Error: dzVents: Error: (3.1.7) HTTP/1.1 response: 18 ==>> Transferred a partial file
Posted: Tuesday 20 April 2021 14:14
I use a little script that gets weather info for me every 15 minutes. Sometimes it errors a lot. I don’t really understand what is going on, and if i can fix it. Most of the times it sees to work.
The script
The errors
The script
-- https://openweathermap.org/api/one-call-api
timer = {
'every 15 minutes'
httpResponses = {
'OWMForecastFunc'
local API_id = “123myapi123"
local latitude = domoticz.settings.location.latitude
local longitude = domoticz.settings.location.longitude
if (item.isTimer) then
domoticz.openURL({
url = 'http://api.openweathermap.org/data/2.5/onecall?lat=' .. latitude .. '&' .. 'lon=' .. longitude ..'&lang=nl&APPID=' .. API_id .. '&units=metric',
method = 'GET',
callback = 'OWMForecastFunc',
if (item.isHTTPResponse) then
if (item.ok) then
if (item.isJSON) then
domoticz.globalData.OWMForecast = item.json
domoticz.emitEvent('OWMForecastUpdated')
domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
domoticz.log(item, domoticz.LOG_ERROR)
2021-04-20 09:00:16.920 Error: dzVents: Error: (3.1.7) HTTP/1.1 response: 18 ==>> Transferred a partial file
2021-04-20 09:00:16.920 Error: dzVents: Error: (3.1.7) {["statusText"]="Transferred a partial file", ["statusCode"]=18, ["isGroup"]=false, ["data"]="", ["isTimer"]=false, ["isScene"]=false, ["isVariable"]=false, ["ok"]=false, ["isJSON"]=false, ["isShellCommandResponse"]=false, ["isSecurity"]=false, ["isHTTPResponse"]=true, ["isDevice"]=false, ["isXML"]=false, ["trigger"]="OWMForecastFunc", ["protocol"]="HTTP/1.1", ["baseType"]="httpResponse", ["isCustomEvent"]=false, ["callback"]="OWMForecastFunc", ["dump"]=function, ["_contentType"]="application/json; charset=utf-8", ["isHardware"]=false, ["isSystem"]=false, ["headers"]={["Access-Control-Allow-Credentials"]="true", ["Server"]="openresty", ["Connection"]="keep-alive", ["Access-Control-Allow-Origin"]="*", ["X-Cache-Key"]="/data/2.5/onecall?APPID=123&lang=nl&lat=123&lon=6.13&units=metric", ["Content-Length"]="19441", ["Content-Type"]="application/json; charset=utf-8", ["Access-Control-Allow-Methods"]="GET, POST", ["Date"]="Tue, 20 Apr 2021 07:00:06 GMT"}}
2021-04-20 11:00:38.647 Error: dzVents: Error: (3.1.7) HTTP/1.1 response: 18 ==>> Transferred a partial file
2021-04-20 11:00:38.648 Error: dzVents: Error: (3.1.7) {["isXML"]=false, ["isDevice"]=false, ["isGroup"]=false, ["_contentType"]="application/json; charset=utf-8", ["statusText"]="Transferred a partial file", ["isTimer"]=false, ["headers"]={["X-Cache-Key"]="/data/2.5/onecall?APPID=123&lang=nl&lat=123&lon=6.13&units=metric", ["Content-Type"]="application/json; charset=utf-8", ["Server"]="openresty", ["Date"]="Tue, 20 Apr 2021 09:00:06 GMT", ["Access-Control-Allow-Credentials"]="true", ["Access-Control-Allow-Origin"]="*", ["Access-Control-Allow-Methods"]="GET, POST", ["Content-Length"]="19461", ["Connection"]="keep-alive"}, ["isSystem"]=false, ["data"]="{"lat”:123,"lon":6.1286,"timezone":"Europe/Amsterdam","timezone_offset":7200,"current":{"dt":1618909204,"sunrise":1618892664,"sunset":1618944237,"temp":11.54,"feels_like":11.02,"pressure":1019,"humidity":87,"dew_point":9.45,"uvi":2.82,"clouds":54,"visibility":10000,"wind_speed":3.6,"wind_deg":50,"weather":[{"id":803,"main":"Clouds","description":"half bewolkt","icon":"04d"}]},"minutely":[{"dt":1618909260,"precipitation":0},{"dt":1618909320,"precipitation":0},{"dt":1618909380,"precipitation":0},{"dt":1618909440,"precipitation":0},{"dt":1618909500,"precipitation":0},{"dt":1618909560,"precipitation":0},{"dt":1618909620,"precipitation":0},{"dt":1618909680,"precipitation":0},{"dt":1618909740,"precipitation":0},{"dt":1618909800,"precipitation":0},{"dt":1618909860,"precipitation":0},{"dt":1618909920,"precipitation":0},{"dt":1618909980,"precipitation":0},{"dt":1618910040,"precipitation":0},{"dt":1618910100,"precipitation":0},{"dt":1618910160,"precipitation":0},{"dt":1618910220,"precipitation":0},{"dt":1618910280,"precipitation":0},{"dt":1618910340,"precipitation":0},{"dt":1618910400,"precipitation":0},{"dt":1618910460,"precipitation":0},{"dt":1618910520,"precipitation":0},{"dt":1618910580,"precipitation":0},{"dt":1618910640,"precipitation":0},{"dt":1618910700,"precipitation":0},{"dt":1618910760,"precipitation":0},{"dt":1618910820,"precipitation":0},{"dt":1618910880,"precipitation":0},{"dt":1618910940,"precipitation":0},{"dt":1618911000,"precipitation":0},{"dt":1618911060,"precipitation":0},{"dt":1618911120,"precipitation":0},{"dt":1618911180,"precipitation":0},{"dt":1618911240,"precipitation":0},{"dt":1618911300,"precipitation":0},{"dt":1618911360,"precipitation":0},{"dt":1618911420,"precipitation":0},{"dt":1618911480,"precipitation":0},{"dt":1618911540,"precipitation":0},{"dt":1618911600,"precipitation":0},{"dt":1618911660,"precipitation":0},{"dt":1618911720,"precipitation":0},{"dt":1618911780,"precipitation":0},{"dt":1618911840,"precipitation":0},{"dt":1618911900,"precipitation":0},{"dt":1618911960,"precipitation":0},{"dt":1618912020,"precipitation":0},{"dt":1618912080,"precipitation":0},{"dt":1618912140,"precipitation":0},{"dt":1618912200,"precipitation":0},{"dt":1618912260,"precipitation":0},{"dt":1618912320,"precipitation":0},{"dt":1618912380,"precipitation":0},{"dt":1618912440,"precipitation":0},{"dt":1618912500,"precipitation":0},{"dt":1618912560,"precipitation":0},{"dt":1618912620,"precipitation":0},{"dt":1618912680,"precipitation":0},{"dt":1618912740,"precipitation":0},{"dt":1618912800,"precipitation":0},{"dt":1618912860,"precipitation":0}],"hourly":[{"dt":1618909200,"temp":11.54,"feels_like":11.02,"pressure":1019,"humidity":87,"dew_point":9.45,"uvi":2.82,"clouds":54,"visibility":10000,"wind_speed":3.28,"wind_deg":65,"wind_gust":4.37,"weather":[{"id":803,"main":"Clouds","description":"half bewolkt","icon":"04d"}],"pop":0},{"dt":1618912800,"temp":11.71,"feels_like":11.05,"pressure":1019,"humidity":81,"dew_point":8.56,"uvi":3.91,"clouds":52,"visibility":10000,"wind_speed":3.31,"wind_deg":63,"wind_gust":4.1,"weather":[{"id":803,"main":"Clouds","description":"half bewolkt","icon":"04d"}],"pop":0},{"dt":1618916400,"temp":12.18,"feels_like":11.41,"pressure":1019,"humidity":75,"dew_point":7.89,"uvi":4.54,"clouds":47,"visibility":10000,"wind_speed":3.2,"wind_deg":59,"wind_gust":3.6,"weather":[{"id":802,"main":"Clouds","description":"licht bewolkt","icon":"03d"}],"pop":0},{"dt":1618920000,"temp":12.77,"feels_like":11.88,"pressure":101", ["isHTTPResponse"]=true, ["trigger"]="OWMForecastFunc", ["callback"]="OWMForecastFunc", ["ok"]=false, ["isJSON"]=false, ["isCustomEvent"]=false, ["isScene"]=false, ["baseType"]="httpResponse", ["statusCode"]=18, ["isHardware"]=false, ["isVariable"]=false, ["isSecurity"]=false, ["dump"]=function, ["protocol"]="HTTP/1.1", ["isShellCommandResponse"]=false}
2021-04-20 11:30:23.760 Error: dzVents: Error: (3.1.7) HTTP/1.1 response: 18 ==>> Transferred a partial file
2021-04-20 11:30:23.762 Error: dzVents: Error: (3.1.7) {["ok"]=false, ["data"]="{"lat”:123,"lon":6.1286,"timezone":"Europe/Amsterdam","timezone_offset":7200,"current":{"dt":1618911012,"sunrise":1618892664,"sunset":1618944237,"temp":12.31,"feels_like":11.87,"pressure":1019,"humidity":87,"dew_point":10.21,"uvi":3.91,"clouds":45,"visibility":10000,"wind_speed":2.57,"wind_deg":50,"weather":[{"id":802,"main":"Clouds","description":"licht bewolkt","icon":"03d"}]},"minutely":[{"dt":1618911060,"precipitation":0},{"dt":1618911120,"precipitation":0},{"dt":1618911180,"precipitation":0},{"dt":1618911240,"precipitation":0},{"dt":1618911300,"precipitation":0},{"dt":1618911360,"precipitation":0},{"dt":1618911420,"precipitation":0},{"dt":1618911480,"precipitation":0},{"dt":1618911540,"precipitation":0},{"dt":1618911600,"precipitation":0},{"dt":1618911660,"precipitation":0},{"dt":1618911720,"precipitation":0},{"dt":1618911780,"precipitation":0},{"dt":1618911840,"precipitation":0},{"dt":1618911900,"precipitation":0},{"dt":1618911960,"precipitation":0},{"dt":1618912020,"precipitation":0},{"dt":1618912080,"precipitation":0},{"dt":1618912140,"precipitation":0},{"dt":1618912200,"precipitation":0},{"dt":1618912260,"precipitation":0},{"dt":1618912320,"precipitation":0},{"dt":1618912380,"precipitation":0},{"dt":1618912440,"precipitation":0},{"dt":1618912500,"precipitation":0},{"dt":1618912560,"precipitation":0},{"dt":1618912620,"precipitation":0},{"dt":1618912680,"precipitation":0},{"dt":1618912740,"precipitation":0},{"dt":1618912800,"precipitation":0},{"dt":1618912860,"precipitation":0},{"dt":1618912920,"precipitation":0},{"dt":1618912980,"precipitation":0},{"dt":1618913040,"precipitation":0},{"dt":1618913100,"precipitation":0},{"dt":1618913160,"precipitation":0},{"dt":1618913220,"precipitation":0},{"dt":1618913280,"precipitation":0},{"dt":1618913340,"precipitation":0},{"dt":1618913400,"precipitation":0},{"dt":1618913460,"precipitation":0},{"dt":1618913520,"precipitation":0},{"dt":1618913580,"precipitation":0},{"dt":1618913640,"precipitation":0},{"dt":1618913700,"precipitation":0},{"dt":1618913760,"precipitation":0},{"dt":1618913820,"precipitation":0},{"dt":1618913880,"precipitation":0},{"dt":1618913940,"precipitation":0},{"dt":1618914000,"precipitation":0},{"dt":1618914060,"precipitation":0},{"dt":1618914120,"precipitation":0},{"dt":1618914180,"precipitation":0},{"dt":1618914240,"precipitation":0},{"dt":1618914300,"precipitation":0},{"dt":1618914360,"precipitation":0},{"dt":1618914420,"precipitation":0},{"dt":1618914480,"precipitation":0},{"dt":1618914540,"precipitation":0},{"dt":1618914600,"precipitation":0},{"dt":1618914660,"precipitation":0}],"hourly":[{"dt":1618909200,"temp":12.08,"feels_like":11.48,"pressure":1019,"humidity":82,"dew_point":9.1,"uvi":2.82,"clouds":47,"visibility":10000,"wind_speed":3.28,"wind_deg":65,"wind_gust":4.37,"weather":[{"id":802,"main":"Clouds","description":"licht bewolkt","icon":"03d"}],"pop":0},{"dt":1618912800,"temp":12.31,"feels_like":11.87,"pressure":1019,"humidity":87,"dew_point":10.21,"uvi":3.91,"clouds":45,"visibility":10000,"wind_speed":3.31,"wind_deg":63,"wind_gust":4.1,"weather":[{"id":802,"main":"Clouds","description":"licht bewolkt","icon":"03d"}],"pop":0},{"dt":1618916400,"temp":12.47,"feels_like":11.89,"pressure":1019,"humidity":81,"dew_point":9.3,"uvi":4.54,"clouds":43,"visibility":10000,"wind_speed":3.2,"wind_deg":59,"wind_gust":3.6,"weather":[{"id":802,"main":"Clouds","description":"licht bewolkt","icon":"03d"}],"pop":0},{"dt":1618920000,"temp":12.82,"feels_like":12.09,"pressure"", ["statusText"]="Transferred a partial file", ["protocol"]="HTTP/1.1", ["isShellCommandResponse"]=false, ["headers"]={["Date"]="Tue, 20 Apr 2021 09:30:13 GMT", ["X-Cache-Key"]="/data/2.5/onecall?APPID=123&lang=nl&lat=123&lon=6.13&units=metric", ["Server"]="openresty", ["Access-Control-Allow-Methods"]="GET, POST", ["Connection"]="keep-alive", ["Access-Control-Allow-Credentials"]="true", ["Content-Type"]="application/json; charset=utf-8", ["Access-Control-Allow-Origin"]="*", ["Content-Length"]="19464"}, ["statusCode"]=18, ["baseType"]="httpResponse", ["dump"]=function, ["isCustomEvent"]=false, ["isHTTPResponse"]=true, ["_contentType"]="application/json; charset=utf-8", ["isTimer"]=false, ["isSecurity"]=false, ["isSystem"]=false, ["isVariable"]=false, ["isHardware"]=false, ["trigger"]="OWMForecastFunc", ["isXML"]=false, ["callback"]="OWMForecastFunc", ["isGroup"]=false, ["isScene"]=false, ["isDevice"]=false, ["isJSON"]=false}
2021-04-20 12:00:17.134 Error: dzVents: Error: (3.1.7) HTTP/1.1 response: 18 ==>> Transferred a partial file
2021-04-20 12:00:17.140 Error: dzVents: Error: (3.1.7) {["isTimer"]=false, ["isJSON"]=false, ["isSystem"]=false, ["isXML"]=false, ["ok"]=false, ["isCustomEvent"]=false, ["baseType"]="httpResponse", ["statusCode"]=18, ["_contentType"]="application/json; charset=utf-8", ["trigger"]="OWMForecastFunc", ["data"]="{"lat”:123,"lon":6.1286,"timezone":"Europe/Amsterdam","timezone_offset":7200,"current":{"dt":1618912803,"sunrise":1618892664,"sunset":1618944237,"temp":14.46,"feels_like":13.79,"pressure":1016,"humidity":70,"dew_point":9.06,"uvi":3.91,"clouds":45,"visibility":10000,"wind_speed":0.89,"wind_deg":36,"wind_gust":4.02,"weather":[{"id":802,"main":"Clouds","description":"licht bewolkt","icon":"03d"}]},"minutely":[{"dt":1618912860,"precipitation":0},{"dt":1618912920,"precipitation":0},{"dt":1618912980,"precipitation":0},{"dt":1618913040,"precipitation":0},{"dt":1618913100,"precipitation":0},{"dt":1618913160,"precipitation":0},{"dt":1618913220,"precipitation":0},{"dt":1618913280,"precipitation":0},{"dt":1618913340,"precipitation":0},{"dt":1618913400,"precipitation":0},{"dt":1618913460,"precipitation":0},{"dt":1618913520,"precipitation":0},{"dt":1618913580,"precipitation":0},{"dt":1618913640,"precipitation":0},{"dt":1618913700,"precipitation":0},{"dt":1618913760,"precipitation":0},{"dt":1618913820,"precipitation":0},{"dt":1618913880,"precipitation":0},{"dt":1618913940,"precipitation":0},{"dt":1618914000,"precipitation":0},{"dt":1618914060,"precipitation":0},{"dt":1618914120,"precipitation":0},{"dt":1618914180,"precipitation":0},{"dt":1618914240,"precipitation":0},{"dt":1618914300,"precipitation":0},{"dt":1618914360,"precipitation":0},{"dt":1618914420,"precipitation":0},{"dt":1618914480,"precipitation":0},{"dt":1618914540,"precipitation":0},{"dt":1618914600,"precipitation":0},{"dt":1618914660,"precipitation":0},{"dt":1618914720,"precipitation":0},{"dt":1618914780,"precipitation":0},{"dt":1618914840,"precipitation":0},{"dt":1618914900,"precipitation":0},{"dt":1618914960,"precipitation":0},{"dt":1618915020,"precipitation":0},{"dt":1618915080,"precipitation":0},{"dt":1618915140,"precipitation":0},{"dt":1618915200,"precipitation":0},{"dt":1618915260,"precipitation":0},{"dt":1618915320,"precipitation":0},{"dt":1618915380,"precipitation":0},{"dt":1618915440,"precipitation":0},{"dt":1618915500,"precipitation":0},{"dt":1618915560,"precipitation":0},{"dt":1618915620,"precipitation":0},{"dt":1618915680,"precipitation":0},{"dt":1618915740,"precipitation":0},{"dt":1618915800,"precipitation":0},{"dt":1618915860,"precipitation":0},{"dt":1618915920,"precipitation":0},{"dt":1618915980,"precipitation":0},{"dt":1618916040,"precipitation":0},{"dt":1618916100,"precipitation":0},{"dt":1618916160,"precipitation":0},{"dt":1618916220,"precipitation":0},{"dt":1618916280,"precipitation":0},{"dt":1618916340,"precipitation":0},{"dt":1618916400,"precipitation":0},{"dt":1618916460,"precipitation":0}],"hourly":[{"dt":1618912800,"temp":14.46,"feels_like":13.79,"pressure":1016,"humidity":70,"dew_point":9.06,"uvi":3.91,"clouds":45,"visibility":10000,"wind_speed":3.31,"wind_deg":63,"wind_gust":4.1,"weather":[{"id":802,"main":"Clouds","description":"licht bewolkt","icon":"03d"}],"pop":0},{"dt":1618916400,"temp":14.19,"feels_like":13.41,"pressure":1016,"humidity":67,"dew_point":8.16,"uvi":4.54,"clouds":43,"visibility":10000,"wind_speed":3.2,"wind_deg":59,"wind_gust":3.6,"weather":[{"id":802,"main":"Clouds","description":"licht bewolkt","icon":"03d"}],"pop":0},{"dt":1618920000,"temp":14.11,"feels_like":13.25,"pressure":1017,"humidity":64,"dew_point":7.41,"uvi":4.6,"clouds":39,"visibility":10000,"wind_speed":3.39,"wind_deg":48,"wind_gust":3.51,"weather":[{"id":802,"main":"Clouds","description":"licht bewolkt","icon":"03d"}],"pop":0},{"dt":1618923600,"temp":14,"feels_like":13.", ["isVariable"]=false, ["isGroup"]=false, ["isHardware"]=false, ["isScene"]=false, ["protocol"]="HTTP/1.1", ["isSecurity"]=false, ["callback"]="OWMForecastFunc", ["isHTTPResponse"]=true, ["isShellCommandResponse"]=false, ["isDevice"]=false, ["headers"]={["Server"]="openresty", ["Content-Type"]="application/json; charset=utf-8", ["Date"]="Tue, 20 Apr 2021 10:00:03 GMT", ["Content-Length"]="19478", ["Access-Control-Allow-Methods"]="GET, POST", ["Access-Control-Allow-Credentials"]="true", ["Access-Control-Allow-Origin"]="*", ["X-Cache-Key"]="/data/2.5/onecall?APPID=123&lang=nl&lat=123&lon=6.13&units=metric", ["Connection"]="keep-alive"}, ["dump"]=function, ["statusText"]="Transferred a partial file"}
2021-04-20 13:30:13.280 Error: dzVents: Error: (3.1.7) HTTP/1.1 response: 18 ==>> Transferred a partial file
2021-04-20 13:30:13.280 Error: dzVents: Error: (3.1.7) {["isVariable"]=false, ["statusCode"]=18, ["statusText"]="Transferred a partial file", ["isXML"]=false, ["isShellCommandResponse"]=false, ["isHardware"]=false, ["isSecurity"]=false, ["callback"]="OWMForecastFunc", ["baseType"]="httpResponse", ["dump"]=function, ["isTimer"]=false, ["isSystem"]=false, ["isCustomEvent"]=false, ["isGroup"]=false, ["isScene"]=false, ["headers"]={["Date"]="Tue, 20 Apr 2021 11:30:03 GMT", ["Content-Length"]="19490", ["Access-Control-Allow-Methods"]="GET, POST", ["Server"]="openresty", ["Access-Control-Allow-Origin"]="*", ["Connection"]="keep-alive", ["Content-Type"]="application/json; charset=utf-8", ["Access-Control-Allow-Credentials"]="true", ["X-Cache-Key"]="/data/2.5/onecall?APPID=123&lang=nl&lat=123&lon=6.13&units=metric"}, ["isJSON"]=false, ["isHTTPResponse"]=true, ["ok"]=false, ["_contentType"]="application/json; charset=utf-8", ["protocol"]="HTTP/1.1", ["data"]="", ["trigger"]="OWMForecastFunc", ["isDevice"]=false}
