I am asking for advice how to solve this.
I have two switches. One is active during daylight, second gets active (ON) when I come home and it's stays ON till I leave home.
I would like to trigger action (turn on light) when first switch is OFF (night) and when second switch goes to ON state (I come home).
Blockly: if switch 1 is OFF AND if switch 2 is ON, THAN turn on the light.
This works fine if I come at night.
The problem I would like to solve, that if I am already at home and first switch change it's state when day goes to night. This triggers this action too and I do not like that. Has anyone any idea how to solve this?
Summary: how to ignore when specific switch is changing its state and still have working AND condition when other switch changes state.
thank you for ideas and best regards.
Blockly triggering condition
AllesVanZelf
- Domoticz version: 12467
Re: Blockly triggering condition
If HOME = On AND { (Time >= Sunset AND Time <= 0:00) OR (Time > 0:00 AND Time <= Sunrise) }
Do Set Light = On
example:
If this is not working as expected, you should try a DzVents script. There you can distinct trigger and condition.
Do Set Light = On
example:
yes I have done the same but it gets triggered at sunset.
Thank you for your hint with DzVent, I need to google it as I am not familiar with this. So if someone has maybe a minute to write this function above with DzVents (distinct), I will be verry grateful as my start with DzVents will be much more painless
AllesVanZelf
Try this:
return
on =
devices =
['At-Home'] =
'between sunset and sunrise'
logging =
level = domoticz.LOG_DEBUG,
execute = function(dz)
local home = dz.devices('At-Home').state
local light = dz.devices('Light-1')
dz.log('State of At-Home is ' .. home, dz.LOG_DEBUG)
dz.log('State of Light-1 is ' .. light.state, dz.LOG_DEBUG)
if home == 'On' and dz.time.matchesRule('between sunset and sunrise') then
light.switchOn()
}Domoticz 2020.1 (12230) on Raspberry Pi 3B with Raspian Buster. Besides Domoticz, Rpi is running Pi-Hole.
Thank you very much my friend
