Selector: issue with off mode
Posted: Tuesday 11 May 2021 0:14
by Number8
Hello
Say Level 2 is selected (hence the bulb is on). Then click on the bulb: it switches to Off but selector Level 2 remains selected instead of being set to Off (see attachment) which seems to me what one could expect. Any thoughts?
Running 2020.2 12485
Thank you
Re: Selector: issue with off mode
Posted: Tuesday 11 May 2021 1:35
by waaren
Number8 wrote: Tuesday 11 May 2021 0:14 Hello
Say Level 2 is selected (hence the bulb is on). Then click on the bulb: it switches to Off but selector Level 2 remains selected instead of being set to Off) which seems to me what one could expect. Any thoughts?
This is by design. Check this topic
Posted: Tuesday 11 May 2021 7:36
by Number8
Thanks @waaren. OK I got it, but what I want is to get the selection action attached to level 0 executed. When .silent() is removed an infinite loop is created. How to get it executed only once?
Re: Selector: issue with off mode  [Solved]
Posted: Tuesday 11 May 2021 9:41
by waaren
Number8 wrote: Tuesday 11 May 2021 7:36 Thanks @waaren. OK I got it, but what I want is to get the selection action attached to level 0 executed. When .silent() is removed an infinite loop is created. How to get it executed only once?
Use something like below
return
    on =
        devices =
            'mySelector'
    logging =
        level = domoticz.LOG_DEBUG ,
        marker = 'selector',
    execute = function(dz, item)
        if item.nValue == 0 and item.level ~= 0 then
           item.switchSelector('Off')
           dz.log('Action required (nValue == 0 and level left at '.. item.level ..')' ,dz.LOG_DEBUG)
        elseif item.nValue == 0 then
             dz.log('No action required (nValue and level both 0)' ,dz.LOG_DEBUG)
            dz.log('No action required (nValue ~= 0) ',dz.LOG_DEBUG)
Posted: Tuesday 11 May 2021 10:11
by Number8
Thank you
