P1 with FTDI not saving inversion
Posted: Wednesday 21 April 2021 12:16
by hemant5400z
Hi All,
Need some help with setting up FDTI. I have a FTDI i'm preparing to connect with my smartmeter so far so good.
The problem comes with inversion as I understand i need to invest the signal. When connected to Windows and using FTProg I can see the the device properly. VID 0x0403 PID 0x6001 Mafufacturer FTDI.
However when I invert the signal, it says ok and done but recycle or re-plug the device shows that it is not onverted so it is not saving the config. Does anyone know why and how to fix this?
The chip shows the folloowing:
FTDI
1750-c
CN480661
FT232RL
Any suggestions/help is appreciated.
Cheers,
Hemant
Re: P1 with FTDI not saving inversion
Posted: Wednesday 21 April 2021 12:23
by erem
this may be a cheap chinese knockoff, and not a true FTDI.
if that is the case, you can invert like this.
P1 Inverter with BC547.gif (9.67 KiB) Viewed 7480 times
Posted: Wednesday 21 April 2021 13:55
by hemant5400z
Thanks,
Where would I get the 3.3 from as the FTDI is set to 5V?
Assuming I can get GND from the FTDI, also I have put a 10K between 5v and RDX already.
Would a BC547C do?
Hemant
Posted: Wednesday 21 April 2021 14:45
by erem
a bc547c is fine.
if your ftdi is 5v tolerant on rx you can feed the bc547 with 5v.
Posted: Wednesday 21 April 2021 15:10
by hemant5400z
Hi Thanks rob,
just to check:
Q1 before 1k goes to RDX and Q1 after 1K goes to 5V split from FDTI
Posted: Wednesday 21 April 2021 15:25
by erem
not quite sure what you mean here
blue dot (5) connects with rj12 pin 5 of connector to meter
white dot to input of device connects with rx of ftdi adapter.
Posted: Wednesday 21 April 2021 15:34
by hemant5400z
yes correct and the 3.3v in my case connect to 5v on fdti.
Also would the 10k pullup still be required betwen vcc and RX?
Posted: Thursday 22 April 2021 10:41
by hemant5400z
Mine is like in the attachment.
Any advice?
Posted: Thursday 22 April 2021 11:20
by erem
looks good to me.
you can connect this and use a pc with a terminal emulator (win:putty or *nix:cu) to see if telegrams are sent by the p1 meter.
Posted: Monday 26 April 2021 16:57
by hemant5400z
Thanks for all the help all is working and data is pulled into domoticz with this setup.
Cheers,
Hemant
