Which action triggered my device ?
Posted: Wednesday 07 April 2021 18:31
by jpr105
For my automated watering I have 4 electrovalves corresponding to my 4 watering zones.
Each electrovalve can be controlled either :
- manually via the smartphone
- for a specific duration via a scenario
- within the framework of a weekly schedule
My question is the following:
In the dZVents language, is it possible to know HOW my electrovalve has been activated?
Thank you in advance for your help
Regards - Jean-Paul
Re: Which action triggered my device ?
Posted: Wednesday 07 April 2021 19:27
by waaren
jpr105 wrote: Wednesday 07 April 2021 18:31
Not natively but below script (using sqlite3 to access the domoticz database) will show you the last actor of the device.
triggerinfo.lua
requires: sqlite3
dzVents >= 3.0.13
domoticz >= V2020.2 build 12693
return
on =
devices =
'myDevice', -- Change to device you need to monitor
'eventTrigger',
logging =
level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when script is tested and OK
marker = 'getActor',
execute = function(dz, item)
local function getLightingLogData(id)
local _,rc = dz.utils.osCommand('which sqlite3')
if rc == 0 then
local cmd = 'sudo sqlite3 -list -noheader domoticz.db "SELECT DeviceRowID ID, User, Date FROM LightingLog WHERE DeviceRowID = ' .. id .. ' ORDER BY Date DESC LIMIT 1;" '
return dz.utils.osCommand(cmd)
dz.log('sqlite3 not available. Please make sure it is installed (sudo apt install sqlite3) and accessible', dz.LOG_ERROR)
-- main
if item.active then
local lightingLogLine = getLightingLogData(item.id)
if lightingLogLine:find('|') then
local lightingLogLineTable = dz.utils.stringSplit( getLightingLogData(item.id) ,'|')
local user = lightingLogLineTable[2]
local modTime = lightingLogLineTable[3]
dz.log( 'user: '.. user .. ' triggered me at ' .. modTime,dz.LOG_FORCE)
dz.log( 'No data in LightingLog for device ' .. item.name,dz.LOG_DEBUG)
Posted: Wednesday 07 April 2021 20:27
by jpr105
Thank you
Fast and efficient. I will try asap
