Hi all
Looking to monitor the rate of change of a temperature sensor. I would assume you would deduct current temperature reading from previous reading, and then write to a variable But not quite sure how to achieve this is dzvents. Still quite new to scripting.
Thanks in advance
Dave
Rate of change
- waaren
Re: Rate of change
Something like below?dezmod wrote: Sunday 06 June 2021 15:01 Looking to monitor the rate of change of a temperature sensor. I would assume you would deduct current temperature reading from previous reading.
return
on =
devices =
'tRate', -- your temperature sensor
data =
lTemperature =
initial = 0,
tDelta =
history = true,
maxHours = 10,
logging =
level = domoticz.LOG_DEBUG,
marker = 'temperature_rate',
execute = function(dz, item)
dz.data.lTemperature = ( item.temperature - dz.data.lTemperature ) / item.lastUpdate.secondsAgo
dz.data.tDelta.add(dz.data.lTemperature)
local cstRate = dz.devices(1366) -- custom sensor with X-is label °C / minute
local rate = dz.utils.round( dz.data.tDelta.avgSince('00:30:00', 0 ), 2 )
dz.log('Rate is now ' .. rate .. ' °C / minute over the last 30 minutes.', dz.LOG_DEBUG)
cstRate.updateCustomSensor( rate )
dezmod
Re: Rate of change
Looks good working away this week will look when i get back thank you.
dezmod
Re: Rate of change
This is working fine thank you. Is there any way to show if the change is negative or positive?
