I'm struggling with the WallBox python library when using from a script called from Domoticz. When I use the python3 script from terminal all works fine. This is what I've tried so far:
* Create an bash to call the script
/usr/bin/python3 /home/pi/domoticz/scripts/python/WallBox.py
or
Python3 /home/pi/domoticz/scripts/python/WallBox.py
* direct call of the script:
or
wallbox.py
#!/usr/bin/python3
import sys
try:
from wallbox import Wallbox
except ImportError:
sys.path.append(sys.path[0] + '/..')
import time
etc
The rights of the script set at 755.
In all cases the wallbox is not found????
This is the domoticz error log:
2021-05-09 13:05:03.830 File "/home/pi/domoticz/scripts/python/WallBox.py", line 8, in <module>
2021-05-09 13:05:03.830 from wallbox import Wallbox
2021-05-09 13:05:03.830 ModuleNotFoundError: No module named 'wallbox'
2021-05-09 13:05:03.831 Error: dzVents: Wallbox: Traceback (most recent call last):
2021-05-09 13:05:03.831 File "/home/pi/domoticz/scripts/python/WallBox.py", line 4, in <module>
2021-05-09 13:05:03.831 from wallbox import Wallbox
2021-05-09 13:05:03.831 ModuleNotFoundError: No module named 'wallbox'
2021-05-09 13:05:03.831 During handling of the above exception, another exception occurred:
2021-05-09 13:05:03.831 Traceback (most recent call last):
2021-05-09 13:05:03.831 File "/home/pi/domoticz/scripts/python/WallBox.py", line 8, in <module>
2021-05-09 13:05:03.831 ::ERROR::
any suggestions???
Mark
Unable to use WallBox python script from domoticz
mvroosmalen
- Domoticz version: 2026.3
Re: Unable to use WallBox python script from domoticz
Domoticz service often runs on elevated rights (root).
Did you install the python Wallbox library with sudo?
require root permission
mvroosmalen
Nope...
The solution is:
#!/usr/bin/python3
import sys
try:
except ImportError:
sys.path.append('/home/pi/.local/lib/python3.7/site-packages')
import time
Thanks for the suggestion anyway
Mark
The solution is:
#!/usr/bin/python3
import sys
try:
except ImportError:
import time
Mark
