Problem DZVENTS RunBefore or after Sunset etc..  [Solved]
djalexnl
Post by djalexnl »
After upgrading to 13080 this weekend all DZVENT scripts that have a trigger with ...after or before sunset or sunrise stopped working...
For example..
    active = true,
    logging = {
		level = domoticz.LOG_DEBUG, -- Select one of LOG_DEBUG, LOG_INFO, LOG_ERROR, LOG_FORCE to override system log level
		marker = "TEST"
        timer = {'10 minutes after sunset'},
    local ErkerLampLinks = domoticz.devices(2692)
    ErkerLampLinks.switchOn().checkFirst()
I noticed that the last 2 days my lights did not turn on after sunset... so i started testing with some test scripts...
Can someone confirm this ...
Thanx Alex
ben92
Re: Problem DZVENTS RunBefore or after Sunset etc..
Post by ben92 »
you can read viewtopic.php?f=71&t=35810
i've got same problem
djalexnl
Post by djalexnl »
Thanks for the reply, I hope this soon gets fixed!..
djalexnl wrote: Monday 15 March 2021 21:56 Thanks for the reply, I hope this soon gets fixed!..
Thx for reporting. Found the problem and it will be fixed in the next build.
djalexnl
Re: Problem DZVENTS RunBefore or after Sunset etc..  [Solved]
Post by djalexnl »
Problem has been solved! Case can be closed ;-)
Thanks again for the fast fix! 8-)
