Which action triggered my device ?
jpr105
Post by jpr105 »
For my automated watering I have 4 electrovalves corresponding to my 4 watering zones.
Each electrovalve can be controlled either :
  • manually via the smartphone
  • for a specific duration via a scenario
  • within the framework of a weekly schedule
My question is the following:
In the dZVents language, is it possible to know HOW my electrovalve has been activated?
Thank you in advance for your help
Regards - Jean-Paul
Re: Which action triggered my device ?
jpr105 wrote: Wednesday 07 April 2021 18:31 s it possible to know HOW my electrovalve has been activated?
Not natively but below script (using sqlite3 to access the domoticz database) will show you the last actor of the device.
        triggerinfo.lua
        requires:   sqlite3
                    dzVents  >= 3.0.13
                    domoticz >= V2020.2 build 12693
return
    on =
        devices =
            'myDevice', -- Change to device you need to monitor
            'eventTrigger',
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when script is tested and OK
        marker = 'getActor',
    execute = function(dz, item)
        local function getLightingLogData(id)
            local _,rc = dz.utils.osCommand('which sqlite3')
            if rc == 0 then
                local cmd = 'sudo sqlite3  -list -noheader domoticz.db "SELECT DeviceRowID ID, User, Date FROM LightingLog WHERE DeviceRowID = ' .. id .. ' ORDER BY Date  DESC LIMIT 1;" '
                return dz.utils.osCommand(cmd)
                dz.log('sqlite3 not available. Please make sure it is installed (sudo apt install sqlite3) and accessible', dz.LOG_ERROR)
        -- main
        if item.active then
            local lightingLogLine = getLightingLogData(item.id)
            if lightingLogLine:find('|') then
                local lightingLogLineTable = dz.utils.stringSplit( getLightingLogData(item.id) ,'|')
                local user = lightingLogLineTable[2]
                local modTime = lightingLogLineTable[3]
                dz.log( 'user: '.. user ..  ' triggered me at ' ..  modTime,dz.LOG_FORCE)
                dz.log( 'No data in LightingLog for device ' .. item.name,dz.LOG_DEBUG)
jpr105
Post by jpr105 »
Thank you waaren
Fast and efficient. I will try asap ;)
