Map one range of numbers to another
Posted: Sunday 23 May 2021 20:22
by RvdM
With C++ there is a map function which is able to map one range of numbers to another.
An example is like this:
int percentage = map(300, 500, 0, 100);
300 equals 0 and 500 equals 100 which makes it easy to calculate things like for example percentages.
Is this possible with lua as well because I couldn't find such a function.
Re: Map one range of numbers to another
Posted: Sunday 23 May 2021 20:53
by waaren
RvdM wrote: Sunday 23 May 2021 20:22
In Lua you can use a table to do that.
local map =
[300] = 0,
[500] = 100,
print(map[300])
print(map[500])
Posted: Sunday 23 May 2021 21:08
by RvdM
Perhaps i'm doing something wrong but this doesn't work.
2021-05-23 21:22:00.479 Error: dzVents: Error: (3.1.8) test: ...v-domoticz/scripts/dzVents/generated_scripts/ScriptT.lua:25: attempt to concatenate a nil value (local 'test')
active = {
true,
timer = { 'every minute' }
logging = {
level = domoticz.LOG_DEBUG,
marker = "test"
execute = function(domoticz, triggeredItem, info)
local map =
[300] = 0,
[500] = 100,
local test = map[400]
domoticz.log('test' .. test, LOG_DEBUG)
domoticz.devices('TestCustomSensor').updateCustomSensor(test)
Posted: Sunday 23 May 2021 22:05
by waaren
RvdM wrote:Perhaps i'm doing something wrong but this doesn't work.
You defined 300 and 500 as keys and then try to call key 400?
or maybe you are looking for something like
local tMap = { 300, 500, 0, 100 }
local function map(n, decimals)
if n > tMap[2] or n < tMap[1] then return 'out of range' end -- protect range
local integer = type(decimals) ~= 'number'
local decimals = decimals or 2
local result = ( n - tMap[1]) * (tMap[4] - tMap[3]) / (tMap[2] - tMap[1])
return ( ( integer and domoticz.utils.round( result ) ) or ( round ( result, decimals ) ) ) -- rounded to integer or number of decimals
print(map(300)) -->> 0
print(map(400)) -->> 50
print(map(401.1357)) -->> 51
print(map(401.1357,4)) -->> 50.5678
print(map(500)) -->> 100
print(map(-299)) -->> out of range
print(map(501)) -->> out of range
Posted: Monday 24 May 2021 16:45
by RvdM
Yes thats it.. but I still get an error
2021-05-24 16:44:00.518 Error: dzVents: Error: (3.1.8) test: ...v-domoticz/scripts/dzVents/generated_scripts/ScriptT.lua:21: attempt to compare number with string
local tMap = { 0, 48, 0, 100 }
niveau = domoticz.devices('Plant - CrotonPetra - WaterNiveau').state
local percentage = map(niveau)
domoticz.devices('Plant - CrotonPetra - Percentage').updateCustomSensor(percentage)
Posted: Monday 24 May 2021 17:15
by RvdM
Solved
niveau = tonumber(domoticz.devices('Plant - CrotonPetra - WaterNiveau').state)
I also changed the function so it equals how the function in C++ works
local function map(n, w, x, y, z, decimals)
if n > x or n < w then return 'out of range' end -- protect range
local result = (n - w) * (z - y) / (x - w)
