Moving from raspberry pi 3 to 4
Posted: Wednesday 16 June 2021 22:58
by jandirkv
I’ve searched the forum but could not find my answer. I now run the latest stable version of domoticz on a raspberry pi 3. Can I simply put my sd card in a raspberry pi 4 and turn it on or do I need to reinstall everything?
Re: Moving from raspberry pi 3 to 4
Posted: Thursday 17 June 2021 9:07
by heggink
It depends. When I did that a few months ago, I decided to do a fresh install since I already did 2 major OS release upgrades so better to start clean. If you are running the latest OS with updates, you are probably OK. Best to make a copy of the disk first. Also, AFAIK, you will need a new bootloader as 3 and 4 are not compatible.
Sent from my SM-G980F using Tapatalk
Posted: Thursday 09 September 2021 13:50
by jandirkv
Thanks for the advise. I will do fresh install then
