Simple compare temp to a switch on/off action
Posted: Monday 21 June 2021 7:49
Good day,
I am stuck on the basics of DZvents.
I can manually switch 'tasmota_switch_kelder' On and Off
Ground_temperature is taken from the Buienradar value which comes as a single value on its own.
2021-06-21 07:46:17.536 buienradar: Temp (ground_temperature)
However the below code gives this error in the log.
Where line 9 error = if (device.name == 'ground_temperature' and device.temperature <17) then
2021-06-21 07:43:00.631 Error: dzVents: Error: (3.1.7) An error occurred when calling event handler Kelder
2021-06-21 07:43:00.631 Error: dzVents: Error: (3.1.7) ...pi/domoticz/scripts/dzVents/generated_scripts/Kelder.lua:9: attempt to index a nil value (global 'device')
Where is my hickup?
Paco
return
on =
timer = {'every minute'}
execute = function(dz, item)
dz.devices('tasmota_switch_kelder').switchOn()
dz.devices('tasmota_switch_kelder').switchOff()
Paco
