Selector: issue with off mode  [Solved]
Number8
Domoticz version: 2022.1
Post by Number8 »
Hello
Say Level 2 is selected (hence the bulb is on). Then click on the bulb: it switches to Off but selector Level 2 remains selected instead of being set to Off (see attachment) which seems to me what one could expect. Any thoughts?
Running 2020.2 12485
Thank you
Debian buster on NUC and three RPi with buster.
Re: Selector: issue with off mode
Number8 wrote: Tuesday 11 May 2021 0:14 Hello
Say Level 2 is selected (hence the bulb is on). Then click on the bulb: it switches to Off but selector Level 2 remains selected instead of being set to Off) which seems to me what one could expect. Any thoughts?
This is by design. Check this topic
Number8
Post by Number8 »
Thanks @waaren. OK I got it, but what I want is to get the selection action attached to level 0 executed. When .silent() is removed an infinite loop is created. How to get it executed only once?
Re: Selector: issue with off mode  [Solved]
Number8 wrote: Tuesday 11 May 2021 7:36 Thanks @waaren. OK I got it, but what I want is to get the selection action attached to level 0 executed. When .silent() is removed an infinite loop is created. How to get it executed only once?
Use something like below
return
    on =
        devices =
            'mySelector'
    logging =
        level = domoticz.LOG_DEBUG ,
        marker = 'selector',
    execute = function(dz, item)
        if item.nValue == 0 and item.level ~= 0 then
           item.switchSelector('Off')
           dz.log('Action required (nValue == 0 and level left at '.. item.level ..')' ,dz.LOG_DEBUG)
        elseif item.nValue == 0 then
             dz.log('No action required (nValue and level both 0)' ,dz.LOG_DEBUG)
            dz.log('No action required (nValue ~= 0) ',dz.LOG_DEBUG)
Number8
Post by Number8 »
Thank you
