An example is like this:
int percentage = map(300, 500, 0, 100);Is this possible with lua as well because I couldn't find such a function.
int percentage = map(300, 500, 0, 100);In Lua you can use a table to do that.RvdM wrote: Sunday 23 May 2021 20:22 Is this possible with lua as well because I couldn't find such a function.
local map =
[300] = 0,
[500] = 100,
print(map[300])
print(map[500])Code: Select all
2021-05-23 21:22:00.479 Error: dzVents: Error: (3.1.8) test: ...v-domoticz/scripts/dzVents/generated_scripts/ScriptT.lua:25: attempt to concatenate a nil value (local 'test')
active = {
true,
timer = { 'every minute' }
logging = {
level = domoticz.LOG_DEBUG,
marker = "test"
execute = function(domoticz, triggeredItem, info)
local map =
[300] = 0,
[500] = 100,
local test = map[400]
domoticz.log('test' .. test, LOG_DEBUG)
domoticz.devices('TestCustomSensor').updateCustomSensor(test)
You defined 300 and 500 as keys and then try to call key 400?RvdM wrote:Perhaps i'm doing something wrong but this doesn't work.
local tMap = { 300, 500, 0, 100 }
local function map(n, decimals)
if n > tMap[2] or n < tMap[1] then return 'out of range' end -- protect range
local integer = type(decimals) ~= 'number'
local decimals = decimals or 2
local result = ( n - tMap[1]) * (tMap[4] - tMap[3]) / (tMap[2] - tMap[1])
return ( ( integer and domoticz.utils.round( result ) ) or ( round ( result, decimals ) ) ) -- rounded to integer or number of decimals
print(map(300)) -->> 0
print(map(400)) -->> 50
print(map(401.1357)) -->> 51
print(map(401.1357,4)) -->> 50.5678
print(map(500)) -->> 100
print(map(-299)) -->> out of range
print(map(501)) -->> out of range
2021-05-24 16:44:00.518 Error: dzVents: Error: (3.1.8) test: ...v-domoticz/scripts/dzVents/generated_scripts/ScriptT.lua:21: attempt to compare number with string
local tMap = { 0, 48, 0, 100 }
niveau = domoticz.devices('Plant - CrotonPetra - WaterNiveau').state
local percentage = map(niveau)
domoticz.devices('Plant - CrotonPetra - Percentage').updateCustomSensor(percentage)
endCode: Select all
niveau = tonumber(domoticz.devices('Plant - CrotonPetra - WaterNiveau').state)
local function map(n, w, x, y, z, decimals)
if n > x or n < w then return 'out of range' end -- protect range
local result = (n - w) * (z - y) / (x - w)
endUsers browsing this forum: No registered users and 1 guest
