Hi All,
I've got a little problem with the camera feature. I've got a working system for past 3 years with camera. After last changes in network I needed to reconfigure the camera configuration with changing the IP. I've notice that after changing I don't see the screen from camera when configuring and using "test connection" button but once the config is saved I see the miniature with correct and updated view. The stream video is working however the screenshot feature is not working at all. The effect is that I cannot use the blocky screenshot and send e-mail feature.
Stream is working as expected which is a bit strange cause as far as I understand screenshot and stream are referring to the same link (https://XXXXX/camsnapshot.jpg?idx=1) and the difference is only in refresh time.
So in summary following works:
https://XXXXX/camsnapshot.jpg?idx=1& ... 6754700022
Following does not:
Now I've removed the camera from configuration and added it fresh, did not work.
I've updated to latest 2020.02 (build 13119) still no go.
Any suggestions would be really great.
Peter
Update: I've just installed a fresh instance of the system in docker where I can test the configuration. Look like this is working as expected so I've got something wrong with the instance running for 3 years. Maybe a db corruption?
Update2: seams to be resolved. Restored previous DB and imported missing parts. All looks good for the moment
screenshot from cammera is not working
bbrowaros1
- Target OS: -
Re: screenshot from cammera is not working
I have the same issue. If I edit and then hit save, they don't show up in the photos app. If I use a file browser to go to the photos > markup folder, they are all there and then will show up in the photos app. It's like they need to get triggered by looking at them from the file browser.bbrowaros1 wrote: Friday 26 March 2021 11:34 Hi All,
Following does not:
Peter
PrepaidGiftBalance
Eric58
With the beta installed, tap the menu icon in the top right corner then go to Settings > Accounts & Privacy. Near the bottom of the page is a button labeled Edit and share screenshots. Turn it on. You might see a prompt the next time you take a screenshot, which will ask if you want to turn on the new feature. IndigoCard
