Eve-Single Pro-line Car Charging Station
rolandbreedveld
Domoticz version: 2021.1
Post by rolandbreedveld »
Hi All
Does someone have experience with an "Eve-Single Pro-line" Car Charging Station from Alfen, connected to Domoticz ?
Mine is connected with Eneco, by mobile network, it has internal a SIM.
The device does also have a Network connector.
regards, Roland
Raspberry Pi(SSD)+UPS HAT,Dashticz on WallTablet,HomeBridge, P1, HarmonyHub,FritzBox,API to 123Solar+ABB-PowerOne+SMA,ESP-Leds(flashed LSC),Tasmota,Shelly,MQTT,Mosquito,Node-Red,http://wiki.breedveld.net/index.php?title=RPiWaterMeter, Mercedes-Me
jeroenkl
Re: Eve-Single Pro-line Car Charging Station
Post by jeroenkl »
rolandbreedveld wrote: Sunday 08 August 2021 12:56 Hi All
regards, Roland
Same situation, any update and result Ronald?
Domoticz version: 2025.1
This charger should be compatible with the OCCP protocol and so compatible with the OCCP python library: https://github.com/mobilityhouse/ocpp
FireWizard
Post by FireWizard »
You may want to take a look at: https://flows.nodered.org/node/node-red-contrib-ocpp
If you are able to establish the communication it is easy to send the data to Domoticz.
