collect data from multiple temp sensors in one sensor
Posted: Monday 22 February 2021 15:50
by svdhaar
is it possible to collect the temperature data from different temp sensors and store / show them in a custom sensor?
i have 3 temp sensors which shows temperature data from my Nas (CPU / HDD1 & HDD2).
my goal is to present this data in one sensor. Main reason is to save space on screen
I'm not a programmer.. found a little script and was trying a bit. With no luck..
anyone with some tips?
timer = {
'every 1 minutes'
execute = function(domoticz, device, timer)
local tempnas = domoticz.devices('NAS - Temp')
local temphd1 = domoticz.devices('NAS - Temp hd1')
local temphd2 = = domoticz.devices('NAS - Temp hd2')
local Temptest = domoticz.devices('NAS - TEMP test')
Temptest.updateCustomSensor(tempnas, temphd1, temphd2)
Re: collect data from multiple temp sensors in one sensor
Posted: Monday 22 February 2021 16:05
by waaren
svdhaar wrote: Monday 22 February 2021 15:50
On what screen? You add a device that will also be visible on a screen. So you go from 3 to 4 devices?
A custom sensor can only display one value so you could average the 3 temperatures but not display all 3.
You could use a text sensor to display multiple values
Posted: Monday 22 February 2021 17:51
by svdhaar
waaren wrote: Monday 22 February 2021 16:05
Do you have an coding example?
i'm using aurora which makes the graphic a bit nicer. ultimate goal is to screw an ipad onto the wall.
as you can see i have NAS sensors shoing data. i would like to add some more.
6 items is the max. thats why i would like to combine the 3 temp values in one sensor.
Posted: Monday 22 February 2021 19:33
by waaren
svdhaar wrote: Monday 22 February 2021 17:51
Sure..
return
on =
timer =
'every minute',
logging =
level = domoticz.LOG_DEBUG,
marker = 'combine values',
execute = function(dz)
local tempnas = dz.devices('Combined NAS - Temp') -- create as text sensor
local temphd1 = dz.devices('NAS - Temp hd1')
local temphd2 = dz.devices('NAS - Temp hd1')
local Temptest = dz.devices('NAS - TEMP test')
local text =
temphd1.name .. ': ' .. dz.utils.round(temphd1.temperature,1) ..' °C\n' ..
temphd2.name .. ': ' .. dz.utils.round(temphd2.temperature,1) ..' °C\n' ..
Temptest.name .. ': ' .. dz.utils.round(Temptest.temperature,1) .. ' °C'
if tempnas.text ~= text then tempnas.updateText(text) end
Posted: Tuesday 23 February 2021 7:50
by svdhaar
waaren wrote: Monday 22 February 2021 19:33
Sure..
return
on =
timer =
'every minute',
logging =
local text =
NICE!
thx! working like a charm
would it be possible to cut of the name of the device? and show the values without the .0?
As you can see the with is maximized
output like this:
21°C 21°C 40°C
Posted: Tuesday 23 February 2021 8:38
by waaren
svdhaar wrote: Tuesday 23 February 2021 7:50
Sure, change the local text part to
local text =
dz.utils.round(temphd1.temperature) ..'°C\n' ..
dz.utils.round(temphd2.temperature) ..'°C\n' ..
dz.utils.round(Temptest.temperature) .. '°C'
Posted: Tuesday 23 February 2021 8:48
by svdhaar
waaren wrote: Tuesday 23 February 2021 8:38
local text =
Thank you!!
Posted: Tuesday 23 February 2021 9:43
by svdhaar
svdhaar wrote: Tuesday 23 February 2021 8:48
local text =
Thank you!!
I would like to perform this arithmic on my internet speed sensors. Those are custom sensors.
Where can i find the needed atributes? i've tried .values, with no luck
: attempt to perform arithmetic on a nil value (local 'x')
return
on =
timer =
'every 1 minutes',
logging =
local speed = dz.devices('Speed') -- create as text sensor
local download = dz.devices('Internet - Download')
local upload = dz.devices('Internet - Upload')
local ping = dz.devices('Internet - Ping')
local text =
dz.utils.round(download.values) ..
dz.utils.round(upload.values) ..
dz.utils.round(ping.values) .. ''
if speed.text ~= text then speed.updateText(text) end
Posted: Tuesday 23 February 2021 10:14
by waaren
svdhaar wrote: Tuesday 23 February 2021 9:43
Did you try to find it in the
https://www.domoticz.com/wiki/DzVents:_ ... nts wiki ?
There you will see that the attributes name is "sensorValue" (version >= 3.0.11) if you are on an older build you can try sValue or rawData[1]
Posted: Tuesday 23 February 2021 11:14
by svdhaar
waaren wrote: Tuesday 23 February 2021 10:14
thx, wil use this wiki site before posting questions
i'm using domo 2020.1
i've added .sensorValue attribute. that returns an error
return
on =
timer =
'every 1 minutes',
logging =
local text =
dz.utils.round(download.sensorValue) ..
dz.utils.round(upload.sensorValue) ..
dz.utils.round(ping.sensorValue)
Posted: Tuesday 23 February 2021 11:32
by waaren
svdhaar wrote: Tuesday 23 February 2021 11:14
Your version does not support this attribute
