hot
[    1.224746] PCI: bus1: Fast back to back transfers disabled
[    1.224783] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    1.224840] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[    1.224879] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[    1.224941] pci 0000:00:00.0: PCI bridge to [bus 01]
[    1.224980] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
[    1.225400] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[    1.225659] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
[    1.234082] iproc-rng200 fe104000.rng: hwrng registered
[    1.234494] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
[    1.235379] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[    1.247558] brd: module loaded
[    1.259790] loop: module loaded
[    1.261567] Loading iSCSI transport class v2.0-870.
[    1.264860] libphy: Fixed MDIO Bus: probed
[    1.266554] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[    1.284307] libphy: bcmgenet MII bus: probed
[    1.374379] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[    1.375568] usbcore: registered new interface driver r8152
[    1.375655] usbcore: registered new interface driver lan78xx
[    1.375732] usbcore: registered new interface driver smsc95xx
[    1.423240] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    1.423294] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[    1.426583] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000060000000890
[    1.427929] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    1.427971] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.428007] usb usb1: Product: xHCI Host Controller
[    1.428038] usb usb1: Manufacturer: Linux 5.10.52-v7l+ xhci-hcd
[    1.428069] usb usb1: SerialNumber: 0000:01:00.0
[    1.428816] hub 1-0:1.0: USB hub found
[    1.428929] hub 1-0:1.0: 1 port detected
[    1.429615] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    1.429659] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[    1.429704] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[    1.430217] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    1.430256] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.430292] usb usb2: Product: xHCI Host Controller
[    1.430322] usb usb2: Manufacturer: Linux 5.10.52-v7l+ xhci-hcd
[    1.430353] usb usb2: SerialNumber: 0000:01:00.0
[    1.431087] hub 2-0:1.0: USB hub found
[    1.431173] hub 2-0:1.0: 4 ports detected
[    1.432835] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.433154] dwc_otg: FIQ enabled
[    1.433170] dwc_otg: NAK holdoff enabled
[    1.433184] dwc_otg: FIQ split-transaction FSM enabled
[    1.433202] Module dwc_common_port init
[    1.433669] usbcore: registered new interface driver uas
[    1.433797] usbcore: registered new interface driver usb-storage
[    1.434019] mousedev: PS/2 mouse device common for all mice
[    1.435718] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    1.439080] sdhci: Secure Digital Host Controller Interface driver
[    1.439115] sdhci: Copyright(c) Pierre Ossman
[    1.439844] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[    1.440474] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.444604] ledtrig-cpu: registered to indicate activity on CPUs
[    1.444972] hid: raw HID events driver (C) Jiri Kosina
[    1.445200] usbcore: registered new interface driver usbhid
[    1.445231] usbhid: USB HID core driver
[    1.451017] Initializing XFRM netlink socket
[    1.451079] NET: Registered protocol family 17
[    1.451241] Key type dns_resolver registered
[    1.451614] Registering SWP/SWPB emulation handler
[    1.451792] registered taskstats version 1
[    1.451833] Loading compiled-in X.509 certificates
[    1.452709] Key type ._fscrypt registered
[    1.452740] Key type .fscrypt registered
[    1.452768] Key type fscrypt-provisioning registered
[    1.465855] uart-pl011 fe201000.serial: there is not valid maps for state default
[    1.466187] uart-pl011 fe201000.serial: cts_event_workaround enabled
[    1.466292] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[    1.473084] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    1.474192] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    1.474265] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[    1.504564] of_cfs_init
[    1.504839] of_cfs_init: OK
[    1.526247] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.527955] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.529657] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.532689] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.534843] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.542452] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[    1.543138] Waiting for root device PARTUUID=1d7c7a13-02...
[    1.604639] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[    1.604747] mmc1: new high speed SDIO card at address 0001
[    1.636262] usb 2-1: New USB device found, idVendor=0781, idProduct=5581, bcdDevice= 1.00
[    1.636317] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.636351] usb 2-1: Product: Ultra
[    1.636380] usb 2-1: Manufacturer: SanDisk
[    1.636410] usb 2-1: SerialNumber: 4C530001210817114480
[    1.640686] usb-storage 2-1:1.0: USB Mass Storage device detected
[    1.641551] scsi host0: usb-storage 2-1:1.0
[    1.784272] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[    1.966901] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[    1.966943] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.966976] usb 1-1: Product: USB2.0 Hub
[    1.968697] hub 1-1:1.0: USB hub found
[    1.969007] hub 1-1:1.0: 4 ports detected
[    2.294269] usb 1-1.2: new full-speed USB device number 3 using xhci_hcd
[    2.430469] usb 1-1.2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[    2.430510] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    2.430547] usb 1-1.2: Product: USB Serial
[    2.534269] usb 1-1.3: new high-speed USB device number 4 using xhci_hcd
[    2.664867] usb 1-1.3: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[    2.664908] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.664944] usb 1-1.3: Product: USB 2.0 Hub
[    2.666695] hub 1-1.3:1.0: USB hub found
[    2.666860] hub 1-1.3:1.0: 4 ports detected
[    2.715445] scsi 0:0:0:0: Direct-Access     SanDisk  Ultra            1.00 PQ: 0 ANSI: 6
[    2.716923] sd 0:0:0:0: [sda] 60063744 512-byte logical blocks: (30.8 GB/28.6 GiB)
[    2.718603] sd 0:0:0:0: [sda] Write Protect is off
[    2.718639] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[    2.719364] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    2.723991]  sda: sda1 sda2
[    2.727655] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    2.742645] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
[    2.742685] EXT4-fs (sda2): write access will be enabled during recovery
[    2.764278] usb 1-1.4: new full-speed USB device number 5 using xhci_hcd
[    2.911523] usb 1-1.4: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
[    2.911573] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.911611] usb 1-1.4: Product: RFXtrx433
[    2.911641] usb 1-1.4: Manufacturer: RFXCOM
[    2.911670] usb 1-1.4: SerialNumber: A129KUAH
[    3.059495] EXT4-fs (sda2): recovery complete
[    3.065819] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[    3.065916] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
[    3.067722] devtmpfs: mounted
[    3.076665] Freeing unused kernel memory: 2048K
[    3.077005] Run /sbin/init as init process
[    3.077033]   with arguments:
[    3.077048]     /sbin/init
[    3.077062]   with environment:
[    3.077076]     HOME=/
[    3.077090]     TERM=linux
[    3.094278] usb 1-1.3.4: new full-speed USB device number 6 using xhci_hcd
[    3.331598] usb 1-1.3.4: New USB device found, idVendor=0658, idProduct=0200, bcdDevice= 0.00
[    3.331649] usb 1-1.3.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.436776] systemd[1]: System time before build time, advancing clock.
[    3.538765] NET: Registered protocol family 10
[    3.540162] Segment Routing with IPv6
[    3.605463] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    3.606689] systemd[1]: Detected architecture arm.
[    3.664778] systemd[1]: Set hostname to <raspberrypi4>.
[    4.340289] systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
[    4.388597] systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
[    4.511215] random: systemd: uninitialized urandom read (16 bytes read)
[    4.527069] random: systemd: uninitialized urandom read (16 bytes read)
[    4.527860] systemd[1]: Listening on udev Kernel Socket.
[    4.528513] random: systemd: uninitialized urandom read (16 bytes read)
[    4.529157] systemd[1]: Listening on fsck to fsckd communication Socket.
[    4.529915] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.530646] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    4.531675] systemd[1]: Listening on Syslog Socket.
[    4.717742] i2c /dev entries driver
[    5.174471] EXT4-fs (sda2): re-mounted. Opts: (null)
[    5.296180] systemd-journald[116]: Received request to flush runtime journal from PID 1
[    5.935555] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[    5.936166] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[    5.936736] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[    5.937317] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[    6.036359] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    6.048590] mc: Linux media interface: v0.10
[    6.059308] bcm2835_audio bcm2835_audio: card created with 8 channels
[    6.078157] videodev: Linux video capture interface: v2.00
[    6.092864] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    6.095978] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    6.096016] [vc_sm_connected_init]: start
[    6.098036] [vc_sm_connected_init]: installed successfully
[    6.166365] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    6.176451] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    6.201505] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    6.202340] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[    6.222818] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    6.232711] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    6.232767] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    6.233186] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[    6.233831] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[    6.235168] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[    6.235625] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[    6.235657] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    6.235681] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    6.235711] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    6.235743] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    6.236005] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[    6.250574] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    6.250619] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    6.269467] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    6.269515] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    6.433937] usbcore: registered new interface driver usbserial_generic
[    6.434021] usbserial: USB Serial support registered for generic
[    6.439792] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    6.488469] usbcore: registered new interface driver ftdi_sio
[    6.488556] usbserial: USB Serial support registered for FTDI USB Serial Device
[    6.488918] ftdi_sio 1-1.4:1.0: FTDI USB Serial Device converter detected
[    6.489121] usb 1-1.4: Detected FT232RL
[    6.528432] usb 1-1.4: FTDI USB Serial Device converter now attached to ttyUSB0
[    6.590902] usbcore: registered new interface driver ch341
[    6.590990] usbserial: USB Serial support registered for ch341-uart
[    6.591106] ch341 1-1.2:1.0: ch341-uart converter detected
[    6.591380] [drm] No displays found. Consider forcing hotplug if HDMI is attached
[    6.591514] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[    6.591978] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[    6.601393] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    6.611057] usb 1-1.2: ch341-uart converter now attached to ttyUSB1
[    6.622586] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    6.624402] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[    6.742086] cdc_acm 1-1.3.4:1.0: ttyACM0: USB ACM device
[    6.745150] brcmfmac: F1 signature read @0x18000000=0x15264345
[    6.754851] usbcore: registered new interface driver cdc_acm
[    6.754869] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    6.823863] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    6.827402] usbcore: registered new interface driver brcmfmac
[    7.083445] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    7.083575] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    7.094885] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[    7.646686] random: crng init done
[    7.646706] random: 7 urandom warning(s) missed due to ratelimiting
[    9.242008] 8021q: 802.1Q VLAN Support v1.8
[    9.432141] uart-pl011 fe201000.serial: no DMA platform data
[    9.774335] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
[    9.845269] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[   10.236078] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[   10.236579] bcmgenet fd580000.ethernet eth0: Link is Down
[   15.409300] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   16.224794] Bluetooth: Core ver 2.22
[   16.224902] NET: Registered protocol family 31
[   16.224919] Bluetooth: HCI device and connection manager initialized
[   16.224948] Bluetooth: HCI socket layer initialized
[   16.224971] Bluetooth: L2CAP socket layer initialized
[   16.225010] Bluetooth: SCO socket layer initialized
[   16.236174] Bluetooth: HCI UART driver ver 2.3
[   16.236197] Bluetooth: HCI UART protocol H4 registered
[   16.236299] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   16.236619] Bluetooth: HCI UART protocol Broadcom registered
[   16.577157] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   16.577176] Bluetooth: BNEP filters: protocol multicast
[   16.577204] Bluetooth: BNEP socket layer initialized
[   22.492067] FS-Cache: Netfs 'cifs' registered for caching
[   22.524346] Key type cifs.spnego registered
[   22.524389] Key type cifs.idmap registered
[   22.526543] CIFS: Attempting to mount //192.168.8.100/RasPiBackup
[   22.526641] CIFS: No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3.1.1), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3.1.1 (or even SMB3 or SMB2.1) specify vers=1.0 on mount.
Is this what i am looking for?
Sarcas
Post by Sarcas »
HansOtten wrote: Monday 09 August 2021 11:03 If The TI utility works, then the stick is allright.
and check with:
lsusb
Ha, I see that one!
pi@raspberrypi4:~ $ lsusb
Bus 002 Device 002: ID 0781:5581 SanDisk Corp. Ultra
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
Bus 001 Device 006: ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB
Bus 001 Device 004: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Sarcas
Post by Sarcas »
After editing my
configuration.yaml
with the correct data found above, I finally could execute
npm ci --production
without errors. Time for the next steps :)
Thanks all!
S.
EddyG
Post by EddyG »
And now make your device(s) persistent, otherwise they might get an other port assigned at the next reboot.
https://www.domoticz.com/wiki/PersistentUSBDevices
