screenshot from cammera is not working
Posted: Friday 26 March 2021 11:34
Hi All,
I've got a little problem with the camera feature. I've got a working system for past 3 years with camera. After last changes in network I needed to reconfigure the camera configuration with changing the IP. I've notice that after changing I don't see the screen from camera when configuring and using "test connection" button but once the config is saved I see the miniature with correct and updated view. The stream video is working however the screenshot feature is not working at all. The effect is that I cannot use the blocky screenshot and send e-mail feature.
Stream is working as expected which is a bit strange cause as far as I understand screenshot and stream are referring to the same link (https://XXXXX/camsnapshot.jpg?idx=1) and the difference is only in refresh time.
So in summary following works:
https://XXXXX/camsnapshot.jpg?idx=1& ... 6754700022
Following does not:
Now I've removed the camera from configuration and added it fresh, did not work.
I've updated to latest 2020.02 (build 13119) still no go.
Any suggestions would be really great.
Peter
Update: I've just installed a fresh instance of the system in docker where I can test the configuration. Look like this is working as expected so I've got something wrong with the instance running for 3 years. Maybe a db corruption?
Update2: seams to be resolved. Restored previous DB and imported missing parts. All looks good for the moment
Following does not:
Peter
