cheking for git
fillister
cheking for git
hello,
I've been trying to reload Domoticz on my PI 3 rev B, the Domoticz has been operating on this PI for years but recently crashed and I have to reload. I have set the PI to boot from usb Flash drive but when I run curl -L https://install.domoticz.com | bash SSH the system stops at checking for git...pi@raspberrypi:~ $
It just sits and does not complete the installation, any help will be greatly appreciated.
Dave21w
- Domoticz version: Stable
Re: cheking for git
Maybe permissions, are you logged in as root or using sudo ?
fillister
Re: cheking for git
Yes, actually used "sudo curl -L https://install.domoticz.com | bash SSH" I've even tried multiple flash drives with the same results.
- Domoticz version: 2026.3
Re: cheking for git
You have to use 'curl -sSL install.domoticz.com | sudo bash' from within a ssh session (if you use ssh to access your RPi)
Else just logon to your Pi, start a terminal session and run 'curl -sSL install.domoticz.com | sudo bash'
fillister
Re: cheking for git
Waltervl
I have tried 'curl -sSL install.domoticz.com | sudo bash' multiple times with the same results. I even checked and SHA hash to verify that the raspian lite image is correct.
Re: cheking for git
Did you do an raspian update before installing?
sudo apt update
sudo apt upgrade
sudo apt update
sudo apt upgrade
fillister
Re: cheking for git
Yes, it replied with broken pipe when I ran the upgrade command, could not get it to fully install the upgrade. I just used pi imager to re flash the usb and am in the process of rebooting the PI. After I set the timezone and expand the file system I'll retry the sudo apt update and the sudo apt upgrade commands.
fillister
Re: cheking for git
All,
It appears as though all of the problems resulted from setting the PI 3 rev B to use the usb instead of the SD to boot. Even though the commands to add the usb as a mass storage device went smoothly and no errors occurred it would take at least an hour to receive an dhcp address and several hours to expand the file system. I had a PI 4 delivered yesterday, it immediately booted off of the usb and I had Domoticz loaded within 5 minuets.
Thank you for your help
