Error: dzVents: Error: (3.1.7) HTTP/1.1 response: 18 ==>> Transferred a partial file
Sarcas
Domoticz version: 2022.1ß
Post by Sarcas »
I use a little script that gets weather info for me every 15 minutes. Sometimes it errors a lot. I don’t really understand what is going on, and if i can fix it. Most of the times it sees to work.
The script
--  https://openweathermap.org/api/one-call-api
		timer = {
			'every 15 minutes'
		httpResponses = {
			'OWMForecastFunc'
	    local API_id    = “123myapi123"
        local latitude  = domoticz.settings.location.latitude
        local longitude = domoticz.settings.location.longitude
		if (item.isTimer) then
			domoticz.openURL({
                    url = 'http://api.openweathermap.org/data/2.5/onecall?lat=' .. latitude .. '&' .. 'lon=' .. longitude ..'&lang=nl&APPID=' .. API_id .. '&units=metric',
				method      = 'GET',
				callback    = 'OWMForecastFunc',
		if (item.isHTTPResponse) then
			if (item.ok) then
				if (item.isJSON) then
                    domoticz.globalData.OWMForecast = item.json
                    domoticz.emitEvent('OWMForecastUpdated')
				domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
				domoticz.log(item, domoticz.LOG_ERROR)
The errors
2021-04-20 09:00:16.920 Error: dzVents: Error: (3.1.7) HTTP/1.1 response: 18 ==>> Transferred a partial file
2021-04-20 09:00:16.920 Error: dzVents: Error: (3.1.7) {["statusText"]="Transferred a partial file", ["statusCode"]=18, ["isGroup"]=false, ["data"]="", ["isTimer"]=false, ["isScene"]=false, ["isVariable"]=false, ["ok"]=false, ["isJSON"]=false, ["isShellCommandResponse"]=false, ["isSecurity"]=false, ["isHTTPResponse"]=true, ["isDevice"]=false, ["isXML"]=false, ["trigger"]="OWMForecastFunc", ["protocol"]="HTTP/1.1", ["baseType"]="httpResponse", ["isCustomEvent"]=false, ["callback"]="OWMForecastFunc", ["dump"]=function, ["_contentType"]="application/json; charset=utf-8", ["isHardware"]=false, ["isSystem"]=false, ["headers"]={["Access-Control-Allow-Credentials"]="true", ["Server"]="openresty", ["Connection"]="keep-alive", ["Access-Control-Allow-Origin"]="*", ["X-Cache-Key"]="/data/2.5/onecall?APPID=123&lang=nl&lat=123&lon=6.13&units=metric", ["Content-Length"]="19441", ["Content-Type"]="application/json; charset=utf-8", ["Access-Control-Allow-Methods"]="GET, POST", ["Date"]="Tue, 20 Apr 2021 07:00:06 GMT"}}
2021-04-20 11:00:38.647 Error: dzVents: Error: (3.1.7) HTTP/1.1 response: 18 ==>> Transferred a partial file
2021-04-20 11:00:38.648 Error: dzVents: Error: (3.1.7) {["isXML"]=false, ["isDevice"]=false, ["isGroup"]=false, ["_contentType"]="application/json; charset=utf-8", ["statusText"]="Transferred a partial file", ["isTimer"]=false, ["headers"]={["X-Cache-Key"]="/data/2.5/onecall?APPID=123&lang=nl&lat=123&lon=6.13&units=metric", ["Content-Type"]="application/json; charset=utf-8", ["Server"]="openresty", ["Date"]="Tue, 20 Apr 2021 09:00:06 GMT", ["Access-Control-Allow-Credentials"]="true", ["Access-Control-Allow-Origin"]="*", ["Access-Control-Allow-Methods"]="GET, POST", ["Content-Length"]="19461", ["Connection"]="keep-alive"}, ["isSystem"]=false, ["data"]="{"lat”:123,"lon":6.1286,"timezone":"Europe/Amsterdam","timezone_offset":7200,"current":{"dt":1618909204,"sunrise":1618892664,"sunset":1618944237,"temp":11.54,"feels_like":11.02,"pressure":1019,"humidity":87,"dew_point":9.45,"uvi":2.82,"clouds":54,"visibility":10000,"wind_speed":3.6,"wind_deg":50,"weather":[{"id":803,"main":"Clouds","description":"half bewolkt","icon":"04d"}]},"minutely":[{"dt":1618909260,"precipitation":0},{"dt":1618909320,"precipitation":0},{"dt":1618909380,"precipitation":0},{"dt":1618909440,"precipitation":0},{"dt":1618909500,"precipitation":0},{"dt":1618909560,"precipitation":0},{"dt":1618909620,"precipitation":0},{"dt":1618909680,"precipitation":0},{"dt":1618909740,"precipitation":0},{"dt":1618909800,"precipitation":0},{"dt":1618909860,"precipitation":0},{"dt":1618909920,"precipitation":0},{"dt":1618909980,"precipitation":0},{"dt":1618910040,"precipitation":0},{"dt":1618910100,"precipitation":0},{"dt":1618910160,"precipitation":0},{"dt":1618910220,"precipitation":0},{"dt":1618910280,"precipitation":0},{"dt":1618910340,"precipitation":0},{"dt":1618910400,"precipitation":0},{"dt":1618910460,"precipitation":0},{"dt":1618910520,"precipitation":0},{"dt":1618910580,"precipitation":0},{"dt":1618910640,"precipitation":0},{"dt":1618910700,"precipitation":0},{"dt":1618910760,"precipitation":0},{"dt":1618910820,"precipitation":0},{"dt":1618910880,"precipitation":0},{"dt":1618910940,"precipitation":0},{"dt":1618911000,"precipitation":0},{"dt":1618911060,"precipitation":0},{"dt":1618911120,"precipitation":0},{"dt":1618911180,"precipitation":0},{"dt":1618911240,"precipitation":0},{"dt":1618911300,"precipitation":0},{"dt":1618911360,"precipitation":0},{"dt":1618911420,"precipitation":0},{"dt":1618911480,"precipitation":0},{"dt":1618911540,"precipitation":0},{"dt":1618911600,"precipitation":0},{"dt":1618911660,"precipitation":0},{"dt":1618911720,"precipitation":0},{"dt":1618911780,"precipitation":0},{"dt":1618911840,"precipitation":0},{"dt":1618911900,"precipitation":0},{"dt":1618911960,"precipitation":0},{"dt":1618912020,"precipitation":0},{"dt":1618912080,"precipitation":0},{"dt":1618912140,"precipitation":0},{"dt":1618912200,"precipitation":0},{"dt":1618912260,"precipitation":0},{"dt":1618912320,"precipitation":0},{"dt":1618912380,"precipitation":0},{"dt":1618912440,"precipitation":0},{"dt":1618912500,"precipitation":0},{"dt":1618912560,"precipitation":0},{"dt":1618912620,"precipitation":0},{"dt":1618912680,"precipitation":0},{"dt":1618912740,"precipitation":0},{"dt":1618912800,"precipitation":0},{"dt":1618912860,"precipitation":0}],"hourly":[{"dt":1618909200,"temp":11.54,"feels_like":11.02,"pressure":1019,"humidity":87,"dew_point":9.45,"uvi":2.82,"clouds":54,"visibility":10000,"wind_speed":3.28,"wind_deg":65,"wind_gust":4.37,"weather":[{"id":803,"main":"Clouds","description":"half bewolkt","icon":"04d"}],"pop":0},{"dt":1618912800,"temp":11.71,"feels_like":11.05,"pressure":1019,"humidity":81,"dew_point":8.56,"uvi":3.91,"clouds":52,"visibility":10000,"wind_speed":3.31,"wind_deg":63,"wind_gust":4.1,"weather":[{"id":803,"main":"Clouds","description":"half bewolkt","icon":"04d"}],"pop":0},{"dt":1618916400,"temp":12.18,"feels_like":11.41,"pressure":1019,"humidity":75,"dew_point":7.89,"uvi":4.54,"clouds":47,"visibility":10000,"wind_speed":3.2,"wind_deg":59,"wind_gust":3.6,"weather":[{"id":802,"main":"Clouds","description":"licht bewolkt","icon":"03d"}],"pop":0},{"dt":1618920000,"temp":12.77,"feels_like":11.88,"pressure":101", ["isHTTPResponse"]=true, ["trigger"]="OWMForecastFunc", ["callback"]="OWMForecastFunc", ["ok"]=false, ["isJSON"]=false, ["isCustomEvent"]=false, ["isScene"]=false, ["baseType"]="httpResponse", ["statusCode"]=18, ["isHardware"]=false, ["isVariable"]=false, ["isSecurity"]=false, ["dump"]=function, ["protocol"]="HTTP/1.1", ["isShellCommandResponse"]=false}
2021-04-20 11:30:23.760 Error: dzVents: Error: (3.1.7) HTTP/1.1 response: 18 ==>> Transferred a partial file
2021-04-20 11:30:23.762 Error: dzVents: Error: (3.1.7) {["ok"]=false, ["data"]="{"lat”:123,"lon":6.1286,"timezone":"Europe/Amsterdam","timezone_offset":7200,"current":{"dt":1618911012,"sunrise":1618892664,"sunset":1618944237,"temp":12.31,"feels_like":11.87,"pressure":1019,"humidity":87,"dew_point":10.21,"uvi":3.91,"clouds":45,"visibility":10000,"wind_speed":2.57,"wind_deg":50,"weather":[{"id":802,"main":"Clouds","description":"licht bewolkt","icon":"03d"}]},"minutely":[{"dt":1618911060,"precipitation":0},{"dt":1618911120,"precipitation":0},{"dt":1618911180,"precipitation":0},{"dt":1618911240,"precipitation":0},{"dt":1618911300,"precipitation":0},{"dt":1618911360,"precipitation":0},{"dt":1618911420,"precipitation":0},{"dt":1618911480,"precipitation":0},{"dt":1618911540,"precipitation":0},{"dt":1618911600,"precipitation":0},{"dt":1618911660,"precipitation":0},{"dt":1618911720,"precipitation":0},{"dt":1618911780,"precipitation":0},{"dt":1618911840,"precipitation":0},{"dt":1618911900,"precipitation":0},{"dt":1618911960,"precipitation":0},{"dt":1618912020,"precipitation":0},{"dt":1618912080,"precipitation":0},{"dt":1618912140,"precipitation":0},{"dt":1618912200,"precipitation":0},{"dt":1618912260,"precipitation":0},{"dt":1618912320,"precipitation":0},{"dt":1618912380,"precipitation":0},{"dt":1618912440,"precipitation":0},{"dt":1618912500,"precipitation":0},{"dt":1618912560,"precipitation":0},{"dt":1618912620,"precipitation":0},{"dt":1618912680,"precipitation":0},{"dt":1618912740,"precipitation":0},{"dt":1618912800,"precipitation":0},{"dt":1618912860,"precipitation":0},{"dt":1618912920,"precipitation":0},{"dt":1618912980,"precipitation":0},{"dt":1618913040,"precipitation":0},{"dt":1618913100,"precipitation":0},{"dt":1618913160,"precipitation":0},{"dt":1618913220,"precipitation":0},{"dt":1618913280,"precipitation":0},{"dt":1618913340,"precipitation":0},{"dt":1618913400,"precipitation":0},{"dt":1618913460,"precipitation":0},{"dt":1618913520,"precipitation":0},{"dt":1618913580,"precipitation":0},{"dt":1618913640,"precipitation":0},{"dt":1618913700,"precipitation":0},{"dt":1618913760,"precipitation":0},{"dt":1618913820,"precipitation":0},{"dt":1618913880,"precipitation":0},{"dt":1618913940,"precipitation":0},{"dt":1618914000,"precipitation":0},{"dt":1618914060,"precipitation":0},{"dt":1618914120,"precipitation":0},{"dt":1618914180,"precipitation":0},{"dt":1618914240,"precipitation":0},{"dt":1618914300,"precipitation":0},{"dt":1618914360,"precipitation":0},{"dt":1618914420,"precipitation":0},{"dt":1618914480,"precipitation":0},{"dt":1618914540,"precipitation":0},{"dt":1618914600,"precipitation":0},{"dt":1618914660,"precipitation":0}],"hourly":[{"dt":1618909200,"temp":12.08,"feels_like":11.48,"pressure":1019,"humidity":82,"dew_point":9.1,"uvi":2.82,"clouds":47,"visibility":10000,"wind_speed":3.28,"wind_deg":65,"wind_gust":4.37,"weather":[{"id":802,"main":"Clouds","description":"licht bewolkt","icon":"03d"}],"pop":0},{"dt":1618912800,"temp":12.31,"feels_like":11.87,"pressure":1019,"humidity":87,"dew_point":10.21,"uvi":3.91,"clouds":45,"visibility":10000,"wind_speed":3.31,"wind_deg":63,"wind_gust":4.1,"weather":[{"id":802,"main":"Clouds","description":"licht bewolkt","icon":"03d"}],"pop":0},{"dt":1618916400,"temp":12.47,"feels_like":11.89,"pressure":1019,"humidity":81,"dew_point":9.3,"uvi":4.54,"clouds":43,"visibility":10000,"wind_speed":3.2,"wind_deg":59,"wind_gust":3.6,"weather":[{"id":802,"main":"Clouds","description":"licht bewolkt","icon":"03d"}],"pop":0},{"dt":1618920000,"temp":12.82,"feels_like":12.09,"pressure"", ["statusText"]="Transferred a partial file", ["protocol"]="HTTP/1.1", ["isShellCommandResponse"]=false, ["headers"]={["Date"]="Tue, 20 Apr 2021 09:30:13 GMT", ["X-Cache-Key"]="/data/2.5/onecall?APPID=123&lang=nl&lat=123&lon=6.13&units=metric", ["Server"]="openresty", ["Access-Control-Allow-Methods"]="GET, POST", ["Connection"]="keep-alive", ["Access-Control-Allow-Credentials"]="true", ["Content-Type"]="application/json; charset=utf-8", ["Access-Control-Allow-Origin"]="*", ["Content-Length"]="19464"}, ["statusCode"]=18, ["baseType"]="httpResponse", ["dump"]=function, ["isCustomEvent"]=false, ["isHTTPResponse"]=true, ["_contentType"]="application/json; charset=utf-8", ["isTimer"]=false, ["isSecurity"]=false, ["isSystem"]=false, ["isVariable"]=false, ["isHardware"]=false, ["trigger"]="OWMForecastFunc", ["isXML"]=false, ["callback"]="OWMForecastFunc", ["isGroup"]=false, ["isScene"]=false, ["isDevice"]=false, ["isJSON"]=false}
2021-04-20 12:00:17.134 Error: dzVents: Error: (3.1.7) HTTP/1.1 response: 18 ==>> Transferred a partial file
2021-04-20 12:00:17.140 Error: dzVents: Error: (3.1.7) {["isTimer"]=false, ["isJSON"]=false, ["isSystem"]=false, ["isXML"]=false, ["ok"]=false, ["isCustomEvent"]=false, ["baseType"]="httpResponse", ["statusCode"]=18, ["_contentType"]="application/json; charset=utf-8", ["trigger"]="OWMForecastFunc", ["data"]="{"lat”:123,"lon":6.1286,"timezone":"Europe/Amsterdam","timezone_offset":7200,"current":{"dt":1618912803,"sunrise":1618892664,"sunset":1618944237,"temp":14.46,"feels_like":13.79,"pressure":1016,"humidity":70,"dew_point":9.06,"uvi":3.91,"clouds":45,"visibility":10000,"wind_speed":0.89,"wind_deg":36,"wind_gust":4.02,"weather":[{"id":802,"main":"Clouds","description":"licht bewolkt","icon":"03d"}]},"minutely":[{"dt":1618912860,"precipitation":0},{"dt":1618912920,"precipitation":0},{"dt":1618912980,"precipitation":0},{"dt":1618913040,"precipitation":0},{"dt":1618913100,"precipitation":0},{"dt":1618913160,"precipitation":0},{"dt":1618913220,"precipitation":0},{"dt":1618913280,"precipitation":0},{"dt":1618913340,"precipitation":0},{"dt":1618913400,"precipitation":0},{"dt":1618913460,"precipitation":0},{"dt":1618913520,"precipitation":0},{"dt":1618913580,"precipitation":0},{"dt":1618913640,"precipitation":0},{"dt":1618913700,"precipitation":0},{"dt":1618913760,"precipitation":0},{"dt":1618913820,"precipitation":0},{"dt":1618913880,"precipitation":0},{"dt":1618913940,"precipitation":0},{"dt":1618914000,"precipitation":0},{"dt":1618914060,"precipitation":0},{"dt":1618914120,"precipitation":0},{"dt":1618914180,"precipitation":0},{"dt":1618914240,"precipitation":0},{"dt":1618914300,"precipitation":0},{"dt":1618914360,"precipitation":0},{"dt":1618914420,"precipitation":0},{"dt":1618914480,"precipitation":0},{"dt":1618914540,"precipitation":0},{"dt":1618914600,"precipitation":0},{"dt":1618914660,"precipitation":0},{"dt":1618914720,"precipitation":0},{"dt":1618914780,"precipitation":0},{"dt":1618914840,"precipitation":0},{"dt":1618914900,"precipitation":0},{"dt":1618914960,"precipitation":0},{"dt":1618915020,"precipitation":0},{"dt":1618915080,"precipitation":0},{"dt":1618915140,"precipitation":0},{"dt":1618915200,"precipitation":0},{"dt":1618915260,"precipitation":0},{"dt":1618915320,"precipitation":0},{"dt":1618915380,"precipitation":0},{"dt":1618915440,"precipitation":0},{"dt":1618915500,"precipitation":0},{"dt":1618915560,"precipitation":0},{"dt":1618915620,"precipitation":0},{"dt":1618915680,"precipitation":0},{"dt":1618915740,"precipitation":0},{"dt":1618915800,"precipitation":0},{"dt":1618915860,"precipitation":0},{"dt":1618915920,"precipitation":0},{"dt":1618915980,"precipitation":0},{"dt":1618916040,"precipitation":0},{"dt":1618916100,"precipitation":0},{"dt":1618916160,"precipitation":0},{"dt":1618916220,"precipitation":0},{"dt":1618916280,"precipitation":0},{"dt":1618916340,"precipitation":0},{"dt":1618916400,"precipitation":0},{"dt":1618916460,"precipitation":0}],"hourly":[{"dt":1618912800,"temp":14.46,"feels_like":13.79,"pressure":1016,"humidity":70,"dew_point":9.06,"uvi":3.91,"clouds":45,"visibility":10000,"wind_speed":3.31,"wind_deg":63,"wind_gust":4.1,"weather":[{"id":802,"main":"Clouds","description":"licht bewolkt","icon":"03d"}],"pop":0},{"dt":1618916400,"temp":14.19,"feels_like":13.41,"pressure":1016,"humidity":67,"dew_point":8.16,"uvi":4.54,"clouds":43,"visibility":10000,"wind_speed":3.2,"wind_deg":59,"wind_gust":3.6,"weather":[{"id":802,"main":"Clouds","description":"licht bewolkt","icon":"03d"}],"pop":0},{"dt":1618920000,"temp":14.11,"feels_like":13.25,"pressure":1017,"humidity":64,"dew_point":7.41,"uvi":4.6,"clouds":39,"visibility":10000,"wind_speed":3.39,"wind_deg":48,"wind_gust":3.51,"weather":[{"id":802,"main":"Clouds","description":"licht bewolkt","icon":"03d"}],"pop":0},{"dt":1618923600,"temp":14,"feels_like":13.", ["isVariable"]=false, ["isGroup"]=false, ["isHardware"]=false, ["isScene"]=false, ["protocol"]="HTTP/1.1", ["isSecurity"]=false, ["callback"]="OWMForecastFunc", ["isHTTPResponse"]=true, ["isShellCommandResponse"]=false, ["isDevice"]=false, ["headers"]={["Server"]="openresty", ["Content-Type"]="application/json; charset=utf-8", ["Date"]="Tue, 20 Apr 2021 10:00:03 GMT", ["Content-Length"]="19478", ["Access-Control-Allow-Methods"]="GET, POST", ["Access-Control-Allow-Credentials"]="true", ["Access-Control-Allow-Origin"]="*", ["X-Cache-Key"]="/data/2.5/onecall?APPID=123&lang=nl&lat=123&lon=6.13&units=metric", ["Connection"]="keep-alive"}, ["dump"]=function, ["statusText"]="Transferred a partial file"}
2021-04-20 13:30:13.280 Error: dzVents: Error: (3.1.7) HTTP/1.1 response: 18 ==>> Transferred a partial file
2021-04-20 13:30:13.280 Error: dzVents: Error: (3.1.7) {["isVariable"]=false, ["statusCode"]=18, ["statusText"]="Transferred a partial file", ["isXML"]=false, ["isShellCommandResponse"]=false, ["isHardware"]=false, ["isSecurity"]=false, ["callback"]="OWMForecastFunc", ["baseType"]="httpResponse", ["dump"]=function, ["isTimer"]=false, ["isSystem"]=false, ["isCustomEvent"]=false, ["isGroup"]=false, ["isScene"]=false, ["headers"]={["Date"]="Tue, 20 Apr 2021 11:30:03 GMT", ["Content-Length"]="19490", ["Access-Control-Allow-Methods"]="GET, POST", ["Server"]="openresty", ["Access-Control-Allow-Origin"]="*", ["Connection"]="keep-alive", ["Content-Type"]="application/json; charset=utf-8", ["Access-Control-Allow-Credentials"]="true", ["X-Cache-Key"]="/data/2.5/onecall?APPID=123&lang=nl&lat=123&lon=6.13&units=metric"}, ["isJSON"]=false, ["isHTTPResponse"]=true, ["ok"]=false, ["_contentType"]="application/json; charset=utf-8", ["protocol"]="HTTP/1.1", ["data"]="", ["trigger"]="OWMForecastFunc", ["isDevice"]=false}
Domoticz on rPi4 - RFXCOM RFXtrx433 USB - ZW090 Z-Stick Gen5 EU - IKEA Tradfri - Philips HUE - YouLess meter - SolarEdge
akamming
Re: Error: dzVents: Error: (3.1.7) HTTP/1.1 response: 18 ==>> Transferred a partial file
Post by akamming »
dzVents does a call to the libcurl library and just reports the error back, which you can find on the libcurl-errors manpage (https://linux.die.net/man/3/libcurl-errors):
CURLE_PARTIAL_FILE (18)
A file transfer was shorter or larger than expected. This happens when the server first reports an expected transfer size, and then delivers data that doesn't match the previously given size.
seems to be a serverside issue
Sarcas wrote: Tuesday 20 April 2021 14:14 I use a little script that gets weather info for me every 15 minutes. Sometimes it errors a lot. I don’t really understand what is going on, and if i can fix it. Most of the times it sees to work.
It looks like the response from OWM tells domoticz that the result-data from OWM might be incomplete. This prevents dzVents from automatically converting the JSON into a Lua table.
Can you try below modified version?
        timer = {
            'every 15 minutes'
        httpResponses = {
            'OWMForecastFunc'
        local function processData(item)
            local myJSON = item.json or domoticz.utils.fromJSON(item.data)
            if myJSON then
                domoticz.globalData.OWMForecast = myJSON
                domoticz.log(item, domoticz.LOG_DEBUG)
        if item.isTimer then
            domoticz.openURL({
                method      = 'GET',
        elseif item.isHTTPResponse then
            processData(item)
Sarcas
Post by Sarcas »
Hi waaren,
Thank you. I have activated your version and will check the logs later to see how it is doing.
Can you explain these lines to me? I am trying to learn :)
if myJSON then
Thanks again!
S.
Sarcas wrote: Wednesday 21 April 2021 11:18 Can you explain these lines to me? I am trying to learn :)
if myJSON then
Let me try :)
local myJSON is telling the Lua interpreter that it should reserve a pointer to a memory location for the variable myJSON that will only be accessible within its current block. A block can be a function, - an if-end, - repeat-until while-end, etc ..
item.json is here a Lua table created during the automatic conversion of the JSON string item.data. If that conversion failed or if the conversion did not take place item.json is nil
The right partof the or will only be evaluated if the left part is either nil or false. So here it will force a conversion of the JSON string item.data to a Lua table when item.json is nil
The result of this line is that myJSON will either contain the automatically converted JSON string or the forced converted JSON string or nil when the forced conversion failed.
In your failing version the automatically conversion will not take place when the returncode of the http call is not between 200-300 because dzVents then assume the call failed (which it partially does because of the incompleteness or the return).
Sarcas
Post by Sarcas »
Thank you for the explanation! I’d never think of that. I like the compactness :)
The errors are way less frequent now btw.
2021-05-08 22:30:10.082 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
2021-05-08 22:30:20.832 Error: Error opening url: http://api.openweathermap.org/data/2.5/onecall?lat=53&lon=6&lang=nl&APPID=myapi&units=metric
2021-05-08 22:30:20.984 Error: dzVents: Error: (3.1.8) HTTP/1.1 response: 18 ==>> Transferred a partial file
2021-05-08 22:30:20.984 Error: dzVents: Error: (3.1.8) Error parsing json to LUA table: (invalid json string)
Not sure what is causing these hiccups, but I am migrating from my old rpi to a new rpi4 so maybe that will help.
S.
