Simple compare temp to a switch on/off action
Backbone
Domoticz version: 2023.2
Post by Backbone »
Good day,
I am stuck on the basics of DZvents.
I can manually switch 'tasmota_switch_kelder' On and Off
Ground_temperature is taken from the Buienradar value which comes as a single value on its own.
2021-06-21 07:46:17.536 buienradar: Temp (ground_temperature)
However the below code gives this error in the log.
Where line 9 error = if (device.name == 'ground_temperature' and device.temperature <17) then
2021-06-21 07:43:00.631 Error: dzVents: Error: (3.1.7) An error occurred when calling event handler Kelder
2021-06-21 07:43:00.631 Error: dzVents: Error: (3.1.7) ...pi/domoticz/scripts/dzVents/generated_scripts/Kelder.lua:9: attempt to index a nil value (global 'device')
return
    on =
        timer = {'every minute'}
    execute = function(dz, item)
            dz.devices('tasmota_switch_kelder').switchOn()
            dz.devices('tasmota_switch_kelder').switchOff()
Where is my hickup?
Paco
EddyG
Re: Simple compare temp to a switch on/off action
Post by EddyG »
Change
in
        if (dz.devices("ground_temperature").temperature <17) then
Backbone
Post by Backbone »
Thanks EddyG,
It works now.
I took a sample code from the wiki and reworked it to what I had.
Paco
