Crash after update beta 13104 Topic is solved
tomyc
Post by tomyc »
I have installed update beta 13104 and Domoticz now crash after about one minute. After restart works again one minute. I have tried to reinstall it but after recovery database problem appears again. It is strange because backup has been created before domoticz upgrade. Last lines in log file:
2021-03-23 21:59:00.541 Error: Domoticz(pid:7205, tid:7210('SQLHelper')) received fatal signal 6 (Aborted)
2021-03-23 21:59:00.541 Error: siginfo address=0x1c25, address=(nil)
2021-03-23 23:00:13.701  [67efe220] Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2021-03-23 23:00:13.747  [7538c220] Debug: SQLH: Do Task ItemType:14 Cmd: Value:710.0;nil
terminate called after throwing an instance of 'std::invalid_argument'
  what():  stof
Fatal Python error: Aborted
Thread 0x76fdf190 (most recent call first):
2021-03-23 23:00:13.749  [7538c220] Error: Domoticz(pid:14171, tid:14177('SQLHelper')) received fatal signal 6 (Aborted)
2021-03-23 23:00:13.749  [7538c220] Error: siginfo address=0x375b, address=(nil)
2021-03-23 23:00:13.769  [72d59220] Debug: web: Host:192.168.0.115 Uri;/json.htm?type=devices&filter=all&used=true&lastupdate=1616536805
2021-03-23 23:00:13.799  [72d59220] Debug: web: Host:192.168.0.133 Uri;/json.htm?type=command&param=getlog&lastlogtime=1616536807&loglevel=268435455
2021-03-23 23:00:13.800  [72d59220] Debug: WEBS GetJSon :getlog :/json.htm?type=command&param=getlog&lastlogtime=1616536807&loglevel=268435455
2021-03-23 23:00:18.156  [7538c220] Error: Thread 3 (Thread 0x7538c220 (LWP 14177)):
2021-03-23 23:00:18.156  [7538c220] Error: #0  __waitpid (options=0, stat_loc=0x7538a1c8, pid=19000) at ../sysdeps/unix/sysv/linux/waitpid.c:30
2021-03-23 23:00:18.156  [7538c220] Error: #1  __waitpid (pid=19000, stat_loc=0x7538a1c8, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
2021-03-23 23:00:18.156  [7538c220] Error: #2  0x002859b4 in dumpstack_gdb(bool) ()
2021-03-23 23:00:18.156  [7538c220] Error: #3  0x00285f80 in signal_handler(int, siginfo_t*, void*) ()
2021-03-23 23:00:18.156  [7538c220] Error: #4  <signal handler called>
2021-03-23 23:00:18.156  [7538c220] Error: #5  raise (sig=6) at ../sysdeps/unix/sysv/linux/raise.c:50
2021-03-23 23:00:18.156  [7538c220] Error: #6  <signal handler called>
2021-03-23 23:00:18.156  [7538c220] Error: #7  __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
2021-03-23 23:00:18.157  [7538c220] Error: #8  0x769fe230 in __GI_abort () at abort.c:79
2021-03-23 23:00:18.157  [7538c220] Error: #9  0x009a415c in __gnu_cxx::__verbose_terminate_handler() ()
2021-03-23 23:00:18.157  [7538c220] Error: #10 0x00907514 in __cxxabiv1::__terminate(void (*)()) ()
2021-03-23 23:00:18.157  [7538c220] Error: #11 0x00907588 in std::terminate() ()
2021-03-23 23:00:18.157  [7538c220] Error: #12 0x00912038 in __cxa_throw ()
2021-03-23 23:00:18.157  [7538c220] Error: #13 0x00940a90 in std::__throw_invalid_argument(char const*) ()
2021-03-23 23:00:18.157  [7538c220] Error: #14 0x002c1b78 in float __gnu_cxx::__stoa<float, float, char>(float (*)(char const*, char**), char const*, char const*, unsigned int*) ()
2021-03-23 23:00:18.157  [7538c220] Error: #15 0x0029c864 in CSQLHelper::UpdateValueInt(int, char const*, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, int, char const*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, bool) ()
2021-03-23 23:00:18.157  [7538c220] Error: #16 0x002bed64 in CSQLHelper::UpdateValue(int, char const*, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, int, char const*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, bool) ()
2021-03-23 23:00:18.157  [7538c220] Error: #17 0x00259e2c in MainWorker::UpdateDevice(int, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int, int, int, int, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int, int, bool) ()
2021-03-23 23:00:18.157  [7538c220] Error: #18 0x0025a754 in MainWorker::UpdateDevice(int, int, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int, int, bool) ()
2021-03-23 23:00:18.157  [7538c220] Error: #19 0x0029e7c0 in CSQLHelper::Do_Work() ()
2021-03-23 23:00:18.158  [7538c220] Error: #20 0x0097b82c in execute_native_thread_routine ()
2021-03-23 23:00:18.158  [7538c220] Error: #21 0x76c0b494 in start_thread (arg=0x7538c220) at pthread_create.c:486
Neúspěšně ukončen (SIGABRT)
Could you please help? Or does anybody have older version of domoticz?
Thank you very much
Tomyc
tomyc
Re: Crash after update beta 13104
Post by tomyc »
I tried to reinstall domoticz, roll back my database version for several days but same problem. After switch off one LUA script it seem to works. But this script has not been changed last days and works without problem with old version of domoticz. Does anybody have idea?
Thank you very much
EDIT: It seems problem is at devices Electricity(instant + counter). I use many these virtual devices but only one works at same time( pic01)
When I change settings "Energy read" from Computed to From device so this settings is coppied to all other device of this type (Electricity). No possible to set each device separately (pic02)
FireWizard
Post by FireWizard »
Hi, @tomyc,
Have a look at viewtopic.php?f=6&t=35855&hilit=13102, which contains a link to: https://github.com/domoticz/domoticz/issues/4736.
So, developers work on a solution and some patience is required.
Toulon7559
Domoticz version: <2025
Post by Toulon7559 »
2*RPI3B+ and 2*RPI0W all with beta 13104 without problems (or at least not visible related to installed applications).
However only 1 *RPI3B+ successfully downloads&installs subsequent beta 13111:
other 3 report download problems after full download cycle.
Strangely, later all 4 show to have 'promoted' to beta 13111.
Last edited by Toulon7559 on Thursday 25 March 2021 21:24, edited 4 times in total.
tomyc
Post by tomyc »
After upgrade to 13111 still same problem. When I turn on script which works with Electricity devices Domoticz do not answer. Same error in log
FireWizard
Solved in version 13119.
tomyc
Post by tomyc »
From version 13119 everything OK again. Thank you very much
Tomyc
