I have a house with thermostat in living room. Living room has lots af glas (door/window) on south wich makes it warm when sun is shining (even if outside temp is low). Because of this, upstairs is not heated. Only if i close all downstair radiators and set Nefit room thermostat to >20C, all heat is transferred to upstairs radiators and heating up the bed and bathrooms. Because upstairs is no regulation, the temperature is not controlled.
With automatic thermostats I can control the room temperature, but Nefit CV (Central Heating Unit) will only stop when max water temp is reached and CV shuts down. Last winter I fitted all radiators with Zigbee remote thermostat from tuya. Also I installed Nefit Easy on Domoticz/Pi to read/control CV unit. I made several independent blocky scripts witch I have to enable/disable by hand, but they work!
By default all downstairs (room=kamer) thermostats are full open (25C) and upstairs (bathroom=badkamer, slaapkamer zuid=room south)are full closed (5C)
Script 1:
If Nefit room temp >18C, set all room thermostat = 19C. when Nefit room temp <18, set all thermostat = 22C (this regulate downstair room temp +- 19C)
Script 2:
If badkamer <21, set badkamer thermostat =25C, if badkamer >=21, set badkamer thermostat = 15 (this should regulate badkamer temp +-21C) If south temp <20, set south thermostat =25C, if south temp >=21, set south thermostat = 15 (this should regulate badkamer temp +-20C)
script 3:
If Slaapkamer Zuid <19C, set Nefit Setpoint = 19C, If Slaapkamer Zuid >=19C, set Nefit Setpoint = 18C. This regulates the CV heating unit, overruling the Nefit Room thermostat bij "injecting" Domoticz value.
*Nefit room temp is read by the Nefit Easy Thermostat unit
*Nefit Setpoint is the Domoticz value witch can be set to the Nefit Easy thermostat unit
*South is Slaapkamer zuid
I tried to create 1 blockly script where all scripts are integrated and also implementing 1 virtual button (verwarming=heating) wich by pressing should disable the normal program mode from the thermostat and enable/disable boiler (hot water from CV unit) and execute the above scripts (1,2,3)
But I get some strange behavior, possible because of nested if-do / if-do-else statements, and I don't know/understand how to "read" or implement the if-do-else statements and how to nest them.
https://prnt.sc/10zuqwy
Need help with (nested) Blockly
njlammerts
- Domoticz version: 2022.2
- waaren
Re: Need help with (nested) Blockly
Blockly in domoticz does not support nested if-elsenjlammerts wrote: Tuesday 30 March 2021 13:09 I don't know/understand how to "read" or implement the if-do-else statements and how to nest them.
njlammerts
Is there an other way to achieve the discribes functionality with Blockly? Maybe "nested" is not the correct way to describe my situation?
Does the display blockly method can work as I see some other examples where several functions are attached within if-then-else statements
The first set of blocks work ok (verwarming on/of and setting thermostats to 18/22 and 25/5 ). I can see the Nefit thermostat setpoint change and also I hear the Tuya CV thermostats change the valve position. But when controlling the badkamer and slaapkamer zuid setting and setting the Nefit Setpoint and Valves it goes weird
- waaren
No.
If you really want this in Blockly you will have to do something like,
if verwarming = Off
set Clock mode = On
elseif verwarming = On and Nefit temp < 18
set Clock mode = Off
set setpoints 22
elseif verwarming = On and Nefit temp >= 18
set setpoints 18
elseif verwarming = On and ( Slaapkamer zuid < 20 or badkamer temp < 18)
set Nefit setpoints 20
etc..
njlammerts
Changed my Blockly script, and now it work. Thanks!
