P1 with FTDI not saving inversion
hemant5400z
Post by hemant5400z »
Hi All,
Need some help with setting up FDTI. I have a FTDI i'm preparing to connect with my smartmeter so far so good.
The problem comes with inversion as I understand i need to invest the signal. When connected to Windows and using FTProg I can see the the device properly. VID 0x0403 PID 0x6001 Mafufacturer FTDI.
However when I invert the signal, it says ok and done but recycle or re-plug the device shows that it is not onverted so it is not saving the config. Does anyone know why and how to fix this?
The chip shows the folloowing:
FTDI
1750-c
CN480661
FT232RL
Any suggestions/help is appreciated.
Cheers,
Hemant
erem
Domoticz version: 2021.1
Re: P1 with FTDI not saving inversion
Post by erem »
this may be a cheap chinese knockoff, and not a true FTDI.
if that is the case, you can invert like this.
P1 Inverter with BC547.gif (9.67 KiB) Viewed 7332 times
Regards,
Rob
hemant5400z
Thanks,
Where would I get the 3.3 from as the FTDI is set to 5V?
Assuming I can get GND from the FTDI, also I have put a 10K between 5v and RDX already.
Would a BC547C do?
Hemant
erem
Post by erem »
a bc547c is fine.
if your ftdi is 5v tolerant on rx you can feed the bc547 with 5v.
Regards,
Rob
hemant5400z
Hi Thanks rob,
just to check:
Q1 before 1k goes to RDX and Q1 after 1K goes to 5V split from FDTI
erem
Post by erem »
not quite sure what you mean here
blue dot (5) connects with rj12 pin 5 of connector to meter
white dot to input of device connects with rx of ftdi adapter.
Regards,
Rob
hemant5400z
yes correct and the 3.3v in my case connect to 5v on fdti.
Also would the 10k pullup still be required betwen vcc and RX?
hemant5400z
Mine is like in the attachment.
Any advice?
erem
Post by erem »
looks good to me.
you can connect this and use a pc with a terminal emulator (win:putty or *nix:cu) to see if telegrams are sent by the p1 meter.
Regards,
Rob
hemant5400z
Thanks for all the help all is working and data is pulled into domoticz with this setup.
Cheers,
Hemant
