Does not display the correct level brightness Zigate + domoticz
Posted: Thursday 25 March 2021 14:29
by pfloryann
I noticed that for devices controlled by Zigate, Domoticz it does not retain the last set brightness level. For example i changed from 100% to 50%, Zigate send the command to device and this works but in Domoticz widget is same... domoticz show me 100% and not 50% brightness level.
I tested with Philips Hue lightstrip , Ikea Tradfri Bulb and Ikea Tradfri led power supply - all have the same problem.
I tested Xiaomi Wifi lightstrip and for this all is fine in Domoticz widget.
I using Domoticz 2020.2 (build 13116), Plugin: 4.12.223
Re: Does not display the correct level brightness Zigate + domoticz
Posted: Thursday 25 March 2021 14:57
by pipiche
works for me on Domoticz build 13080, will check on 13116 are above ...
Posted: Thursday 25 March 2021 15:39
by pipiche
I do confirm this is happening on 13116 and not 13080 nor 13109
Posted: Friday 26 March 2021 10:10
by pfloryann
With 13118 and update plugin works for now
Posted: Friday 26 March 2021 11:47
by pipiche
You right 13119 works
