I have a propblem using selector switch with harmony hub. I can easily make it work using json calls, but then i dont get state update on selector switch if i use remote control ..
What is proper way to configure selector switch to use actual devices and receive state updates ?
Why is there sub/slave devices and how to use them ?
Selector switch with actual switches and updates ?
tontze
- Domoticz version: Beta Ch
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- Domoticz version: 2025.1
Re: Selector switch with actual switches and updates ?
Did you see the following wiki pages and topics:
https://www.domoticz.com/wiki/Harmony_Hub
viewtopic.php?f=4&t=3311
For sub slaves see the following old wiki page:
https://www.domoticz.com/wiki/Harmony_Hub_Control
tontze
Thnx , read those.
Couldnt find answer tho, if i do selector switch with json calls, it wont get updated if i use remote..
In selector swith there should be option to directly use existing devices.
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
