Page 1 of 2
Can the MQTT Client Gateway post "retained" messages?
Posted: Monday 29 March 2021 15:07
by Bikey
I'm using the MQTT Client gateway to have Domoticz publish the status of sensors and switches on MQTT so that other software can use this.
This works fine, except that if the other tool restarts, it is not until and update is send from Domoticz about a sensor before it is informed of the last state. This would be solved if Domoticz would publish it's messages on MQTT using the "retain" flag (see
explanation)
However, I don't see how this can be configured in the MQTT Client gateway.
Does anybody know an elegant way to do this?
Re: Can the MQTT Client Gateway post "retained" messages?
Posted: Monday 29 March 2021 15:51
From what I know about retained messages this is not what they are meant for. And also you will have to find a way to remove them again.
Better is to have the other tool request the device data on startup with MQTT command "getdeviceinfo".
Posted: Monday 29 March 2021 16:30
by waaren
waltervl wrote: Monday 29 March 2021 15:51
This is exactly what retained Mosquitto message are meant for.
Removal of retained messages is an implicit process. As soon as the next message arrives for a topic the previous message is removed.
Posted: Monday 29 March 2021 16:40
Then I read the wrong article or mis interpretated it.....
Posted: Monday 29 March 2021 16:51
by Bikey
Yes, this is exactly what the use is for retained messages.
From the link I have referred to:
Retained messages help newly-subscribed clients get a status update immediately after they subscribe to a topic. The retained message eliminates the wait for the publishing clients to send the next update.
To me this is so common sense, I wonder if/why nobody else seems to have ran into this question with Domoticz?
Posted: Monday 29 March 2021 17:15
From what I see in on the forum most people use MQTT to communicate from Domoticz with single devices (or hubs with devices) and those devices (or hubs) know their own status. They only get data from Domoticz to do something, switch on/off etc. So in that case no need to send retained messages from Domoticz. Domoticz is receiving device status data and sending commands.
To what other systems are you sending MQTT messages with Domoticz device info?
Posted: Monday 29 March 2021 18:03
by Bikey
I'm using Domoticz on a Raspberry Pi to read the status of GPIO-ports that are connected to my alarm system and be able to switch it on/of.
Domoticz acts as a hub to forward this information to HomeAssistant that does logic with it (to which I am migrating to)
Posted: Tuesday 30 March 2021 0:21
You better use a separate application for that instead of Domoticz. Google for raspberry GPIO mqtt and a new world will arise
Probably easier to setup retained messages too.....
Posted: Monday 26 April 2021 14:00
by waaren
Bikey wrote: Monday 29 March 2021 18:03
Domoticz acts as a hub to forward this information to HomeAssistant that does logic with it.
Thx to @kiddigital, from 2021.1 build 13232 onwards domoticz MQTT supports retained messages.
To list all retained messages use following cmd on the command line
sudo mosquitto_sub --retained-only -F "%U - %t - %p" -v -p 1883 -t "#" | paste -sd '' | sed 's/\t/ /g' | sed 's/ / /g' | sed 's/\}1/\}\n1/g'
nb. because of buffering it might take until a next message before the command will show results.
Posted: Saturday 02 October 2021 15:49
by Andrex
waaren wrote: Monday 26 April 2021 14:00from 2021.1 build 13232 onwards domoticz MQTT supports retained messages.
Where do I set the retain flag? In the hardware section I can't find it.
Posted: Saturday 02 October 2021 16:35
by jvdz
Andrex wrote: Saturday 02 October 2021 15:49
In the Hardware setup, but this is only valid for certain formats :
Publish Topic:
Flat
Select the Topic('s) Domoticz will use to publish outgoing messages.
Flat - publish outgoing messagen on topic {domoticz/out}.
Hierarchical - publish outgoing messagen on topic {domoticz/out}/{$floorplan name}/{$plan name}.
Combined - Use both Flat and Hierarchical topic schemes.
Index - publish outgoing messagen on topic {domoticz/out}/{$idx}. (with or without Retain bit)
Name - publish outgoing messagen on topic {domoticz/out}/{$name}. (with or without Retain bit)
None - disable outgoing messages.
Posted: Saturday 02 October 2021 16:41
by Andrex
jvdz wrote: Saturday 02 October 2021 16:35
In the Hardware setup, but this is only valid for certain formats (?) :
Publish Topic:
Flat
I'm sorry, but I'm lost.
What you reported is what I see in the hardware setup, but where o I set the retain bit?
Posted: Saturday 02 October 2021 16:44
by jvdz
Andrex wrote: Saturday 02 October 2021 16:41
... by setting the Publish topic to one of the items that has
(with Retain).
I have no idea why the other message types do not have the option to set the retain option, but that seems to be the choice made in hardware.html:
<td>
<select id="combotopicselect" style="width:200px" class="combobox ui-corner-all">
<option value="1">Flat</option>
<option value="2">Floor/Room</option>
<option value="3">Flat + Floor/Room</option>
<option value="4">Index</option>
<option value="132">Index (with Retain)</option>
<option value="8">Name</option>
<option value="136">Name (with Retain)</option>
<option value="0">None</option>
</select>
<br>
<span>
Select the Topic('s) Domoticz will use to publish outgoing messages. <br>
<b>Flat</b> - publish outgoing messagen on topic <i>{domoticz/out}</i>.<br>
<b>Hierarchical</b> - publish outgoing messagen on topic <i>{domoticz/out}/{$floorplan name}/{$plan name}</i>.<br>
<b>Combined</b> - Use both <b>Flat</b> and <b>Hierarchical</b> topic schemes.<br>
<b>Index</b> - publish outgoing messagen on topic <i>{domoticz/out}/{$idx}</i>. (with or without Retain bit)<br>
<b>Name</b> - publish outgoing messagen on topic <i>{domoticz/out}/{$name}</i>. (with or without Retain bit)<br>
<b>None</b> - disable outgoing messages.<br>
<br>
Note that <b>Hierarchical</b> only reports sensor updates for sensors that are placed on a floorplan/plan.<br>
<br>
Alternative topic prefixes for {domoticz/in} and {domoticz/out} can be entered below.<br>
</td>
Posted: Saturday 02 October 2021 16:59
by Andrex
[quote=jvdz post_id=280344 time=1633185856 user_id=3281]
... by setting the Publish topic to one of the items that has [b](with Retain)[/b].
[/quote]
I'm sorry again...but in those items how do I specify that I need the retain bit?
This is what I see:
[attachment=0]chrome_KcZGCRAw60.png[/attachment]
P.s. I don't know how I broke the quote here...
Posted: Saturday 02 October 2021 17:31
by jvdz
Click the Dropdownbox that contains flat and you understand what I mean..... but: I do not see the option to set the retain for the FLAT format in the html page, but assume it is possible when that option would be added or we know what the JSON call looks like.
Posted: Saturday 02 October 2021 18:34
by jvdz
I also understand why the retain option is made only available to those 2 option as retain means is saves the last message for a specific topic and saving the last message for the other topics doesn't make sense when you like to save the last status per device!.
Posted: Saturday 02 October 2021 23:08
by kiddigital
Andrex wrote:jvdz wrote: Saturday 02 October 2021 16:44
(with Retain).
This is what I see:
Are you sure you are at the right Beta version? Make sure you clear your browser cache after updating Domoticz.
When at the right version, you should see in the dropdown list also options that say that the retain bit will be set as well.
Posted: Sunday 03 October 2021 0:05
It should be in the Publish Topic pulldown menu
- Screenshot_20211003-000028~2.png (97.69 KiB) Viewed 3418 times
Posted: Sunday 03 October 2021 14:30
by Andrex
waltervl wrote: Sunday 03 October 2021 0:05
I don't have those 2 options in the pulldown menu:
- firefox_2EpTc4v5Es.png (5.96 KiB) Viewed 3405 times
I'm on version 2021.1 Compile Date: 2021-04-17 (I don't see the build number).
Posted: Sunday 03 October 2021 14:35
by Andrex
kiddigital wrote: Saturday 02 October 2021 23:08
I've just update to the latest beta (Version: 2021.1 (build 13682)) and I still don't have those 2 options...
Edit: never mind, it was the same cache problem, now I see those 2 options.
Thanks!!!
