Xiaomi zigbee temperature, humidity and pressure sensor update rate
askold
Xiaomi aquara zigbee sensor temperature, humidity and pressure WSDCGQ11LM connected through the DGNWG02LM hub. The domoticz updates the data once an hour. At the same time, the sensor itself measures much more often, which can be seen in Mi Home. The hub, therefore, can also transmit information more often. But how do you get it to domoticz? I wanted to use this sensor for automatic fan control, but once an hour is not good enough.
- Domoticz version: 2025.1
Re: Xiaomi zigbee temperature, humidity and pressure sensor update rate
I have no gateway but these battery powered sensors send data only when something has changed significantly.
Why the Xiaomi Gateway is not passing them through to Domoticz I have no idea.
Please check this large topic abaout the implementation and perhaps ask your question there too as there are more Gateway users get notified.
https://domoticz.com/forum/viewtopic.php?f=68&t=11520
askold
Judging by the domoticz logs, Gateway is transmitting data. I see lines like this in the log:waltervl wrote: Wednesday 21 July 2021 13:29 IWhy the Xiaomi Gateway is not passing them through to Domoticz I have no idea.
2021-07-22 00:50:05.968 XGW: Temp (Xiaomi Temperature)
2021-07-22 00:50:05.987 XGW: Humidity (Влажность)
2021-07-22 00:51:00.681 XGW: Light/Switch (Xiaomi Gateway Alarm Clock)
2021-07-22 00:51:06.687 XGW: Temp (Xiaomi Temperature)
2021-07-22 00:51:06.705 XGW: Humidity (Влажность)
2021-07-22 00:51:27.064 XGW: Temp (Xiaomi Temperature)
2021-07-22 00:51:27.081 XGW: Humidity (Влажность)
2021-07-22 00:52:00.677 XGW: Light/Switch (Xiaomi Gateway Alarm Clock)
2021-07-22 00:52:17.646 XGW: Temp (Xiaomi Temperature)
2021-07-22 00:52:17.664 XGW: Humidity (Влажность)
But devicechanged and otherdevices are updated only once an hour, just like the graphs in domoticz.
