Using Domoticz Rest API, how to create a switch with On/Off Action Topic is solved
sazaki
Post by sazaki »
I can create a switch using the REST API:
http://192.168.18.1:8080/json.htm?type= createdevice & idx=29&sensorname=switch1&devicetype=244&devicesubtype=73
But, I don't know how to use API to fill the "On Action" "Off Action" of the created switch. I would like to have something like http://192.168.18.3/myscripyt1.sh in "On Action" , http://192.168.18.3/myscripyt2.sh in "Off Action".
Any help or advice is appreciated.
Re: Using Domoticz Rest API, how to create a switch with On/Off Action
sazaki wrote: Wednesday 24 March 2021 3:51 I don't know how to use API to fill the "On Action" "Off Action" of the created switch.
You can use the "setused" REST API where the actions are base64 encoded in strparam1 and strparam2
something like
http://<domoticz ip:domoticz port>/json.htm?type=setused&used=true&idx=IDX&strparam1=base64Encoded(ON ACTION STRING)&strparam2=base64Encoded(OFF ACTION STRING)
http://<domoticz ip:domoticz port>/json.htm?type=setused&used=true&idx=<your idx>&strparam1=aHR0cDovLzE5Mi4xNjguMTguMy9teXNjcmlweXQxLnNo&strparam2=aHR0cDovLzE5Mi4xNjguMTguMy9teXNjcmlweXQyLnNo
sazaki
Post by sazaki »
Thank you very much. It works.
