Dashticz spoils the camera url
Mad6
Post by Mad6 »
Hi!
I have 3 cameras in dashticz config file (and the domoticz cam settings).
2 camera works fine, but 1 camera doesn't want to.
The Dashticz put junk in the url like this: "&t=83029"
example:
https://[domoticz IP]/camsnapshot.jpg?idx=2&t=83029
http://[camera IP]/webcapture.jpg?command=snap&t=83431&channel=1&user=admin&password=[campass]
If I connect directly to the other two cameras, they work, but the Domoticz link is always broken.
What have I done wrong? :roll:
the config file:
blocks['cam1'] = {
type: 'camera',
imageUrl: "http://[cam1IP]/web/auto.jpg?-usr=[username]&-pwd=[campass]&",
refresh: 2,
width: 6,
height: 200
blocks['cam2'] = {
type: 'camera',
imageUrl: "http://[cam2IP]/web/auto.jpg?-usr=[username]&-pwd=[campass]&",
refresh: 2,
width: 6,
height: 200
blocks['cam3'] = {
type: 'camera',
isimage: true,
forcerefresh: 1,
slidedelay : 10,
imageUrl: "https://[domoticz IP]/camsnapshot.jpg?idx=1",
refresh: 2,
width: 6,
height: 200
HansieNL
Re: Dashticz spoils the camera url
Post by HansieNL »
Can you try with http:// instead of https:// and see of that works?
Blah blah blah
Mad6
Post by Mad6 »
I tried, and received a new junk.
http://[domoticz IP]/camsnapshot.jpg?idx=1&t=87215
I deleted the configuration detail and copied an example to its location. There is no change.
blocks['kapu_cam'] = {
type: 'camera',
title: 'Voordeur',
isimage: true,
forcerefresh: 1,
slidedelay : 10,
imageUrl: "http://[domoticz IP]/camsnapshot.jpg?idx=1",
refresh: 2,
width: 6,
height: 200
Lokonli
Post by Lokonli »
Use forcerefresh:0
With the forcerefresh parameter you can influence the caching prevention methods. With forcerefresh:0 setting no caching prevention method will be applied.
Verstuurd vanaf mijn AC2003 met Tapatalk
Mad6
Post by Mad6 »
It's working, thanks!
But only the direct connect to cameras.
Domoticz link show empty image like this:
When opened in a new tab, the link will download a snapshot from the camera.
Lokonli
Post by Lokonli »
Which Domoticz URL do you use?
Mad6
Post by Mad6 »
Lokonli wrote: Friday 21 May 2021 14:28 Which Domoticz URL do you use?
