i am trying to write a python plugin which derives the needed boiler temp from an outside temperature device
however i cannot find a way how to get access to a temperature sensor which was not created by the pluing (e.g. i have a idx number from the temperature sensor, how can i get the value of that sensor in a python plugin)
Does someone have some sample code i can use?
Gettign the value from a temperature device in a python plugin
Re: Gettign the value from a temperature device in a python plugin
A plugin can only see its own devices. Is really a plugin you need ? Or a python/lua/dzVent script would be better ?
Otherwise you can use jsonnAPI inside the plugin ( which I don’t think is great)
akamming
Tx. i could fix with a python/lua/dzvents script, but i really like the fact that the plugin creates and manages it's own devices. Saves a lot of manual work creating the virtual devices.pipiche wrote: Saturday 15 May 2021 20:56 A plugin can only see its own devices. Is really a plugin you need ? Or a python/lua/dzVent script would be better ?
I already used the json API as a workaround. It works, but requires that the plugin know the IP Adress and port from the domoticz instance. It is now a configurable parameter in the plugin, but it would be better if this could be retrieved from the domoticz config within the python code. Does anyone know how?
- waaren
A lot of work?akamming wrote: Saves a lot of manual work creating the virtual devices.
Takes about 20 seconds per device (if you type as slow as me)
akamming
and multiply that by 25 virtual deviceswaaren wrote: Sunday 16 May 2021 21:33 A lot of work?
Takes about 20 seconds per device (if you type as slow as me)![]()
besides now i don't get error's on this script if i accidentally delete a device, it is recreated by the plugin.
I had the same concern and created a topic : viewtopic.php?f=65&t=35121
Getting access to other devices state with read only access from a plugin would be very useful.
- Domoticz version: 2025.1
A plugin is only to be used to create and control the related hardware. Of you want to control/modify devices based on other devices you need scripting like Blockly, Lua, DzVents etc who have a view over all Domoticz devices.Masure wrote: Wednesday 25 August 2021 14:36 I had the same concern and created a topic : viewtopic.php?f=65&t=35121
If you accidentally would like to use one then the http API way of working would do.
It is the same for C++ Hardware plugins I presume.
