Domoticz Windows with one python plugin - how to set up?
Posted: Sunday 25 April 2021 19:21
I'm quite new with Domoticz and need some help with basic (?) setup.
I want to set up Domoticz with one python plugin (Xiaomi Flora if it does matter) on Windows machine where I have other HA system (Homeseer) already running.
I've installed Domoticz on that machine and was able to run it.
Then I've installed python and everything was OK
I've installed the plugin by copying it to the plugin folder in the Domoticz directory (I had to create plugin folder), then started Domoticz, went to the Hardware section and created new - Xiaomi Flora was on the list.
But after I created that hardware, Domoticz stopped working.
When I try to run it again it starts, opens the browser tab for accessing the interface, but then it stops working.
I don't know where to look what's wrong and would appreciate any help.
I have other instance of Domoticz running with same plugin on Raspberry PI without issues, but there is no other HA system on that machine installed.
As far as I understood in case of raspberry the bluepy is needed to be installed to allow python access bluetooth, but bluepy doesn't run on Windows, and I've red that python 3.9 has bluetooth support implemented in it. But maybe here is the cause?
