dzVents script to delete history data of devices for which you don't want any history-log
requires domoticz V2020.2 build >= 13027
Warning!!
Please make sure you have a recent and tested backup as this script potentially
deletes many rows from the history tables (on my test system database size went from 23 MB to 6 MB)
        Script to delete history data from database of the devices for which you don't want any historylog
        Warning!! Please make sure you have a recent and tested backup as this script potentially
        there are two ways to have this script ignore devices (and thus do not touch its history)
            1. Add device ID to the comma separated variable "excludeDeviceString"
            2. Add the string "ExcludeFromHistoryDelete" to the description field of the device
        History:
        20210301 initial release
        20200302 Split JSON in used and unused to minimize risk of too many lines
local scriptVar = 'deleteHistory_'
return
    on =
        timer =
          'at 1:53', -- Preferable at the the start of a quiet period
        customEvents =
            scriptVar,
        httpResponses =
            scriptVar .. '*',
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all ok
        marker = scriptVar,
    execute = function(dz, item)
        --- enter below the comma separated list of devices that are to be excluded from deleteHistory
        --- Or enter the string 'ExcludeFromHistoryDelete' anywhere in the device description
        local excludeDeviceString = '3,4,5,6,10,446,447,834,835,192'
        --- No changes required below this line
        local function getDevices(used)
            dz.openURL(
                url = dz.settings['Domoticz url'] .. '/json.htm?type=devices&displayhidden=1&used=' .. tostring(used == 'used'),
                callback = scriptVar .. used,
        local function deleteSwitchLogHistory(idx, delay)
            dz.openURL(dz.settings['Domoticz url'] .. '/json.htm?type=command&param=clearlightlog&idx=' .. idx).afterSec(delay)
            return delay + 2 -- Give command some time to be processed before next one
        local function deleteCalendarHistory(idx, delay )
            dz.openURL
                dz.settings['Domoticz url'] .. '/json.htm?type=command&param=deletedaterange'..
                '&idx=' .. idx ..
                '&fromdate=2010-01-01' ..
                '&todate=9999-12-31'
            ).afterSec(delay)
            return delay + 5 -- Give command some time to be processed before next one
        local function vacuumDatebase(delay)
            dz.log(delay, dz.LOG_DEBUG)
            dz.openURL(dz.settings['Domoticz url'] .. '/json.htm?type=command&param=vacuumdatabase').afterSec(delay + 10 )
        local function hasCalendarHistory(dv)
           return not(dv.Type:lower():find('switch') or dv.SubType:lower():find('switch') or dv.SubType =='AC' or dv.deviceSubType == 'Text')
        local function createExcludedDevicesTable()
            local excludeDevices = {}
            for id in excludeDeviceString:gmatch("%d*") do
                excludeDevices[id] = true
            return excludeDevices
        local function processResult(rt)
            local delay = 0
            local excludeDevices = createExcludedDevicesTable()
            for key, dv in ipairs(rt) do
                if excludeDevices[dv.idx] or dv.Description:find('ExcludeFromHistoryDelete') then
                    dz.log('Exclude: '.. dv.idx .. ' -->> ' .. dv.Name .. ': ' .. dv.Type .. ', ' ..dv.SubType .. ', ' .. dv.Description, dz.LOG_DEBUG)
                elseif hasCalendarHistory(dv) then
                    dz.log('Calendar: '.. dv.idx .. ' -->> ' .. dv.Name .. ': ' .. dv.Type .. ', ' ..dv.SubType .. ', ' .. dv.Description, dz.LOG_DEBUG)
                    delay = deleteCalendarHistory(dv.idx, delay)
                    dz.log('Switch: '.. dv.idx .. ' -->> ' .. dv.Name .. ': ' .. dv.Type .. ', ' ..dv.SubType .. ', ' .. dv.Description, dz.LOG_DEBUG)
                    delay = deleteSwitchLogHistory(dv.idx, delay)
            return delay
        -- main
        if item.isTimer then
            getDevices('used')
        elseif item.isCustomEvent then
            getDevices('unused')
        elseif not(item.json) then
            dz.log('Problem retrieving data ' , dz.LOG_ERROR)
        else -- httpResponse
            local delay = processResult(item.json.result)
            if item.trigger:find('unused') then
                dz.emitEvent(scriptVar).afterSec(delay)
zicht
Domoticz version: 2023.1+
Re: dzVents script to delete history data of devices for which you don't want any history-log
Post by zicht »
Nice & thanks.
Will test this weekeind.
Any particular reason to want to shrink the db this way ?
(with short log on 1 day and lamps on 3 days, i am able to get to <8Mb, but i do not notice any discomfort when >10Mb)
EddyG
Post by EddyG »
With short log sensors on 3 days and lights/switches on 1 day I still have 40Mb, but still have no problem.
My every 5 minutes database backup folder contains almost 34 Gb of databases (3 days) and creates no problem on my NAS.
But I can use the script the other way around just to include some devices of which I do not want any history.
So Tnx @waaren
PieterS
Domoticz version: 2024.7
Post by PieterS »
Hi Waaren,
Nice solution. But last week I was searching for a solution to delete the log of a single (text)-counter "Domoticz uptime". It creates a log that I delete manually once in a while...
This is the device:
This is the script:
    on = {   timer  =   {"every 5 minutes"}},
    execute = function(dz)
        local uptimeTextDevice = dz.devices("Domoticz uptime")
        local minutes = dz.startTime.minutesAgo%60
        local days    = dz.startTime.daysAgo
        local hours   = dz.startTime.hoursAgo%24
        if days == 1 then
            DagText = " dag"
            DagText = " dagen"
        uptimeTextDevice.updateText(days ..DagText..", " .. hours .. " uur en " .. minutes .. " minuten"  )
I had in mind that there is a function in DZvents to delete the entry in the log immediately and just keep the result in a variable of the IDX.. Now there are about 300 entries a day.. The log is useless in my opinion. :?:
You might have a hint?
Synology with Domoticz build (V2024.7) in Docker
HansieNL
Post by HansieNL »
@PieterS
I'm using this script to save uptime as a variable (thanks to @Waaren):
-- dzuptime.lua
-- Set Domoticz Uptime as User Variable string
	--[[ logging = {
		level = domoticz.LOG_ERROR,   -- Select one of LOG_INFO, LOG_DEBUG, LOG_ERROR, LOG_FORCE to override system log level
		marker = "(Uptime)"
		timer = {
			"every minute"
		if days == 1 then DagenText = " dag" else DagenText = " dagen" end
		if hours == 1 then UrenText = " uur" else UrenText = " uren" end
		if minutes == 1 then MinutenText = " minuut" else MinutenText = " minuten" end
		dz.variables("Uptime").set(days ..DagenText.. ", " .. hours ..UrenText.. " en " .. minutes ..MinutenText)
Blah blah blah
zicht wrote: Tuesday 02 March 2021 19:05 Any particular reason to want to shrink the db this way ?
I prefer and use a shortlog of 14 days but I am only interested in a couple devices of the > 400 used in my system. Until now I used a bash script triggered in cron doing more or less the same as this script to keep my production database size within reasonable limits but using dzVents makes it OS independent.
And.. the backup schedule / retention I use (24 hourly backups / 31 daily backups / 12 monthly backups) make that every MB multiplies with 67 :)
PieterS wrote: Tuesday 02 March 2021 19:46 I had in mind that there is a function in DZvents to delete the entry in the log immediately and just keep the result in a variable of the IDX.. Now there are about 300 entries a day.. The log is useless in my opinion. :?:
Can you try this?
        local function deleteTextLog(idx)
        if days == 1 then
            DagText = " dag"
            DagText = " dagen"
        if dz.time.matchesRule('every hour') then -- change to your liking
            deleteTextLog(uptimeTextDevice.id)
PieterS
Post by PieterS »
H waaren,
Tried your script in several ways but it didn't empty the logfile by : I just put the 3 rows near the end into my script, I copied your whole script but no luck...
No errors in logfile of Domoticz..
Changed log level to Debug (everything)
2021-03-03 16:59:00.496 Status: dzVents: Info: ------ Start internal script: Uptime:, trigger: "every minute"
2021-03-03 16:59:00.497 Status: dzVents: Debug: Processing device-adapter for Domoticz uptime: Text device
2021-03-03 16:59:00.497 Status: dzVents: Info: ------ Finished Uptime
2021-03-03 16:59:00.497 Status: dzVents: Debug: - UpdateDevice = {["idx"]=785, ["_trigger"]=true, ["nValue"]=0, ["sValue"]="39 dagen, 21 uur en 29 minuten"}
2021-03-03 16:59:00.683 Status: dzVents: Debug: Processing device-adapter for Domoticz uptime: Text device
2021-03-03 16:59:00.684 Status: dzVents: Debug: - Device: Domoticz uptime
This is the log of today
I use the latest stable version of Domoticz V 2020.2 (build 12231) and dzVents version 3.0.1
What is wrong? :roll:
erem
Domoticz version: 2021.1
Post by erem »
@PieterS
PieterS wrote: Wednesday 03 March 2021 17:18 I use the latest stable version of Domoticz V 2020.2 (build 12231) and dzVents version 3.0.1
which part of
waaren wrote: Tuesday 02 March 2021 16:14 requires domoticz V2020.2 build >= 13027
did you not understand :mrgreen: :mrgreen:
Regards,
Rob
HansieNL
Post by HansieNL »
@PieterS
I switched from variable to this script, so I can use an Uptime device in Domoticz.
Every hour the log is cleared, so the script is working o.k.
Did you try the script as Waaren did post without changes?
Edit: I’m using stable 2020.2, but my dzvents version is 3.0.2. Did you update and upgrade your system?
Blah blah blah
PieterS wrote: Wednesday 03 March 2021 17:18 Tried your script in several ways but it didn't empty the logfile by : I just put the 3 rows near the end into my script, I copied your whole script but no luck...
Did you read this part of the wiki ?
__________________________________________________________________________________________________________________________
When not yet familiar with dzVents please start with reading Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents enabled' is checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
___________________________________________________________________________________________________________________________
In below version I activated debug logging. Can you please try it? It might show enough information to see what goes wrong on your system.
	logging =
		marker = 'upTime',
        if days == 1 then
            DagText = " dag"
            DagText = " dagen"
erem wrote: Wednesday 03 March 2021 17:26 which part of
Maybe the part where it was not in? :o
@PieterS post is about another script.
PieterS
Post by PieterS »
Thanks Waaren for quick reply. I use several dzVentz scripts. So settings should be oke.
@HansieNL: A made a mistake in the version of dzVents. Should be version 3.0.11 :oops: The host is a Synology and Domoticz is a package compiled by Jadahl.
@waaren: Now I copied your full latest script and saved it in a new name.. Changed timers in 2 and 5 minutes.
I had in mind that lines 29 till 31 should do the job.. But lines 13 and 14 are important too :? Sorry for that.
This is a part in the log what might give you some information. Says not much to me..
2021-03-03 19:20:01.011 Status: dzVents: Info: upTime: ------ Start internal script: Uptime2:, trigger: "every 2 minutes"
2021-03-03 19:20:01.011 Status: dzVents: Debug: upTime: OpenURL: url = http://127.0.0.1:8084/json.htm?type=command&param=clearlightlog&idx=785
2021-03-03 19:20:01.011 Status: dzVents: Debug: upTime: OpenURL: method = GET
2021-03-03 19:20:01.011 Status: dzVents: Debug: upTime: OpenURL: post data = nil
2021-03-03 19:20:01.011 Status: dzVents: Debug: upTime: OpenURL: headers = nil
2021-03-03 19:20:01.011 Status: dzVents: Debug: upTime: OpenURL: callback = nil
2021-03-03 19:20:01.011 Status: dzVents: Info: upTime: ------ Finished Uptime2
But clearing the log is succesfull :D
Thanks everyone a lot for your help :P
