Xiaomi zigbee temperature, humidity and pressure sensor update rate
Posted: Wednesday 21 July 2021 12:42
Xiaomi aquara zigbee sensor temperature, humidity and pressure WSDCGQ11LM connected through the DGNWG02LM hub. The domoticz updates the data once an hour. At the same time, the sensor itself measures much more often, which can be seen in Mi Home. The hub, therefore, can also transmit information more often. But how do you get it to domoticz? I wanted to use this sensor for automatic fan control, but once an hour is not good enough.
