Domoticz has a buildin report function for the amount of Rain that has fallen per day, week, month etc.
I want to use that data in a script to control the amount of water I drip into my garden.
Question 1. Someone who build that function already??
Question 2. Are those, reported, calculated amounts available for scripting?
Thanks for helping already..
Using calculated amount of rain parameters from Domoticz
Afterburner
- waaren
Re: Using calculated amount of rain parameters from Domoticz
Not directly but you can use the API callsAfterburner wrote: Thursday 27 May 2021 22:17 Are those, reported, calculated amounts available for scripting?
/json.htm?type=graph&sensor=rain&idx=23&range=day
/json.htm?type=graph&sensor=rain&idx=23&range=week
/json.htm?type=graph&sensor=rain&idx=23&range=month
/json.htm?type=graph&sensor=rain&idx=23&range=year
and process the results in your script.
You can use below dzVents script that I once created as an example / starting point.
local scriptVar = 'water the plants'
return
on =
timer =
'at 09:09', -- change to the time you want to check the amount of rain in the set number of days
httpResponses =
scriptVar,
logging =
level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when script works as expected
marker = scriptVar,
execute = function(dz, item)
local minAmount = 2 -- in mm rain
local daysToEvaluate = 5 -- in days
local rainDevice = dz.devices('myRain') -- name enclosed in quotes or number without quotes
local waterPump = dz.devices('Beregening')
if item.isDevice or item.isTimer then
dz.openURL(
url = dz.settings['Domoticz url'] .. '/json.htm?type=graph&sensor=rain&idx=' .. rainDevice.idx .. '&range=month',
callback = scriptVar,
return
local function getmm(rt)
local startDate = (dz.time.addMinutes(-1 * daysToEvaluate * 24 * 60)).rawDate
local mm = 0
dz.log('startDate: ' .. startDate, dz.LOG_DEBUG)
for index, record in ipairs(rt) do
if record.d > startDate then
mm = mm + record.mm
return mm
if item.ok and item.isJSON then
local mmRain = getmm(item.json.result, days )
if mmRain < minAmount then
waterPump.cancelQueuedCommands()
waterPump.switchOn()
waterPump.switchOff().afterSec(3600)
dz.log('Not enough rain in the last ' .. daysToEvaluate .. ' days (' .. mmRain .. ' mm). Switching waterpump on for 1 hour', dz.LOG_DEBUG)
dz.log('Enough rain in the last ' .. daysToEvaluate .. ' days (' .. mmRain .. 'mm). No need to turn on waterpump.', dz.LOG_DEBUG)
dz.log('No valid response from domoticz ',dz.LOG_ERROR)
dz.log(item,dz.LOG_ERROR)
Afterburner
Good startingpoint. Thanks.
