collect data from multiple temp sensors in one sensor
svdhaar
Post by svdhaar »
is it possible to collect the temperature data from different temp sensors and store / show them in a custom sensor?
i have 3 temp sensors which shows temperature data from my Nas (CPU / HDD1 & HDD2).
my goal is to present this data in one sensor. Main reason is to save space on screen :-)
I'm not a programmer.. found a little script and was trying a bit. With no luck..
anyone with some tips? :-)
        timer = {
           'every 1 minutes'
    execute = function(domoticz, device, timer)
        local tempnas      = domoticz.devices('NAS - Temp')
        local temphd1       = domoticz.devices('NAS - Temp hd1')
        local temphd2       = = domoticz.devices('NAS - Temp hd2')
        local Temptest      = domoticz.devices('NAS - TEMP test')
          Temptest.updateCustomSensor(tempnas, temphd1, temphd2)
Re: collect data from multiple temp sensors in one sensor
svdhaar wrote: Monday 22 February 2021 15:50 my goal is to present this data in one sensor. Main reason is to save space on screen :-)
On what screen? You add a device that will also be visible on a screen. So you go from 3 to 4 devices?
A custom sensor can only display one value so you could average the 3 temperatures but not display all 3.
You could use a text sensor to display multiple values
svdhaar
Post by svdhaar »
waaren wrote: Monday 22 February 2021 16:05
Do you have an coding example?
i'm using aurora which makes the graphic a bit nicer. ultimate goal is to screw an ipad onto the wall.
as you can see i have NAS sensors shoing data. i would like to add some more.
6 items is the max. thats why i would like to combine the 3 temp values in one sensor.
svdhaar wrote: Monday 22 February 2021 17:51 Do you have an coding example?
Sure..
return
    on =
        timer =
           'every minute',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'combine values',
    execute = function(dz)
        local tempnas = dz.devices('Combined NAS - Temp') -- create as text sensor
        local temphd1 = dz.devices('NAS - Temp hd1')
        local temphd2 = dz.devices('NAS - Temp hd1')
        local Temptest = dz.devices('NAS - TEMP test')
        local text =
            temphd1.name .. ': ' .. dz.utils.round(temphd1.temperature,1) ..' °C\n' ..
            temphd2.name .. ': ' .. dz.utils.round(temphd2.temperature,1) ..' °C\n' ..
            Temptest.name .. ': ' .. dz.utils.round(Temptest.temperature,1) ..  ' °C'
        if tempnas.text ~= text then tempnas.updateText(text) end
svdhaar
Post by svdhaar »
waaren wrote: Monday 22 February 2021 19:33
Sure..
return
    on =
        timer =
           'every minute',
    logging =
        local text =
NICE!
thx! working like a charm :-).
would it be possible to cut of the name of the device? and show the values without the .0?
As you can see the with is maximized
output like this:
21°C 21°C 40°C
svdhaar wrote: Tuesday 23 February 2021 7:50 would it be possible to cut of the name of the device? and show the values without the .0?
Sure, change the local text part to
        local text =
            dz.utils.round(temphd1.temperature) ..'°C\n' ..
            dz.utils.round(temphd2.temperature) ..'°C\n' ..
            dz.utils.round(Temptest.temperature) ..  '°C'
svdhaar
Post by svdhaar »
waaren wrote: Tuesday 23 February 2021 8:38
        local text =
Thank you!! :D :D
svdhaar
Post by svdhaar »
svdhaar wrote: Tuesday 23 February 2021 8:48
        local text =
Thank you!! :D :D
I would like to perform this arithmic on my internet speed sensors. Those are custom sensors.
Where can i find the needed atributes? i've tried .values, with no luck :-) : attempt to perform arithmetic on a nil value (local 'x')
return
    on =
        timer =
           'every 1 minutes',
    logging =
        local speed = dz.devices('Speed') -- create as text sensor
        local download = dz.devices('Internet - Download')
        local upload = dz.devices('Internet - Upload')
        local ping = dz.devices('Internet - Ping')
        local text =
            dz.utils.round(download.values) ..
            dz.utils.round(upload.values) ..
            dz.utils.round(ping.values) ..  ''
        if speed.text ~= text then speed.updateText(text) end
svdhaar wrote: Tuesday 23 February 2021 9:43 I would like to perform this arithmic on my internet speed sensors. Those are custom sensors.
Did you try to find it in the https://www.domoticz.com/wiki/DzVents:_ ... nts wiki ?
There you will see that the attributes name is "sensorValue" (version >= 3.0.11) if you are on an older build you can try sValue or rawData[1]
svdhaar
Post by svdhaar »
waaren wrote: Tuesday 23 February 2021 10:14
thx, wil use this wiki site before posting questions :-)
i'm using domo 2020.1
i've added .sensorValue attribute. that returns an error
return
    on =
        timer =
           'every 1 minutes',
    logging =
        local text =
            dz.utils.round(download.sensorValue) ..
            dz.utils.round(upload.sensorValue) ..
            dz.utils.round(ping.sensorValue)
svdhaar wrote: Tuesday 23 February 2021 11:14 attempt to perform arithmetic on a nil value (local 'x')
Your version does not support this attribute
