Z-Wave curtain switch unable to send STOP command
jjnh
Domoticz version: 2026.2
Post by jjnh »
Currently I am trying some options for our electric blinds. I have bought a Z-Wave curtain/shutter switch. In my case a Shenzhen NEO CoolCam NAS-CS03ZE. The switch is initially recognized as a light switch in Domoticz, but I can reconfigure it as a shutter with percentage control. This works fine.
Now I want to control the shutter from domoticz using remote wall switches.
The issue I run into, is that I cannot send a STOP command. It's either Off (moving down) or On (moving up). When issuing a STOP command from Dzvents. It will be interpreted as an Off command sending the shutter back down again.
What I want to achieve:
Scenario 1:
- press the button for up on the remote
- shutter starts moving up
- when desired position is reached press the up button on the remote again
- shutter stops moving.
Scenario 2:
- Hold the bright button on the remote
- when desired position is reached, release the button on the remote
These operations can be done with the control buttons on the switch as it has an up/stop/down button on the front.
There is also a z-wave class and command for it called:
Command Class = COMMAND_CLASS_SWITCH_MULTILEVEL
Command = SWITCH_MULTILEVEL_STOP_LEVEL_CHANGE
However I cannot get Domoticz to send this to the switch.
How can I get this going?
Kind regards,
John
Odroid N2+ 4GB, Updated to 2025.2, with an RfxTrx433E, Zigbee2MQTT with Slaesh's CC2652RB and more than 65 devices active, Zwave-JS-UI, SolarEdge ModBus, Daikin (via Faikin), ESPEasy devices, iRobot and P1 connected.
jjnh
Re: Z-Wave curtain switch unable to send STOP command
Post by jjnh »
No one any idea?
Pvhpsb
Post by Pvhpsb »
Hey,
Do you have results with the NAS-CS03ZE in Domticz?
With kind regards,
Patrick
