Page 1 of 2
Dashticz v3.7.5 beta
Posted: Sunday 28 February 2021 22:01
by Lokonli
A new beta release with as main change: Open Weather Map widgets.
Whilte updating the current OWM module I noticed that OWM provides several widgets as well. I thought let's try to merge those first.
- owmwidget.jpg (30.3 KiB) Viewed 1882 times
blocks['mywidget'] = {
type: 'owmwidget',
layout: 11,
apikey: '123abc...',
city: 'amsterdam',
country: 'nl'
The widgets automatically scales to the column width.
Only the English language is supported.
In total 24 different widgets are available. See:
https://dashticz.readthedocs.io/en/beta ... idget.html
Re: Dashticz v3.7.5 beta
Posted: Monday 01 March 2021 9:18
by RuudP1987
This looked nice to mee so I did git pull to update. All good.
Added to my config.js
//owm config widget
type: 'owmwidget', //to select a owm widget
layout: 11, //1 .. 24
width: 12,
And after that I added it to my 2nd column. But nothing shows up
Currentweather shows up and after that buienradar is showing. Not the graph from OWM.
columns[2] = {
blocks: ['sunrise','currentweather_big_owm','mywidget','buienradar'],
width: 4,
Posted: Monday 01 March 2021 12:10
by Lokonli
'currentweather_big_owm' is working you wrote, so your OWM config settings must be ok ...
Can you open DevTools (F12), and post the errors that are reported on the console tab? (I guess there will be something ...)
Posted: Monday 01 March 2021 16:20
by madpatrick
Working !!
Is it possible the limt the amout of days ? 8 days is to much data for my width and makes the widget very small (not readable)
and change the colors ? Like a black background instead of white
by RuudP1987
Lokonli wrote: Monday 01 March 2021 12:10
XML-parsefout: ongedefinieerde entiteit
Regelnummer 5, kolom 93: news_modal.tpl:5:93
XML-parsefout: onjuist gevormd
Regelnummer 3, kolom 35: garbage_1.tpl:3:35
XML-parsefout: troep na documentelement
Locatie: http://192.168.1.2:8082/tpl/graph_tooltip.tpl
Regelnummer 16, kolom 1:
Posted: Monday 01 March 2021 18:11
by Lokonli
RuudP1987 wrote: Monday 01 March 2021 16:20
There seems to be something wrong with loading the template files (*.tpl) on your system.
What kind of system do you have? Which http server do you use for Dashticz?
But this should not be caused by the new OWM widgets...
Can you check whether you see the same errors in the previous beta? (3.7.4)
Are you using git? You can switch back to the previous beta with:
git checkout b328a91ddcf8bb5916d1638bd7642a6b54179153
then test Dashticz. The owm widgets probably will show an empty button.
Switch back to the latest beta with:
Posted: Monday 01 March 2021 18:18
by Lokonli
madpatrick wrote: Monday 01 March 2021 16:20
Working !!
Customization is rather limited. You can choose on of the other layouts, but for daily forecast you always will receive 8 days.
https://dashticz.readthedocs.io/en/beta ... owmwidgets
You can try to find the CSS styles by right click->inspect. Probably you can adjust the colors via custom.css
When I've time I'll finalize the update of the 'old' weather_owm module.
Posted: Monday 01 March 2021 18:43
by RuudP1987
Lokonli wrote: Monday 01 March 2021 18:11
The checkout gives an error
fatal: reference is not a tree: b328a91ddcf8bb5916d1638bd7642a6b54179153
I am running on a new raspberry 4 (Linux raspberrypi 5.10.11-v7l+) and installed Dashticz by its by automatic script. Apache is running as webserver.
Posted: Wednesday 03 March 2021 11:37
by RuudP1987
@Lokonli, any solution for a fix?
Posted: Friday 05 March 2021 16:08
by Vomera
Styling issue air quality block. I mention it also on 3.7.3 because i was running on that version. Updated to 3.7.5 and still the issue. Maybe its not coded yet. See post at:
viewtopic.php?p=270138#p270138
Posted: Saturday 06 March 2021 16:06
by pvklink
hi @lokonli
I am almost ready with my alarm system.
At the moment i am programming the Armed Home situation.
The Armed Away is already working.
I like to full screen my wall tablet when enabling Arm home OR Arm Away
In the doc it says that i can enable full screen by:
config['security_panel_lock'] = 1; --away
config['security_panel_lock'] = 2; --home
and disable it with config['security_panel_lock'] = 0; --disable
But how to adress both situations ?
I like to have a full screen in both ARM HOME and AWAY situations
suggestion: config['security_panel_lock'] = 3; --home and away
Posted: Saturday 06 March 2021 16:40
by Lokonli
pvklink wrote: Saturday 06 March 2021 16:06
hi @lokonli
If I remember correctly with 2 it will be full screen in Armed home as well as Armed Away mode. Did you try already?
Posted: Saturday 06 March 2021 20:51
by pvklink
ok, will try it and give feedback
Posted: Saturday 06 March 2021 21:00
by pvklink
Works Great!
Thanks !
Perhaps small change to the doc
My alarm system works awsome! Sensors, motion detection, cams,
only part is the geo part that must be changed, IFTTT gives the event far( 5minutes) to late, but thats another topic
I will play with the secpanel part to flash when device changes and when its maximized...
Keep up the good work, my security is GREATTTTT
Posted: Saturday 06 March 2021 22:50
by pvklink
And the flashing of the secpanel also works perfect!
Posted: Sunday 07 March 2021 11:00
by sammyke007
@Lokonli, is there any way to disable the "animation" in the "decorated" secpanel?
No need to code it, but maybe there's already a hidden parameter available?
I guess it's called the "digitdisplay"?
Something I can disable with one of the custom files?
I'm almost sure it's this animation?
.text-strobe {
background: linear-gradient(to right, #e72a3a 10%, #fff 50%, #5bdaff 60%);
background-size: auto auto;
background-clip: border-box;
background-size: 200% auto;
background-clip: text;
-webkit-background-clip: text;
-webkit-text-fill-color: transparent;
animation: textclip 1.5s linear infinite;
@keyframes textclip {
to {
background-position: 200% center;
Will this work after adding to
custom.css?
.sec-frame .text-strobe {
background: red;
animation: none;
or
.text-strobe {
background: red;
animation: none;
3.7.5 is running fine, tnx for the update once again!
Posted: Sunday 07 March 2021 13:23
by Lokonli
sammyke007 wrote: Sunday 07 March 2021 11:00
.text-strobe {
to {
custom.css?
background: red;
animation: none;
or
.text-strobe {
background: red;
animation: none;
Did you already try to set the block parameter 'decorate' to false?
https://dashticz.readthedocs.io/en/beta ... panel.html
Posted: Sunday 07 March 2021 16:33
by sammyke007
Lokonli wrote: Sunday 07 March 2021 13:23
.text-strobe {
to {
custom.css?
background: red;
animation: none;
or
.text-strobe {
background: red;
animation: none;
Yes, I do read manuals
I's just that I like the decorated style, but without animations.
I was already able to make the shield icon to stop spinning, so I guess that the above code works. Will try later today.
Posted: Sunday 07 March 2021 16:48
by pvklink
I am excited about using the dials, they look great and can combine/replace different "old" parts.
I have three blocks for an irrigation item times 6 for my all my irrigation zones, total 18 devices., 3 for a zone
One for duration watering, one for the schema, on for puting it directly on or off
see:
viewtopic.php?p=269920#p269920
Is it possible with the current dial functionality to make a combined dial with
1. Outerring needle to set the duration (0,1, 5, 10,20,30,60 minutes, also selector parts of an idx)
2. Inner part toe select a schema by selector value of a idx
3. Push button part by clicking the black part in the inner circle, on/of of a idx ?
All three parts are there, but not combined, it it possible to create this, would be great (for me
Posted: Sunday 07 March 2021 21:21
by pvklink
I can't get switch to work for the longfonds block
I changed the value from true to false, but nothing happens
blocks['longfonds'] = {
zipcode: '2543BA',
title: 'Luchtkwaliteit',
switch: true,
housenumber: '25',
width: 4,
