Hello, I'm actually using a pi with a domoticz service but I'd like to migrate to docker on Synology to have more stability(I already got a few dockerized services working perfectly).
I pulled a domoticz image from docker hub (linuxserver.io) everything is running nicely, except I don't get any device feedback.
Every port is opened in Synology firewall (8888:8081, 9898:9898, 6144:6144, 1443:1443 all in TCP) and I don't really understand why the docker can't receive updates from my devices.
Anyone already had that problem ?
Thanks.
Domoticz on Docker on Synology
ZhakirSetie
- Target OS: -
Re: Domoticz on Docker on Synology
What devices are we talking about?
Do the motherboard devices work?
What is in the Domoticz log?
Why not use https://hub.docker.com/r/domoticz/domoticz
- JackD
What do you mean.... Can't you get to Domoticz UI or does Domoticz run but non of the devices can be seen in Domoticz.
Did you correctly setup the Domoticz Docker environment
If you have USB devices(hub, receiver, transceiver, Z-wave controller etc..... you have to have the correct drivers installed on the Synology.
