3 position switch with a bathroom fan
Posted: Wednesday 14 July 2021 20:42
by jochem25
I want to switch my bathroom fan remotely (and intelligent) with domoticz. So i thought about buying a kaku ACM-3500-2 switch and an aeotec multisensor. The fan had also 3 wires / positions, but I am reading in the manual that I can put only at 1 port at a time 230v.
I am a bit afraid that when an off signal from rfxcom433 is not recieved by the kaku switch that there is power on two wires, what will damage the fan.
does anybody know a good solution for this?
Re: 3 position switch with a bathroom fan
Posted: Friday 16 July 2021 23:23
by Ron
Maybe you can use a blinds switch (rolluik schakelaar).
This kind of switche only connect contact one or two, never two at the same time.
Posted: Monday 19 July 2021 16:53
by jochem25
good idea, thanks!
Posted: Monday 19 July 2021 17:17
by Treve
jochem25 wrote:Hi,
Do you have a Itho fan? If yes, is hi-low not enough?
In my case it’s sufficient.
Posted: Monday 19 July 2021 17:29
by jochem25
I have a Ruck tube fan for my bathroom.
hi-low is enough, I don`t need three positions
Posted: Monday 19 July 2021 19:46
by Treve
Now you have to know how the fan electrical works before you can manage a solution.
Posted: Tuesday 20 July 2021 8:46
by jochem25
the electrical scheme is quit simpel:
- Capture.JPG (19.39 KiB) Viewed 855 times
it doesn`t need a pwm.
With the blinds switch it will work. I need only 1 and 3
Posted: Tuesday 20 July 2021 10:01
by Treve
- Switch-relais.jpg (20.45 KiB) Viewed 847 times
I think the simplest solution is to use a cheap Zigbee or more expensive Z-Wave switch that drives a normal 220 volt relay with changeover contact.
