Need to convert sunset as a $ as 20:30 f.I.
Search the wiki, but can’t find it.
Convert sunset as $
Dickey
- Domoticz version: 2022.1
Convert sunset as $
Dz-beta | Dashticz 3.8.10 BETA | Tradfri | RF-Link | Z-Wave | Harmony | Unify | P1 |
- waaren
Re: Convert sunset as $
Can you please elaborate a bit on this? Based on this one line, I have no clear idea on what you try to achieve.Dickey wrote: Wednesday 31 March 2021 10:47 Hi,
Dickey
Hi waaren,
Thanks for you're answer. This is a part of the code.
Want to have a action between 2 different moments.
local onTime = 'sunset'
local ofTime = '23:00'
local printerTime = '09:00'
if os.date('%H:%M') >= onTime and os.date('%H:%M') <= ofTime then
if otherdevices['Wie is er thuis'] == 'Off' then
print ("We zijn NIET thuis")
- erem
- Domoticz version: 2021.1
Regards,
Rob
Rob
Dickey
Thanks Rob,
Wil try that, let you know the result.
Dick
Dick
- waaren
Dickey wrote: Wednesday 31 March 2021 12:23 Hi waaren,
local onTime = 'sunset' local ofTime = '23:00' local printerTime = '09:00' commandArray = {} if os.date('%H:%M') >= onTime and os.date('%H:%M') <= ofTime then if otherdevices['Wie is er thuis'] == 'Off' then print ("We zijn NIET thuis")
OK. sunset moment is passed to Lua as minutes since midnight in _G.timeofday.SunsetInMinutes
This will give you two options.
local onTime = _G.timeofday.SunsetInMinutes -- sunset as minutes since midnight
local now = os.date('%H') * 60 + os.date('%M') -- now in minutes since midnight
if now >= onTime and os.date('%H:%M') <= ofTime then
local function minutesToTime(minutes)
local h = math.floor(minutes / 60)
local hh = ('0' .. h):sub(-2)
local mm = ('0' .. minutes - (h * 60)):sub(-2)
return hh .. ':' .. mm
local onTime = minutesToTime(_G.timeofday.SunsetInMinutes) -- sunset as hh:mm
print(onTime)
Dickey
You been very busy
Tnx for that.
I used opt 2. Did not know the ... minutesToTime(_G.timeofday.SunsetInMinutes).
This is new piece:
Appreciate you're help.
Thanks a lot.
This is new piece:
commandArray['Group:Hoofdverlichting']='Inactive'Thanks a lot.
