Many devices have a log display that shows the values for the last 24 hours. This display can be set to 3 days, 1 day, 3 hours and 1 hour. This all works fine, except the 3 days display. This sticks to 24 hours, just like the 1 day setting.
What am I doing wrong?
Multi-day log display Topic is solved
- JackD
Re: Multi-day log display
You can not get more data in the log display than you set under the "settings tab=>log history"
If your settings are 1 day you can not get 3 days in you log display, you have to adjust first to set 3 days under the "settings tab=>log history"
My "settings tab=> log history" is set to 2 days, so if I push the 3 day button tab I only get 2 day's in de log display.
Not the behavior you would expect, but this is how It now seems to work.......
sciurius
- Domoticz version: 2021.1
Ah. That's why the top line always reads "Last 24 hours".
