Energy Graph
Posted: Monday 22 February 2021 15:12
by Brutus
I'm struggeling with my energy graph. IDX 1 is a P1 Smart Meter With LAN. It monitors a 3 fase meter and we also have solar panels.
I would like to see the actual incomming or outgoing power (-3262). Just as the P1 meter is showing in Domoticz.
When adding this code:
// Grafiek: "Energie"
blocks['graph_1'] = {
    devices: [1],
    legend: false,
	datasetColors: ['white'],
	buttonsBorder: 'transparent',
        buttonsColor: '#ccc',
	buttonsFill: 'transparent',
	lineFill:true,
The graph outputs the standing of the consumption that day.
Output of P1 meter currently -3966
http://192.168.100.9:8080/json.htm?type=devices&rid=1
	"ActTime" : 1614002195,
	"AstrTwilightEnd" : "19:55",
	"AstrTwilightStart" : "05:44",
	"CivTwilightEnd" : "18:38",
	"CivTwilightStart" : "07:01",
	"DayLength" : "10:31",
	"NautTwilightEnd" : "19:17",
	"NautTwilightStart" : "06:23",
	"ServerTime" : "2021-02-22 14:56:35",
	"SunAtSouth" : "12:50",
	"Sunrise" : "07:34",
	"Sunset" : "18:05",
	"app_version" : "2020.2",
	"result" :
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"BatteryLevel" : 255,
			"Counter" : "94628.239",
			"CounterDeliv" : "548.486",
			"CounterDelivToday" : "12.390 kWh",
			"CounterToday" : "32.643 kWh",
			"CustomImage" : 0,
			"Data" : "52778525;41849714;270702;277784;0;3966",
			"Description" : "",
			"Favorite" : 1,
			"HardwareID" : 2,
			"HardwareName" : "P1",
			"HardwareType" : "P1 Smart Meter with LAN interface",
			"HardwareTypeVal" : 5,
			"HaveTimeout" : false,
			"ID" : "0001",
			"LastUpdate" : "2021-02-22 14:56:34",
			"Name" : "Energie",
			"Notifications" : "false",
			"PlanID" : "0",
			"PlanIDs" :
				0
			"Protected" : false,
			"ShowNotifications" : true,
			"SignalLevel" : "-",
			"SubType" : "Energy",
			"SwitchTypeVal" : 0,
			"Timers" : "false",
			"Type" : "P1 Smart Meter",
			"TypeImg" : "counter",
			"Unit" : 1,
			"Usage" : "0 Watt",
			"UsageDeliv" : "3966 Watt",
			"Used" : 1,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "1"
	"status" : "OK",
	"title" : "Devices"
Re: Energy Graph
Posted: Monday 22 February 2021 18:04
by Lokonli
You have to create a 'custom graph'.
For an example for single phase P1 see:
https://dashticz.readthedocs.io/en/mast ... tom-graphs
Re: Energy Graph
Posted: Tuesday 23 February 2021 11:16
by Brutus
@Lokonli
Thnx for your answer. Did look there but had no luck getting it to work now it does.
Used this code:
    title: 'Energie',
    devices: [1],
	graph: ['line','line','line'],
	lineFill:[false, true, true],
	lineTension: 0.4,
	custom : {
        "last day": {
            range: 'day',
            filter: '4 hours',
            data: {
                Actueel: 'd.v_1+d.v2_1-d.r1_1-d.r2_1',
                Verbruik: 'd.v_1+d.v2_1',
                Oplevering: '-d.r1_1-d.r2_1'
	datasetColors: [colourWhite, colourBlueLight, colourOrange],
    legend: true
Result:
Re: Energy Graph
Posted: Tuesday 23 February 2021 13:51
by Lokonli
The graph looks quite ok to me.
What would you like to see differently? The data in the header row?
or combine it with the solar data?
(The energy usage seems high. You have a heat pump/electrical heating?)
Re: Energy Graph
Posted: Wednesday 24 February 2021 11:08
by Brutus
Hi Lokonli,
I'm sorry maybe I was not clear about that. Before you pointed me to that link I already looked at that link but could not get the graph working. After you pointed it again to me I looked and got it working as you can see 8-)
This graph is from work. We only have heatpomps and 104 Solar panels recently placed. So I installed Domoticz to get a better look at the Energy standings. With dashticz we can make it even look nice ;) With days like this the graph looks nice:
Now I thought lets do this at home with the same graph because I like it. But... I copied the code from this page:
https://dashticz.readthedocs.io/en/mast ... stom-graph
Modified it to my device:
blocks['graph_77'] = {
    title: 'Energie',
    devices: [77],
    graph: ['line','bar','bar'],
    custom : {
        "last day": {
            range: 'day',
            filter: '24 hours',
            data: {
                nett: 'd.v_77+d.v2_77-d.r1_77-d.r2_77',
                usage: 'd.v_77+d.v2_77',
                generation: '-d.r1_77-d.r2_77'
        "last 2 weeks": {
            range: 'month',
            filter: '14 days',
            data: {
        "last 6 months": {
            range: 'year',
            filter: '6 months',
            data: {
    legend: true,
    datasetColors:['blue','red','yellow']
With this result:
The last day graph is not working. The other two are giving data.
What could be wrong?
Greetings.
Re: Energy Graph
Posted: Wednesday 24 February 2021 13:31
by Lokonli
Can you add the graph debug button (see manual), select 'last day' button, and copy/paste the debug data here?
Then I'll have a look.
Re: Energy Graph
Posted: Thursday 25 February 2021 9:53
by Brutus
I'm trying to add this button but getting this error:
Error loading custom/CONFIG.js
SyntaxError: missing : after property id at line 329:10
    title: 'Energie',
    devices: [77],
    debug Button: true,
	custom : {
        "last day": {
            range: 'day',
            filter: '24 hours',
            data: {...
Re: Energy Graph
Posted: Thursday 25 February 2021 12:00
by Lokonli
Brutus wrote: Thursday 25 February 2021 9:53 I'm trying to add this button but getting this error:
    title: 'Energie',
    devices: [77],
    debug Button: true,
	custom : {
        "last day": {
            range: 'day',
            filter: '24 hours',
            data: {...
Replace
debug Button: true,
with
debugButton: true,
Re: Energy Graph
Posted: Thursday 25 February 2021 22:18
by Brutus
When using the search option on the Dashticz documentation it creates a space :roll:
Removing the space helps haha. Heres the debug:
  "mountPoint": "#block_24",
  "block": {
    "width": 12,
    "datasetColors": [
      "blue",
      "red",
      "yellow"
    "barWidth": 0.9,
    "beginAtZero": false,
    "borderDash": [],
    "borderWidth": 2,
    "buttonsBorder": "white",
    "buttonsColor": "black",
    "buttonsFill": "white",
    "buttonsIcon": "#686868",
    "buttonsMarginX": 2,
    "buttonsMarginY": 0,
    "buttonsPadX": 6,
    "buttonsPadY": 2,
    "buttonsRadius": 0,
    "buttonsShadow": false,
    "buttonsSize": 14,
    "buttonsText": false,
    "cartesian": "linear",
    "custom": {
      "last day": {
        "range": "day",
        "filter": "24 hours",
        "data": {
          "nett": "d.v_77+d.v2_77-d.r1_77-d.r2_77",
          "usage": "d.v_77+d.v2_77",
          "generation": "-d.r1_77-d.r2_77"
      "last 2 weeks": {
        "range": "month",
        "filter": "14 days",
        "data": {
      "last 6 months": {
        "range": "year",
        "filter": "6 months",
        "data": {
    "customHeader": false,
    "debugButton": true,
    "displayFormats": false,
    "drawOrderDay": false,
    "drawOrderLast": false,
    "drawOrderMonth": false,
    "flash": false,
    "fontColor": "white",
    "format": true,
    "gradients": false,
    "graph": [
      "line",
      "bar",
      "bar"
    "graphTypes": false,
    "groupBy": false,
    "groupByDevice": false,
    "height": false,
    "iconColour": "grey",
    "interval": 1,
    "legend": true,
    "lineFill": false,
    "lineTension": 0.1,
    "maxTicksLimit": null,
    "method": 1,
    "pointBorderColor": [
      "grey"
    "pointBorderWidth": 0,
    "pointRadius": 0,
    "pointStyle": false,
    "range": "initial",
    "refresh": 300,
    "reverseTime": false,
    "sortDevices": false,
    "spanGaps": false,
    "stacked": false,
    "title": "Energie",
    "tooltiptotal": false,
    "zoom": false,
    "devices": [
      77
    "key": "graph_77"
  "key": "graph_77",
  "name": "graph",
  "graphDevices": [
      "AddjMulti": 1,
      "AddjMulti2": 1,
      "AddjValue": 0,
      "AddjValue2": 0,
      "BatteryLevel": 255,
      "Counter": "16816.958",
      "CounterDeliv": "14037.239",
      "CounterDelivToday": "13.105 kWh",
      "CounterToday": "3.174 kWh",
      "CustomImage": 0,
      "Data": "10905291;5911667;4133502;9903737;398;0",
      "Description": "",
      "Favorite": 1,
      "HardwareID": 10,
      "HardwareName": "Energie Meter",
      "HardwareType": "P1 Smart Meter USB",
      "HardwareTypeVal": 4,
      "HaveTimeout": false,
      "ID": "0001",
      "LastUpdate": "2021-02-25 22:16:45",
      "Name": "Energie",
      "Notifications": "false",
      "PlanID": "4",
      "PlanIDs": [
        4,
        6
      "Protected": false,
      "ShowNotifications": true,
      "SignalLevel": "-",
      "SubType": "Energy",
      "SwitchTypeVal": 0,
      "Timers": "false",
      "Type": "P1 Smart Meter",
      "TypeImg": "counter",
      "Unit": 1,
      "Usage": "398 Watt",
      "UsageDeliv": "0 Watt",
      "Used": 1,
      "XOffset": "347",
      "YOffset": "301",
      "idx": 77,
      "currentValue": "3,17 kWh",
      "name": "Energie",
      "sensor": "counter",
      "subtype": "Energy",
      "title": "Energie",
      "txtUnit": "kWh",
      "txtUnits": [],
      "type": "P1 Smart Meter",
      "decimals": 2
  "decimals": 2,
  "graphIdx": "block_24",
  "lastRefreshTime": 1614287811,
  "range": "day",
  "title": "Energie",
  "params": [
    "type=graph&sensor=counter&idx=77&range=day&method=1"
  "txtUnits": [
    "kWh"
  "data": {
    "result": [
        "d": "2021-02-24 22:20",
        "r1_77": "0",
        "v_77": "332"
        "d": "2021-02-24 22:25",
        "r1_77": "0",
        "v_77": "327"
        "d": "2021-02-24 22:30",
        "r1_77": "0",
        "v_77": "330"
        "d": "2021-02-24 22:35",
        "r1_77": "0",
        "v_77": "328"
        "d": "2021-02-24 22:40",
        "r1_77": "0",
        "v_77": "324"
        "d": "2021-02-24 22:45",
        "r1_77": "0",
        "v_77": "326"
        "d": "2021-02-24 22:50",
        "r1_77": "0",
        "v_77": "295"
        "d": "2021-02-24 22:55",
        "r1_77": "0",
        "v_77": "203"
        "d": "2021-02-24 23:00",
        "r1_77": "0",
        "v_77": "201"
        "d": "2021-02-24 23:05",
        "r1_77": "0",
        "v_77": "203"
        "d": "2021-02-24 23:10",
        "r1_77": "0",
        "v_77": "180"
        "d": "2021-02-24 23:15",
        "r1_77": "0",
        "v_77": "178"
        "d": "2021-02-24 23:20",
        "r1_77": "0",
        "v_77": "177"
        "d": "2021-02-24 23:25",
        "r1_77": "0",
        "v_77": "180"
        "d": "2021-02-24 23:30",
        "r1_77": "0",
        "v_77": "198"
        "d": "2021-02-24 23:35",
        "r1_77": "0",
        "v_77": "223"
        "d": "2021-02-24 23:40",
        "r1_77": "0",
        "v_77": "207"
        "d": "2021-02-24 23:45",
        "r1_77": "0",
        "v_77": "294"
        "d": "2021-02-24 23:50",
        "r1_77": "0",
        "v_77": "289"
        "d": "2021-02-24 23:55",
        "r1_77": "0",
        "v_77": "262"
        "d": "2021-02-25 00:00",
        "r1_77": "0",
        "v_77": "268"
        "d": "2021-02-25 00:05",
        "r1_77": "0",
        "v_77": "359"
        "d": "2021-02-25 00:10",
        "r1_77": "0",
        "v_77": "363"
        "d": "2021-02-25 00:15",
        "r1_77": "0",
        "v_77": "375"
        "d": "2021-02-25 00:20",
        "r1_77": "0",
        "v_77": "359"
        "d": "2021-02-25 00:25",
        "r1_77": "0",
        "v_77": "363"
        "d": "2021-02-25 00:30",
        "r1_77": "0",
        "v_77": "354"
        "d": "2021-02-25 00:35",
        "r1_77": "0",
        "v_77": "376"
        "d": "2021-02-25 00:40",
        "r1_77": "0",
        "v_77": "342"
        "d": "2021-02-25 00:45",
        "r1_77": "0",
        "v_77": "322"
        "d": "2021-02-25 00:50",
        "r1_77": "0",
        "v_77": "365"
        "d": "2021-02-25 00:55",
        "r1_77": "0",
        "v_77": "279"
        "d": "2021-02-25 01:00",
        "r1_77": "0",
        "v_77": "180"
        "d": "2021-02-25 01:05",
        "r1_77": "0",
        "v_77": "181"
        "d": "2021-02-25 01:10",
        "r1_77": "0",
        "v_77": "182"
        "d": "2021-02-25 01:15",
        "r1_77": "0",
        "v_77": "184"
        "d": "2021-02-25 01:20",
        "r1_77": "0",
        "v_77": "203"
        "d": "2021-02-25 01:25",
        "r1_77": "0",
        "v_77": "197"
        "d": "2021-02-25 01:30",
        "r1_77": "0",
        "v_77": "194"
        "d": "2021-02-25 01:35",
        "r1_77": "0",
        "v_77": "188"
        "d": "2021-02-25 01:40",
        "r1_77": "0",
        "v_77": "185"
        "d": "2021-02-25 01:45",
        "r1_77": "0",
        "v_77": "181"
        "d": "2021-02-25 01:50",
        "r1_77": "0",
        "v_77": "182"
        "d": "2021-02-25 01:55",
        "r1_77": "0",
        "v_77": "182"
        "d": "2021-02-25 02:00",
        "r1_77": "0",
        "v_77": "315"
        "d": "2021-02-25 02:05",
        "r1_77": "0",
        "v_77": "275"
        "d": "2021-02-25 02:10",
        "r1_77": "0",
        "v_77": "278"
        "d": "2021-02-25 02:15",
        "r1_77": "0",
        "v_77": "276"
        "d": "2021-02-25 02:20",
        "r1_77": "0",
        "v_77": "273"
        "d": "2021-02-25 02:25",
        "r1_77": "0",
        "v_77": "269"
        "d": "2021-02-25 02:30",
        "r1_77": "0",
        "v_77": "269"
        "d": "2021-02-25 02:35",
        "r1_77": "0",
        "v_77": "266"
        "d": "2021-02-25 02:40",
        "r1_77": "0",
        "v_77": "263"
        "d": "2021-02-25 02:45",
        "r1_77": "0",
        "v_77": "262"
        "d": "2021-02-25 02:50",
        "r1_77": "0",
        "v_77": "170"
        "d": "2021-02-25 02:55",
        "r1_77": "0",
        "v_77": "166"
        "d": "2021-02-25 03:00",
        "r1_77": "0",
        "v_77": "167"
        "d": "2021-02-25 03:05",
        "r1_77": "0",
        "v_77": "165"
        "d": "2021-02-25 03:10",
        "r1_77": "0",
        "v_77": "195"
        "d": "2021-02-25 03:15",
        "r1_77": "0",
        "v_77": "183"
        "d": "2021-02-25 03:20",
        "r1_77": "0",
        "v_77": "176"
        "d": "2021-02-25 03:25",
        "r1_77": "0",
        "v_77": "176"
        "d": "2021-02-25 03:30",
        "r1_77": "0",
        "v_77": "177"
        "d": "2021-02-25 03:35",
        "r1_77": "0",
        "v_77": "159"
        "d": "2021-02-25 03:40",
        "r1_77": "0",
        "v_77": "162"
        "d": "2021-02-25 03:45",
        "r1_77": "0",
        "v_77": "161"
        "d": "2021-02-25 03:50",
        "r1_77": "0",
        "v_77": "165"
        "d": "2021-02-25 03:55",
        "r1_77": "0",
        "v_77": "161"
        "d": "2021-02-25 04:00",
        "r1_77": "0",
        "v_77": "259"
        "d": "2021-02-25 04:05",
        "r1_77": "0",
        "v_77": "282"
        "d": "2021-02-25 04:10",
        "r1_77": "0",
        "v_77": "263"
        "d": "2021-02-25 04:15",
        "r1_77": "0",
        "v_77": "261"
        "d": "2021-02-25 04:20",
        "r1_77": "0",
        "v_77": "260"
        "d": "2021-02-25 04:25",
        "r1_77": "0",
        "v_77": "259"
        "d": "2021-02-25 04:30",
        "r1_77": "0",
        "v_77": "259"
        "d": "2021-02-25 04:35",
        "r1_77": "0",
        "v_77": "257"
        "d": "2021-02-25 04:40",
        "r1_77": "0",
        "v_77": "262"
        "d": "2021-02-25 04:45",
        "r1_77": "0",
        "v_77": "255"
        "d": "2021-02-25 04:50",
        "r1_77": "0",
        "v_77": "165"
        "d": "2021-02-25 04:55",
        "r1_77": "0",
        "v_77": "164"
        "d": "2021-02-25 05:00",
        "r1_77": "0",
        "v_77": "163"
        "d": "2021-02-25 05:05",
        "r1_77": "0",
        "v_77": "185"
        "d": "2021-02-25 05:10",
        "r1_77": "0",
        "v_77": "179"
        "d": "2021-02-25 05:15",
        "r1_77": "0",
        "v_77": "177"
        "d": "2021-02-25 05:20",
        "r1_77": "0",
        "v_77": "173"
        "d": "2021-02-25 05:25",
        "r1_77": "0",
        "v_77": "173"
        "d": "2021-02-25 05:30",
        "r1_77": "0",
        "v_77": "163"
        "d": "2021-02-25 05:35",
        "r1_77": "0",
        "v_77": "167"
        "d": "2021-02-25 05:40",
        "r1_77": "0",
        "v_77": "160"
        "d": "2021-02-25 05:45",
        "r1_77": "0",
        "v_77": "166"
        "d": "2021-02-25 05:50",
        "r1_77": "0",
        "v_77": "164"
        "d": "2021-02-25 05:55",
        "r1_77": "0",
        "v_77": "161"
        "d": "2021-02-25 06:00",
        "r1_77": "0",
        "v_77": "292"
        "d": "2021-02-25 06:05",
        "r1_77": "0",
        "v_77": "273"
        "d": "2021-02-25 06:10",
        "r1_77": "0",
        "v_77": "263"
        "d": "2021-02-25 06:15",
        "r1_77": "0",
        "v_77": "257"
        "d": "2021-02-25 06:20",
        "r1_77": "0",
        "v_77": "256"
        "d": "2021-02-25 06:25",
        "r1_77": "0",
        "v_77": "257"
        "d": "2021-02-25 06:30",
        "r1_77": "0",
        "v_77": "255"
        "d": "2021-02-25 06:35",
        "r1_77": "0",
        "v_77": "293"
        "d": "2021-02-25 06:40",
        "r1_77": "0",
        "v_77": "294"
        "d": "2021-02-25 06:45",
        "r1_77": "0",
        "v_77": "295"
        "d": "2021-02-25 06:50",
        "r1_77": "0",
        "v_77": "204"
        "d": "2021-02-25 06:55",
        "r1_77": "0",
        "v_77": "225"
        "d": "2021-02-25 07:00",
        "r1_77": "0",
        "v_77": "227"
        "d": "2021-02-25 07:05",
        "r1_77": "0",
        "v_77": "214"
        "d": "2021-02-25 07:10",
        "r1_77": "0",
        "v_77": "177"
        "d": "2021-02-25 07:15",
        "r1_77": "0",
        "v_77": "169"
        "d": "2021-02-25 07:20",
        "r1_77": "0",
        "v_77": "159"
        "d": "2021-02-25 07:25",
        "r1_77": "0",
        "v_77": "228"
        "d": "2021-02-25 07:30",
        "r1_77": "0",
        "v_77": "210"
        "d": "2021-02-25 07:35",
        "r1_77": "0",
        "v_77": "220"
        "d": "2021-02-25 07:40",
        "r1_77": "0",
        "v_77": "203"
        "d": "2021-02-25 07:45",
        "r1_77": "0",
        "v_77": "110"
        "d": "2021-02-25 07:50",
        "r1_77": "0",
        "v_77": "110"
        "d": "2021-02-25 07:55",
        "r1_77": "0",
        "v_77": "154"
        "d": "2021-02-25 08:00",
        "r1_77": "0",
        "v_77": "123"
        "d": "2021-02-25 08:05",
        "r1_77": "0",
        "v_77": "124"
        "d": "2021-02-25 08:10",
        "r1_77": "0",
        "v_77": "81"
        "d": "2021-02-25 08:15",
        "r1_77": "0",
        "v_77": "27"
        "d": "2021-02-25 08:20",
        "r1_77": "47",
        "v_77": "0"
        "d": "2021-02-25 08:25",
        "r1_77": "109",
        "v_77": "0"
        "d": "2021-02-25 08:30",
        "r1_77": "172",
        "v_77": "0"
        "d": "2021-02-25 08:35",
        "r1_77": "339",
        "v_77": "0"
        "d": "2021-02-25 08:40",
        "r1_77": "411",
        "v_77": "0"
        "d": "2021-02-25 08:45",
        "r1_77": "489",
        "v_77": "0"
        "d": "2021-02-25 08:50",
        "r1_77": "556",
        "v_77": "0"
        "d": "2021-02-25 08:55",
        "r1_77": "666",
        "v_77": "0"
        "d": "2021-02-25 09:00",
        "r1_77": "737",
        "v_77": "0"
        "d": "2021-02-25 09:05",
        "r1_77": "740",
        "v_77": "0"
        "d": "2021-02-25 09:10",
        "r1_77": "1099",
        "v_77": "0"
        "d": "2021-02-25 09:15",
        "r1_77": "810",
        "v_77": "0"
        "d": "2021-02-25 09:20",
        "r1_77": "1301",
        "v_77": "0"
        "d": "2021-02-25 09:25",
        "r1_77": "1376",
        "v_77": "0"
        "d": "2021-02-25 09:30",
        "r1_77": "1421",
        "v_77": "0"
        "d": "2021-02-25 09:35",
        "r1_77": "1200",
        "v_77": "0"
        "d": "2021-02-25 09:40",
        "r1_77": "1318",
        "v_77": "0"
        "d": "2021-02-25 09:45",
        "r1_77": "1151",
        "v_77": "0"
        "d": "2021-02-25 09:50",
        "r1_77": "1266",
        "v_77": "0"
        "d": "2021-02-25 09:55",
        "r1_77": "1094",
        "v_77": "0"
        "d": "2021-02-25 10:00",
        "r1_77": "1186",
        "v_77": "0"
        "d": "2021-02-25 10:05",
        "r1_77": "1006",
        "v_77": "0"
        "d": "2021-02-25 10:10",
        "r1_77": "1199",
        "v_77": "0"
        "d": "2021-02-25 10:15",
        "r1_77": "1396",
        "v_77": "0"
        "d": "2021-02-25 10:20",
        "r1_77": "1264",
        "v_77": "0"
        "d": "2021-02-25 10:25",
        "r1_77": "1400",
        "v_77": "0"
        "d": "2021-02-25 10:30",
        "r1_77": "1637",
        "v_77": "0"
        "d": "2021-02-25 10:35",
        "r1_77": "1413",
        "v_77": "0"
        "d": "2021-02-25 10:40",
        "r1_77": "1357",
        "v_77": "0"
        "d": "2021-02-25 10:45",
        "r1_77": "1429",
        "v_77": "0"
        "d": "2021-02-25 10:50",
        "r1_77": "1232",
        "v_77": "0"
        "d": "2021-02-25 10:55",
        "r1_77": "1749",
        "v_77": "0"
        "d": "2021-02-25 11:00",
        "r1_77": "2060",
        "v_77": "0"
        "d": "2021-02-25 11:05",
        "r1_77": "1934",
        "v_77": "0"
        "d": "2021-02-25 11:10",
        "r1_77": "2041",
        "v_77": "0"
        "d": "2021-02-25 11:15",
        "r1_77": "2132",
        "v_77": "0"
        "d": "2021-02-25 11:20",
        "r1_77": "1972",
        "v_77": "0"
        "d": "2021-02-25 11:25",
        "r1_77": "1670",
        "v_77": "0"
        "d": "2021-02-25 11:30",
        "r1_77": "1861",
        "v_77": "0"
        "d": "2021-02-25 11:35",
        "r1_77": "2127",
        "v_77": "0"
        "d": "2021-02-25 11:40",
        "r1_77": "2065",
        "v_77": "0"
        "d": "2021-02-25 11:45",
        "r1_77": "1833",
        "v_77": "0"
        "d": "2021-02-25 11:50",
        "r1_77": "2116",
        "v_77": "0"
        "d": "2021-02-25 11:55",
        "r1_77": "2283",
        "v_77": "0"
        "d": "2021-02-25 12:00",
        "r1_77": "2136",
        "v_77": "0"
        "d": "2021-02-25 12:05",
        "r1_77": "2005",
        "v_77": "0"
        "d": "2021-02-25 12:10",
        "r1_77": "2160",
        "v_77": "0"
        "d": "2021-02-25 12:15",
        "r1_77": "1978",
        "v_77": "0"
        "d": "2021-02-25 12:20",
        "r1_77": "2185",
        "v_77": "0"
        "d": "2021-02-25 12:25",
        "r1_77": "2157",
        "v_77": "0"
        "d": "2021-02-25 12:30",
        "r1_77": "1818",
        "v_77": "0"
        "d": "2021-02-25 12:35",
        "r1_77": "2080",
        "v_77": "0"
        "d": "2021-02-25 12:40",
        "r1_77": "2594",
        "v_77": "0"
        "d": "2021-02-25 12:45",
        "r1_77": "2567",
        "v_77": "0"
        "d": "2021-02-25 12:50",
        "r1_77": "2576",
        "v_77": "0"
        "d": "2021-02-25 12:55",
        "r1_77": "2553",
        "v_77": "0"
        "d": "2021-02-25 13:00",
        "r1_77": "2557",
        "v_77": "0"
        "d": "2021-02-25 13:05",
        "r1_77": "2442",
        "v_77": "0"
        "d": "2021-02-25 13:10",
        "r1_77": "2476",
        "v_77": "0"
        "d": "2021-02-25 13:15",
        "r1_77": "2516",
        "v_77": "0"
        "d": "2021-02-25 13:20",
        "r1_77": "2501",
        "v_77": "0"
        "d": "2021-02-25 13:25",
        "r1_77": "2423",
        "v_77": "0"
        "d": "2021-02-25 13:30",
        "r1_77": "2252",
        "v_77": "0"
        "d": "2021-02-25 13:35",
        "r1_77": "2168",
        "v_77": "0"
        "d": "2021-02-25 13:40",
        "r1_77": "2367",
        "v_77": "0"
        "d": "2021-02-25 13:45",
        "r1_77": "1987",
        "v_77": "0"
        "d": "2021-02-25 13:50",
        "r1_77": "1987",
        "v_77": "0"
        "d": "2021-02-25 13:55",
        "r1_77": "1760",
        "v_77": "0"
        "d": "2021-02-25 14:00",
        "r1_77": "2141",
        "v_77": "0"
        "d": "2021-02-25 14:05",
        "r1_77": "1918",
        "v_77": "0"
        "d": "2021-02-25 14:10",
        "r1_77": "1743",
        "v_77": "0"
        "d": "2021-02-25 14:15",
        "r1_77": "1384",
        "v_77": "0"
        "d": "2021-02-25 14:20",
        "r1_77": "1552",
        "v_77": "0"
        "d": "2021-02-25 14:25",
        "r1_77": "1964",
        "v_77": "0"
        "d": "2021-02-25 14:30",
        "r1_77": "1672",
        "v_77": "0"
        "d": "2021-02-25 14:35",
        "r1_77": "1648",
        "v_77": "0"
        "d": "2021-02-25 14:40",
        "r1_77": "1467",
        "v_77": "0"
        "d": "2021-02-25 14:45",
        "r1_77": "2105",
        "v_77": "0"
        "d": "2021-02-25 14:50",
        "r1_77": "1748",
        "v_77": "0"
        "d": "2021-02-25 14:55",
        "r1_77": "1790",
        "v_77": "0"
        "d": "2021-02-25 15:00",
        "r1_77": "1736",
        "v_77": "0"
        "d": "2021-02-25 15:05",
        "r1_77": "1795",
        "v_77": "0"
        "d": "2021-02-25 15:10",
        "r1_77": "1718",
        "v_77": "0"
        "d": "2021-02-25 15:15",
        "r1_77": "1610",
        "v_77": "0"
        "d": "2021-02-25 15:20",
        "r1_77": "1274",
        "v_77": "0"
        "d": "2021-02-25 15:25",
        "r1_77": "1468",
        "v_77": "0"
        "d": "2021-02-25 15:30",
        "r1_77": "1369",
        "v_77": "0"
        "d": "2021-02-25 15:35",
        "r1_77": "1290",
        "v_77": "0"
        "d": "2021-02-25 15:40",
        "r1_77": "1224",
        "v_77": "0"
        "d": "2021-02-25 15:45",
        "r1_77": "1075",
        "v_77": "0"
        "d": "2021-02-25 15:50",
        "r1_77": "1036",
        "v_77": "0"
        "d": "2021-02-25 15:55",
        "r1_77": "1018",
        "v_77": "0"
        "d": "2021-02-25 16:00",
        "r1_77": "760",
        "v_77": "0"
        "d": "2021-02-25 16:05",
        "r1_77": "1008",
        "v_77": "0"
        "d": "2021-02-25 16:10",
        "r1_77": "649",
        "v_77": "0"
        "d": "2021-02-25 16:15",
        "r1_77": "624",
        "v_77": "0"
        "d": "2021-02-25 16:20",
        "r1_77": "498",
        "v_77": "0"
        "d": "2021-02-25 16:25",
        "r1_77": "546",
        "v_77": "0"
        "d": "2021-02-25 16:30",
        "r1_77": "741",
        "v_77": "0"
        "d": "2021-02-25 16:35",
        "r1_77": "685",
        "v_77": "0"
        "d": "2021-02-25 16:40",
        "r1_77": "467",
        "v_77": "0"
        "d": "2021-02-25 16:45",
        "r1_77": "402",
        "v_77": "0"
        "d": "2021-02-25 16:50",
        "r1_77": "298",
        "v_77": "0"
        "d": "2021-02-25 16:55",
        "r1_77": "150",
        "v_77": "0"
        "d": "2021-02-25 17:00",
        "r1_77": "83",
        "v_77": "0"
        "d": "2021-02-25 17:05",
        "r1_77": "27",
        "v_77": "0"
        "d": "2021-02-25 17:10",
        "r1_77": "0",
        "v_77": "85"
        "d": "2021-02-25 17:15",
        "r1_77": "0",
        "v_77": "105"
        "d": "2021-02-25 17:20",
        "r1_77": "0",
        "v_77": "155"
        "d": "2021-02-25 17:25",
        "r1_77": "0",
        "v_77": "244"
        "d": "2021-02-25 17:30",
        "r1_77": "0",
        "v_77": "259"
        "d": "2021-02-25 17:35",
        "r1_77": "0",
        "v_77": "273"
        "d": "2021-02-25 17:40",
        "r1_77": "0",
        "v_77": "335"
        "d": "2021-02-25 17:45",
        "r1_77": "0",
        "v_77": "327"
        "d": "2021-02-25 17:50",
        "r1_77": "0",
        "v_77": "333"
        "d": "2021-02-25 17:55",
        "r1_77": "0",
        "v_77": "245"
        "d": "2021-02-25 18:00",
        "r1_77": "0",
        "v_77": "251"
        "d": "2021-02-25 18:05",
        "r1_77": "0",
        "v_77": "271"
        "d": "2021-02-25 18:10",
        "r1_77": "0",
        "v_77": "197"
        "d": "2021-02-25 18:15",
        "r1_77": "0",
        "v_77": "199"
        "d": "2021-02-25 18:20",
        "r1_77": "0",
        "v_77": "199"
        "d": "2021-02-25 18:25",
        "r1_77": "0",
        "v_77": "177"
        "d": "2021-02-25 18:30",
        "r1_77": "0",
        "v_77": "175"
        "d": "2021-02-25 18:35",
        "r1_77": "0",
        "v_77": "175"
        "d": "2021-02-25 18:40",
        "r1_77": "0",
        "v_77": "177"
        "d": "2021-02-25 18:45",
        "r1_77": "0",
        "v_77": "176"
        "d": "2021-02-25 18:50",
        "r1_77": "0",
        "v_77": "176"
        "d": "2021-02-25 18:55",
        "r1_77": "0",
        "v_77": "176"
        "d": "2021-02-25 19:00",
        "r1_77": "0",
        "v_77": "270"
        "d": "2021-02-25 19:05",
        "r1_77": "0",
        "v_77": "304"
        "d": "2021-02-25 19:10",
        "r1_77": "0",
        "v_77": "289"
        "d": "2021-02-25 19:15",
        "r1_77": "0",
        "v_77": "286"
        "d": "2021-02-25 19:20",
        "r1_77": "0",
        "v_77": "280"
        "d": "2021-02-25 19:25",
        "r1_77": "0",
        "v_77": "277"
        "d": "2021-02-25 19:30",
        "r1_77": "0",
        "v_77": "270"
        "d": "2021-02-25 19:35",
        "r1_77": "0",
        "v_77": "271"
        "d": "2021-02-25 19:40",
        "r1_77": "0",
        "v_77": "175"
        "d": "2021-02-25 19:45",
        "r1_77": "0",
        "v_77": "175"
        "d": "2021-02-25 19:50",
        "r1_77": "0",
        "v_77": "177"
        "d": "2021-02-25 19:55",
        "r1_77": "0",
        "v_77": "175"
        "d": "2021-02-25 20:00",
        "r1_77": "0",
        "v_77": "177"
        "d": "2021-02-25 20:05",
        "r1_77": "0",
        "v_77": "177"
        "d": "2021-02-25 20:10",
        "r1_77": "0",
        "v_77": "178"
        "d": "2021-02-25 20:15",
        "r1_77": "0",
        "v_77": "242"
        "d": "2021-02-25 20:20",
        "r1_77": "0",
        "v_77": "256"
        "d": "2021-02-25 20:25",
        "r1_77": "0",
        "v_77": "230"
        "d": "2021-02-25 20:30",
        "r1_77": "0",
        "v_77": "232"
        "d": "2021-02-25 20:35",
        "r1_77": "0",
        "v_77": "232"
        "d": "2021-02-25 20:40",
        "r1_77": "0",
        "v_77": "235"
        "d": "2021-02-25 20:45",
        "r1_77": "0",
        "v_77": "234"
        "d": "2021-02-25 20:50",
        "r1_77": "0",
        "v_77": "326"
        "d": "2021-02-25 20:55",
        "r1_77": "0",
        "v_77": "362"
        "d": "2021-02-25 21:00",
        "r1_77": "0",
        "v_77": "348"
        "d": "2021-02-25 21:05",
        "r1_77": "0",
        "v_77": "341"
        "d": "2021-02-25 21:10",
        "r1_77": "0",
        "v_77": "336"
        "d": "2021-02-25 21:15",
        "r1_77": "0",
        "v_77": "329"
        "d": "2021-02-25 21:20",
        "r1_77": "0",
        "v_77": "325"
        "d": "2021-02-25 21:25",
        "r1_77": "0",
        "v_77": "321"
        "d": "2021-02-25 21:30",
        "r1_77": "0",
        "v_77": "231"
        "d": "2021-02-25 21:35",
        "r1_77": "0",
        "v_77": "230"
        "d": "2021-02-25 21:40",
        "r1_77": "0",
        "v_77": "231"
        "d": "2021-02-25 21:45",
        "r1_77": "0",
        "v_77": "230"
        "d": "2021-02-25 21:50",
        "r1_77": "0",
        "v_77": "233"
        "d": "2021-02-25 21:55",
        "r1_77": "0",
        "v_77": "227"
        "d": "2021-02-25 22:00",
        "r1_77": "0",
        "v_77": "234"
        "d": "2021-02-25 22:05",
        "r1_77": "0",
        "v_77": "234"
        "d": "2021-02-25 22:10",
        "r1_77": "0",
        "v_77": "389"
        "d": "2021-02-25 22:15",
        "r1_77": "0",
        "v_77": "387"
    "status": "OK",
    "title": "Graph day",
  "realrange": "day",
  "dataFilterCount": 24,
  "dataFilterUnit": "hours",
  "groupBy": false,
  "customRange": true,
  "customRangeName": "last day",
  "graphConfig": {
    "range": "day",
    "data": {
  "keys": [
    "v",
    "v",
    "r1"
  "ykeys": [
    "nett",
    "usage",
    "generation"
  "txtUnit": "kWh",
  "ylabels": [
    "Watt",
    "Watt",
    "Watt"
  "chartctx": "graphoutput_block_24",
  "_width": 666,
  "loadingTooltip": false
Re: Energy Graph
Posted: Friday 26 February 2021 0:12
by Lokonli
Your meter behaves like a single tariff meter.
Can you remove all r2 and v2 data fields from the custom data definition and retry?
Re: Energy Graph
Posted: Friday 26 February 2021 1:04
by Brutus
That did the trick! But I don't have a single tariff meter. Domoticz reads both usage and generation devices...
Re: Energy Graph
Posted: Friday 26 February 2021 8:30
by Lokonli
And in the Domoticz day graph?
If the Dashticz weeks and months graph is working, then apparently there's something wrong with the day data.
Can you post the browser output of the following:
http://domoticzip:port/json.htm?idx=77&method=1&range=day&sensor=counter&type=graph
Re: Energy Graph
Posted: Friday 26 February 2021 8:59
by Brutus
hmm never noticed but the day graph indeed has only Usage and generation. Don't know if this is normal behavior of Domoticz.
Output (cut something out because is was a lot of data):
delivered	true
result
0
d	"2021-02-25 08:50"
r1	"556"
v	"0"
1
d	"2021-02-25 08:55"
r1	"666"
v	"0"
2
d	"2021-02-25 09:00"
r1	"737"
v	"0"
3
286
d	"2021-02-26 08:40"
r1	"19"
v	"0"
287
d	"2021-02-26 08:45"
r1	"92"
v	"0"
288
d	"2021-02-26 08:50"
r1	"196"
v	"0"
status	"OK"
title	"Graph counter day"
